Question about Maytag MSD2656G Side by Side Refrigerator
Freezer works fine but the refrigerator part just quits working & ruins all the food. I have to unplug it & the whole tray on the bottom fills up with water after a day, then I plug it back up.
    Sergeant:
  • 340 Answers
Is the thermostat for the frig section set properly? is the condenser clean? could be a defrost problem to many components to try to change i'd call for service. Tom
Posted on Jun 21, 2009
LecT662AW fridge freezer! The freezer compartment works OK. The fridge does not. Any suggestions please?
Check the condenser fan is it working? Is the temperature control door working? If you are about to ruin a whole bunch of food shouldn't you can a service agent on this ASAP?
Nov 26, 2016 | Refrigerators
Water under fridge sometimes
You may want to remove all the food, unplug your fridge, and the out the whole thing...melting the ice and cleaning out all the unwanted water. The drawer will be removable, and you can dry under it. Also check the overflow tray under the fridge, if there is one...it'll be full from all the melting.
Jan 24, 2014 | Whirlpool GX5FHTXVA Bottom Freezer French...
I have a Kenmore refrigerator 795690002900 bottom freezer. The freezer is working but the fridge doesn`t work. The temp adjustment for freezer lits up the 6 and 7 will not adjust, the fridge part does not...
Mine bottom freezer 10 or so year old unit did the same thing, problem was the thermal switch ("clicks on") on de-ice circuit was broken. Quick "fix" is to defrost the unit by shutting it off, putting frozen food in a cooler. Once the ice melts the path for blowing cold air UP to the frige will be opened. Will work fine for days until the freezer ices up again.
Most likely the "clicks on" or thermal swithch that is bad and will not let the defroster heater work. Easy fix. Everything is BEHIND the pull out frozen food tray. Remove a couple of screws and you will see all the ice. If I remember correctly my clicks on was just to the right of center and took only 5 minutes to replace after defrosting the unit.
Hope this helped,
Ken C
Apr 30, 2012 | Kenmore 71279 Bottom Freezer Refrigerator
My refrigerator was recently working perfectly but was moved to an unlevel area. It is on the coldest setting for the refrigerator and the freezer. We are experiencing a lukewarm refrigerator and food...
Here is a tip that I wrote on moving refrigerators...if you did not do it thisway then you may well have ruined a perfectly good refrigerator.
Moving a Refrigerator What is thebest way
If you already have moved it wrong, you can sometimes get it working byplugging it in and unplugging it a number of times with an hour or so inbetween.
heatman101
Jul 01, 2011 | Amana ARB2257C Bottom Freezer Refrigerator
When I was chipping the ice out of the freezer I struck something built into the bottom freezer tray. All I hear now is air blowing. Did I only ruin the freezer or is the whole frig. toast? I only use it...
Hello and Welcome to FixYa!
Try switching off the unit for some time and turn it On... Check for the working of the unit..If it works properly then you don't need to worry... If not then the unit needs to be diagnosed/repaired if required...Don't worry...There should not be anything like ruining the complete unit or something. Just the fault needs to be diagnosed if any such occurs.
Best of Luck,
Concerned,
Sep 17, 2010 | Avanti 498YW-1 Compact Refrigerator
I have a 19-year-old Kenmore top freezer refrigerator (model #1069610513). The freezer seems fine, but the fridge is warm. It was fine last night but when I opened it this morning the milk felt like room...
You might be developing an ice dam in the bottom tray of thr freezer that is obstucting the flow of cold air to the refigerater part of the unit. remove frozen items so you can see the bottom tray and see if you notice an exccesive amount of frosting on said floor tray, if so you are probably experiancing a defrosting problem.Check to see if you can feel cold air coming in from the top back section of the refrigerator. There is a fan that blows across the coils in the freezer section under the floor tray, if you cant feel the air either your fan has quit or you are froze shut.You can try a temp fix by removing food items to a cooler with ice or another unit and unplugging this one and letting it thaw out, be sure and put down a towl or two on the floor the tawing ice will go to the evaporater tray underneath and overflow once its thawed plug it back in and let it cool down. Check again to see if you can feel air in the frig. if you cant your fan has quit, you need to seek local appliance tech help they should be able to get you going for a fairly inexpencive amount.
Jul 12, 2009 | Kenmore Refrigerators
Kenmore Refrigerator Mod 70162990
It is under the evaporator you will have to remove the back cover... let me know if you want to do it and I will step you thru it...
Sep 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I...
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I have also turn the buttons off and on inside the fridge.
Feb 21, 2008 | Zanussi ZX97 / 5 Bottom Freezer...
Maytag MSD2656G Side by Side Refrigerator Logo
117 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
