Question about Compaq Presario R3000Z Notebook
Compaq Presario 1500 T notebook Hdd boot problem...I think so...WHEN I START MY NOTEBOOK I GET THE "OPERATING SYSTEM NOT FOUND" MESSAGE...I TRYED TO INSTALL WINDOWS XP BUT IT DOESN'T SEEM TO FIND MY HDD.I HAD THE PROBLEM A FEW TIMES, BUT I MODYFIED THE BIOS SETTING FOR THE HDD AND IT WORKED FOR A FEW TIMES...I LOADED SYSTEM DEFAULTS FOR BIOS AND STILL NOT WORKING...I DON'T WANT TO BUY ANOTHER HDD, SO WHAT SHOULD I DO?IT'S A LITTLE BIT ODD CAUSE I DON'T THINK THE HDD IS BROKEN...THE BIOS SETTINGS ARE CORRECT...THE WINDOWS THE SAME.. I DON'T HAVE VIRUSES...AND THE SLOT OF THE HDD LOOKS INTACT...COULD IT BE A "BAD" SECTOR ON THE HDD?PLEASE I NEED TO GET IT FIXED!SO GIVE AS MANY SOLUTIONS AS U CAN!
  • 1 more comment
  • Rusquez Michel
    Rusquez Michel Nov 03, 2007
    i don't think it is a software problem...i need someone who knows much about hard disks...
  • Rusquez Michel
    Help? Anybody....
  • Rusquez Michel
    Rusquez Michel Nov 14, 2007
    well f**k u man, F**K U!!!!!!!!!!!!!
Use the original cd for the seller it is OEM windows it is only the version which will be installed even you buy new HDD or original windows CD
Posted on Nov 03, 2007
Compaq presario 2594 us laptop , after boot-up get message ( operating system not found) tried recovery disc, will not formate hdd , will get this message in windows set-up , SET-UP...
I've gist had the same problem after flashing bios ...
go to BIOS and change the SATA mode to IDE. it worked for me.
original instructions:
also You have to turn OFF (disable) the boot from network. The error your seeing is result of the network boot rom not finding PXE server to boot from. Again, be sure to disable boot from network.
PLUS it seems if only 128 MB is showing as memory then the memory sticks might be damaged and not able to retain information/data to complete the installation process. Best take them out clean it properly & replace & try again. Nothing to do with BIOS!
Jun 11, 2011 | Compaq Presario 2594us Notebook PC...
Can you give me any tips on how to start up my computer when it's saying operating system not found?
  1. Check the system setup, see if the hard disk drive is seen and identified in the bios. If not, reset defaults and see if it ID's
  2. Reseat the HDD, if #1 doesn't work
  3. If the HDD is seen, and Identified, but the system will not boot, then there may be a HDD problem. Run diags on the HDD< see of you get a failure. If you do, replace the HDD.
  4. If the drive passes diagnostics, then try booting to your Windows CD, press R for Recovery console (If XP, Choose Repair my Computer for Vista/7) run the command CHKDSK /R if XP
If that fails, then try a repair install of Windows, info can be found here:
http://www.fixya.com/support/r3874510-find_information_windows_installations
Jan 12, 2010 | Compaq Presario 1692 Notebook
Compaq presario 2100 laptop operating system not
On my Compaq Presario Windows 7 laptop, I have got "Operating System not found" error, to fix problem,Windows Boot Genius helped me finally!
Oct 10, 2009 | Compaq Presario 1692 Notebook
OPERATING SYSTEM NOT FOUND MESSAGE
HI,
This can be an issue with the hard drive..
Go to bios by tapping F10 while the system boots > go to diagnostics and select hdd self test.
If it given an error "No IDE device found" then try reseating the hard drive. i.e. take it out and put it back in.
Otherwise try changing the boot order by going to advance / system configuration > select boot order > select the hdd and pess F6 till it goes to the top. Press F10 to save and exit.
Hope this helps..
Regards,
Anup
Apr 08, 2009 | Compaq Presario 700US Notebook
Operating system is missing is the message shown on my dell
Boot to the F12 menu, see if you can boot to the HDD diagnostics. If not, boot to the Dell Resource CD, run the HDD diagnostics from there. If Diags fail, replace the HDD. If they pass, boot to the Vista DVD, then run a repair of the operating system
Apr 07, 2009 | Dell Vostro 1500 Notebook
My HP Compaq Presario v2000 has new mobo, new CPU
You probably put more than a pin-head size drop of heat grease compound on CPU, thus "bleeding" over on the CPU, effectively overheating processor (very common). In any event, your problem is overheating -that's *the* place to look for now.
gurutim
Mar 18, 2009 | HP Compaq Presario V2000 Notebook
Computer loads operating syatem not found
http://forums.lenovo.com/lnv/board/message?board.id=N_Series_Lenovo_3000&thread.id=10549
Feb 23, 2009 | Compaq Computers & Internet
Compaq presario v5000
Boot into Setup and run the TOOLS / PRIMARY HDD TEST / SHORT TEST.
If it fails, try another HDD.
If OK, verify Boot Order is Floppy, CD-ROM, HDD. Exit Setup.
Print Table 1 Low Level Format instructions from http://support.microsoft.com/kb/106419
Boot with a DOS disk that contains Debug. Run the Table 1 script. Turn V5000 Off.
Boot with the HP Operating System CD. XP install should now proceed normally.
Good luck.
Sep 12, 2008 | Compaq Presario V5005us Notebook
Compaq presario not working
This generally indicates hard drive failure. Try reinstalling your operating system, if you have any problems during or after the install, then the hard drive will need to be replaced.
Jul 08, 2008 | Compaq Presario V4000 Notebook
HP Compaq Presario V6000T
what you need to do, is go into the Bios. usually F2 at setup.
Or esc or delete. you have to press a few times at bootup.
Once in the bios screen, find the page where you can change the boot sequence. it,s probably set to boot from HDD( hard disk ) set it to boot from CD/DVD first then FDD Or HDD second.
when you save and exit, it will boot from the dvd drive, this will give you access, to use the cd drive first.
then re-install your operating system.
Mike @ compurepair.
Apr 04, 2008 | HP Compaq Presario V6000T Notebook
Compaq Presario R3000Z Notebook Logo
382 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
