Question about Kenmore Refrigerators
Refrigertor run alot
My refrigertor seems to be always running. i had the seals replaced
    Sergeant:
  • 212 Answers
Check to see if you have frost build up on rear wall of freezer section. you could possibly be low on freon
Posted on Jun 21, 2009
My water lines always have air in them, alot of air! I do not get alot of water, The pump seems to run along time with, no results. I have an old piston pump, the repair man that was here removed the jet...
Is there water visible in the well,or do you have a point ,nonetheless if the pump is running for a long time,then there is not enough water,or the suction side of the pump is drawing in air ....the pump will suck in air easier than pulling water up into the pump,the suction side cannot leak at all !!! If you have a foot valve it may be faulty also !
Good luck
Feb 22, 2015 | Garden
My Kenmore elite Freezer runs quite alot, and the fan continues to run even when the door is opened...what is wrong?
Sounds like the seal around the door is damaged or deteriorating and needs to be replaced to make a tight seal. ~Denise
Jul 04, 2011 | Kitchen Ranges
I own a Mayatg mah6700aww washer. The ring that seals the door to the washer has an area at the bottom that seems to have been bent somehow, it's not ripped or torned, just kinda warped. That area on the...
best place would be marconeapplianceparts they are not only one of the biggest appliance parts manufacturers they seem to be alot cheaper then most others u can actually look at this link under door and tub front to get an idea how to change basicly the metal ring on the outside of the door you would have to disconnect but also you have to remove the front panel as well to reseat the rubber boot back on the tub and yes the seal most definetly has to be replaced if you have any further questions please message me back and please remember to rank this opinion votes are always good to lol thanks again Rick
Dec 13, 2010 | Maytag MAH6700AWW Neptune Front-Load...
I have a 1998 Pontiac Sunfire coupe. The car runs amazing has alot of get up and go but the transmission seems to slip alot while making turns, or at complete stops. it does leak fluid alot. I'm curious as...
it sound to me that the tranny needs to be resealed that the seals and gaskets are worn. There are many places the tranny fluid can come out of like where the front axles go into the tranny or the front seal or the pan gasket
Sep 02, 2010 | 1998 Pontiac Sunfire
Fan in the freezer of refrigertor runs all the time is it suppose to?
Hello there:
Yes the fan will always continue to run to allow for the air to be circulated in the freezer compartment
If this fan is not running
than this will need immediate attention to prevent further problems with the appliance ok
Hope this is very helpful for you
Best regards mike
Aug 01, 2010 | Avanti FF1101W Top Freezer Refrigerator
1995 kx 125 rattling
seems like somethjing foreign could have been forgotten in the transfer case. this most likely is causing the rattle, when the viberation from the motor reaches a certain pitch or frequency.. best to have it checked by a pro...
Nov 12, 2009 | kawasaki KX 125 Motorcycles
Hot
check to see if the fan at the compressor is running
Jun 17, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
On warm DAy My Refrigertor Dont Work I lost Food 2 Times But it stay running
You don't say how old your unit is, so I will give you some things to look for.
1.Condensor coils must be kept clean. Inspect and clean if needed.
2.Door seals MUST be sealing tight so warm air does not enter the unit. Heat moves toward cold, so any void in the door seals will cause food loss.
3. Controls should be set fairly equal to each other, too much of 1 control over the creates unstable temp.
4. Limit door open times, get in, get out! Think ahead about what you want out of the unit.
5. Observe the compressor run time, if it's running continually, then you need to investigate the above issues. If no apparent cause is found, then you may have a weak compressor
Please rate this advice on helpful my answer was in resolving this issue.
Thank you.
Dave E. (Illeagle).
Jun 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
