Question about Mountain Plumbing Mountain The "Little Gourmet" Heating Tank MT641
Leaking braided water line from under spout LITTLE GOURMET
HI
JUST installed LITTLE GOURMET hot water dispenser and its leaking under spout from one of the braided water lines. are the water lines thread in to the spout? can i just replace the water line if i broke it,. or i must replace the whole spout.
thanks
  • 332 Answers
You will have to get a replacement from the manifacture,, they will send it to you, call them tell them wich one it is hot or cold they may have diffrent threads then again they may be the same,,,can you get the threaded part out of the faucet, you will need an extractor, you can get this at a hardware store, it has a rubber seal so you can only tighten it so much, get it ot try again but be gentle,, one thing I found after doing plumbing for 34 years if you snug it and it leaks you can always snug it some more if you over tighten it you can't do anything but replace it,,,, good luck let me know how it goes
Posted on Jun 23, 2009
Sunbeam hot/cold water dispenser is leaking from looks like copper tubing that goes to tank. Model # ylr-5-87h3 what could my problem be
Broken solder connection.
Continual expansion and contraction of metal due to hot and cold extremes will cause metal fatigue. The most vulnerable place is at the join. Other places can fail, but usually the solder join will fail first.
Buy another one and support economy.
Make sure next unit is connected to cold water line, and not hot water line. If hot water dispenser is connected to Hot line, then it will cause water heater to run each time water is drawn through dispenser because cold water immediately enters tank.
http://waterheatertimer.org/Water-heater-dip-tube.html
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html#h-c
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#pot
You might also consider installing small tank under counter. Tanks are less glamorous than hot water dispensers but tanks are more reliable long term than instantaneous water heaters.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 28, 2013 | Water Heaters
Leaking water tank on Insinkerator hot water dispenser
Jan 2013
1) If the tank is leaking, then Replace with new dispenser.
2) Add comment and attach photo of leak.
Jan 23, 2013 | Emerson InSinkErator W-152 Hot Water...
Our little gourmet dual hot/cold faucet has just started to gurgle out hot steaming water all day without use. The complete faucet is burning hot. Unit is 4 years old and used frequently.
having hot water trickle out all day will make the whole unit hot,, to the touch,, what you need to do , is turn off both the water supplys under the sink,, then remove the handle by removing the hold down screw,, after that , remove the hot water valve,, Just remove the nut that's on the outside of the fixture, what your going to find is at the end of that valve, is a washer,, made of hard rubber,, that needs replacing,, but also, inside of the fixture is a washer seat, its either brass or stainless steel,, that takes a seat tool wrench to remove that ,, but to make sure its repaired completely, both the washer and seat need to be replaced, seat tools are pretty inexpensive at Lowes , or Home depot,, and thats where you can get the parts you need also,, be sure and compare the old parts with the new, so take them with you when you go, most hardware stores that have plumbing supplies will have what you need, the seat just unscrews , but they can be a little tough,, if you decide to get a seat tool, they have straight ones and 90 degree ones ,, the straight ones you'll need a wrench to assist turning in the removal and install,
Aug 26, 2011 | Mountain Plumbing Products Little Gourmet...
My hot water from the Mountain Plumbing hot water dispenser has a lot of white pieces in it. Has the tank failed?
No attack on this scale is heating element that dissolves when it is possible to disconnect apperaat water heating and draining than doing it in vinegar and let the heat once again connect and then empty and most calcium is removed from apperaat
Nov 08, 2009 | Mountain Plumbing Mountain The "Little...
Leak from hose that connects MT641 Heating Tank to Dispenser
It may be a push n lock. If you can send a pic of your phone vam, send one and we can see what's needed. Co7196@yahoo.com. If its a push n lock, While pushing on the line push in the smaller inner sleeve and pull on the line. Make sure there is not pressure in the line.
Sep 22, 2009 | Mountain Plumbing Mountain The "Little...
Leak from hose that connects the dispenser to the tank
the temp is to high and it is just a neoprheme hose go to the hard ware store and purchast a new hose the samt size 3/8 re install it and trun the temp down on the unit, make sure the hose you get has at least 140 degree rating
Dec 26, 2008 | Mountain Plumbing Mountain The "Little...
Little Gourmet Hot water tank leaks out small hole in tank bottom
this is a condensate line and suprising enough most of the plumbers I go back after never hook them up they should have a hose off of them and led to a discharge area, if this is actually on the tank you will need to drain it and remove it and reseal it,
Dec 19, 2008 | Mountain Plumbing Mountain The "Little...
InSinkErator Instant Hot Water Faucet leaking from heater unit model #GN1100
Make sure that there is no leaks traveling down the hoses or at the connections on the top. The tanks can leak, if you have the Stainless Steel tank the following information applies - Stainless Steel Tank: 3 years, with an extended service plan available when installed by an InSinkErator Pro Circle™ plumber. I you product is under warranty I believe that you can call the number that is printed on the tank and literature.
Dec 04, 2008 | Mountain Plumbing Mountain The "Little...
Mountain Plumbing Mountain The "Little Gourmet" Heating Tank MT641 Logo
195 people viewed this question
Top Mountain Plumbing Water Heaters Experts
Bill Boyd
Paul Carew
David Spradling
David Spradling
Are you a Mountain Plumbing Water Heater Expert? Answer questions, earn points and help others
