Question about Refrigerators
Fridge warm I have a GE. the freezer works but has frost build up on the back (inside). the refridgerator section is warm
  • 1,543 Answers
The frost build up is blocking the flow of cooling air from reaching the refrigerator section. If you take the cover off the frosted area and melt the frost off with a hair blower your refrigerator will work fine for a few days to a couple weeks, and then the problem will show up again. You need to determine why it is not defrosting by itself. You do not list the model number or even an aproximate age of your unit, so I can not be very specific with a solution. Test the defrost heater and then look at the defrost control timer. Also, look for any signs of air leakage into the refrigerator, such as a poor gasket (look at the bottom of the fresh foods gasket in particular) or a dispenser area if your model has a through the door ice dispenser.
Posted on Jun 21, 2009
My Model #gts22wcp fridge stopped getting cold. freeezer works great. Only blows cold air into fridge if freezer door is open.
Possibly a problem with the defrost system. If the cooling coils behind the freezer wall start to build up too much frost or snow, the air flow to the refrigerator section gets blocked first. So the freezer still works but the fresh food section starts to get warm . As the frost continues to build up, in time the freezer section will only get as cold as the fresh food section should. There are 3 main parts to the defrost system. You could have a burned out defrost heater, a bad defrost timer, or a bad defrost termination thermostat. The heater is located directly under the cooling coils in the freezer. The termination thermostat is a silver round disk clipped to the top of the same cooling coils, and the timer in located in the control panel in the fresh food section.
Apr 02, 2016 | GE Refrigerators
GE gs22jepacc side by side refridgerator
Typically a frost build up would indicate a low charge. Partial freezing as evaporation happens too quickly in part of the circuit. Check the charge.
Nov 16, 2013 | GE Refrigerators
Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
42'' monogram getting very hot between doors and in unit above
This is typical for frost-free refridgerators/freezers. In order to keep ice from buiding up on the interior walls of the freezer section, the manufacturer installs electric defrosting elements and extra "warming" elements in the outer edges of the cabinet, normally around the door openings to help mitigate any frost/ice build up and surface condensation that typically occurs on the exterior surfaces as the doors are opened and closed frequently.
These edge warmers stay very warm to keep ice and condensation from accumulating and will become VERY very warm (hot) when the fridge/freezer is in the once a day defrost cycle.
Unless you have an energy saver switch (GE trademark) inside the fridge section, which you can turn off, there is no way to disable these added elements. If you find that you're getting ice building up in the freezer, you'll need to turn off the energy saver switch to resolve that issue.
Energy Saver switch "ON" means these elements are off, while having the ES switch "OFF" means those heaters are running all the time and costing you more in energy consumption
Jul 13, 2009 | GE Refrigerators
GE regrigerator not cooling or freezing
first defrost it by turning it off for 1\2 to 1 full day,put towels on the floor to catch the water,when a refridgerator gets frosted up it cant circulate the cold air,and if its one with the freezer on top then the cold air cant blow down into the refridgerator,check inside the refridgerator at the top where the thermostat cover is there will be a vent hole,it could have ice built up so much that its totally blocking the air flow.This usually happens when hot food is put in the refridgerator and causes steam,or the refridgerator runs too much caused by bad door seals,or the cooling fins on the back or bottom underneath plugged with dust and the freon gets too hot causing condensation inside the freezer which causes it to frost up,a plugged drain hole will back up water and freeze,the fan in the freezer may have stopped working,which is about a $60.00 part,and finally a bad defrost element (about a $40.00 part)which is a glass tube inside the freezer with a coiled up wire inside it that heats up at certain times to defrost any ice build up,(which is the last thing to check)
May 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge Fridge not cooling
Make sure that the light in the ref side is not staying on when the door is closed. Could have a bad door switch. Probably have a defrost problem in the freezer. Check to see if there is a lot of frost build up on the inside/back of the freezer. If there is then you have a bad heater or defrost thermostat or a bad timer. Also another possibility is make sure the freezer fan is working. If there is no circulation of air then the fresh food side will get warm. Then replace evaporator fan motor.
Apr 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Fridge not cooling
is the freezer fan running?is there any frost in the freezer?can you pull the frig. out and see how hot it is?is the comp. fan running?is the comp. clicking on and off,let me know what you find-mike
Nov 07, 2008 | GE Refrigerators
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refridgerator freezer GE
Frost is due to outside air leaking into unit. Check on back wall to see if hole for ice maker fill tube is still plugged. If not and you have no ice maker cover hole with tape. Also look for water or ice build up in bottom of freezer or ref. sections. May have a plugged drain. Let me know what you find.
Nov 11, 2007 | Refrigerators
Frost in freezer compartment
It is possible to get this build up in the return vents.  Check seals for any possiblilty of warm air getting into the fridge.  Warm air getting in will cause this.  For now use a hair dryer or some hot water to clear the vents.  Let me know what you find.  Would appreciate a solved rating for expert advice.
Oct 17, 2007 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
