Question about Craftsman Garden
My lawn moer wont start even if pull it a millon times
I just need to now if i can fix it or not
  • Dwain Pippen May 11, 2010
    Maybe...but we need more info. What is the model number of the ENGINE, not the number on the body. Should be around the sparkplug stamped into the housing. It will have... Model-Type-Code, assuming it's a Briggs and Stratton. Have you tried taking off the air filter and squirting a little gas in the carb then try to start? If not, try it and see what happens.
  • 84 Answers
Also if briggs and stratton try adjusting the fuel-air ratio.
Posted on Jun 24, 2009
Tucomse moer 5.5 Won't speed up when cutting tall grass.
These push-mowers have a limited power, when you hit tall grass there is much more resistance on the blades. Even higher power riding mowers can stall on tall grass.
Aug 04, 2015 | Garden
It there a timing mark for a toro lawn mower gts195cc?
Usually there is not. The timing is through the flywheel that connects to the crankshaft and it is permanently set with a woodruff key. When evereything is tight, the timing is good. IF you hit something and cause the blades to stop, the flywheel can move and twist on the shaft and bend the woodruff key. The engine then wont start or will backfire etc. To fix this you need to pull the flywheel off the crankshaft and replace the woodruff key and reinstall it.
Mar 31, 2014 | Toro Garden
I have a poulan 6.25 self propelled mower that wont start soun like its not getting fire
First make your kill handle is pulling your cable all the way back.Sometimes the cable will rust or even break inside its sheathing. to test take a peice of wire and tie it off by pulling the arm all the way back then start it. If that works replkace kill cable
Jun 17, 2012 | Poulan Pro 22" Self Propelled High Wheel...
My yard pro lawn mower will not start, when i try to pull start it the crank rope vets pulled back sometimes
Two things to check here, check the blade is tight, it acts as a flywheel so needs to be tight, second, check the flywheel key has not sheared as this will cause the engine to kick back as the timing will be out.
Apr 25, 2012 | Garden
When engaging the moer it doesnt want to start
The tractor has a safety feature that doesn't allow you to start the engine with the mower engaged. Just disengage the mower, then start the engine. Once you have it running, then engage the mower.
May 21, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Need a manual!
Go to searparts.com and type in your model
Jul 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Pull cord all the way out, and will not recoil
I started to take mine apart but when i loosened the 4 screws on the yoke the string rewound so ive been running it like that.
May 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Pullstring pulled back...HARD..to engine
You have a partly sheared flywheel key that is making engine out of time replace flywheel key
May 06, 2009 | Mtd 22" Yard Machine Push Mower
How do you start the lawn mower on imagine babyz nintendo ds?
Put the stylus on the red ring and make short quick strokes to the right. With each stroke you will see the cord pull out and the ring will turn green. I did this about 30 times, then finally i used my finger instead of the stylus and is started up on the third try.
Dec 22, 2008 | Nintendo DS Lite Console
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Mike Squire
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
