Question about Maytag Neptune MAH5500B Front Load Washer
Loud noise my machine sounds like it is ready to take off.. I think ots going to screech to a holt and die pretty soon, works fine though,
  • mw repairs May 11, 2010
    Noise will eventually cause serious damage. Yes it will screech to a halt and die. Either bearings are worn out (GE) or something is stuck between the two tubs. Would have to know the make to solve further
    Sergeant:
  • 187 Answers
Try following:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
pls rate my suggestion
Posted on Jun 21, 2009
Loud ticking noise coming from rotating drum
Most certainly not worth the repair cost. You can get a new VCR for about 25 dollars. If you take it apart you will be able to see what is going on inside to cause this. I am thinking a belt is off or ready to break.
Mar 15, 2014 | Panasonic PV-7661 VCR
When I play my Toy Story 3 blu ray it is fine audio wise to start with but as soon as the film starts there is a very loud screech and distortion noise. This doesn't happen to any other blu ray we have....
it's a problem with the player's firmware, try hitting the audio button on your LG remote twice. i think it defaults to 7 channel sound, you can also try the sound settings on the DVD. had the same problem with my toy story 3.
Apr 04, 2011 | LG BD350 Blu-Ray Player
Our tv is Samsung DLP HL-P4663W 46 in. Rear Projection HDTV-Ready Television After having our TV on for about 45 minutes it starts to make this hissing sound which starts low and gets louder and louder,...
hello
This looks like a colorwheel symptom, does the sound is like a mechanical sound? high pitch sound? winding, whirling or screeching noise ? well if this is the color wheel, what i think it is, it seems that it is not working properly when this happens the DMD board recognizes that it is not spinning at the correct RPM and turns off the Tv for sercurity reasons, so if you want to replace this yourself what i recommend you to do is to open the back of the Tv and search for the colorwheel it can have missing parts or it could be shattered or it could not spin correcty, hope this info. can help you.
Jun 14, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Washer makes a loud, pulsing, screeching noise with no spinning
With a manufacturing date of 7/15/97, your washing machine is clearly worn out.
Nov 07, 2017 | Whirlpool Washing Machines
Fisher Paykel Gw11, leaking, loud noise, not going through cycle
pump is a common fault and easy to change for about $25. all sound related. new machines are pretty inexpensive. your call
Aug 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
My mustang is smoking and making a screeching sound.
You have a Bad Belt Tensioner and will need a new one and Possibly a new Belt. Have the Alternator Checked also. It could have gone Bad during these Problems. If the Tensioner is Not keeping the Belt very Tight it will not allow the Alt. To charge the Battery and it will drain very fast.
Jan 25, 2009 | 1990 Ford Mustang
Loud spin cycle
OTHER THEN CHECKING THE WATER PUMP I THINK YOUR RIGHT THE BEARING ARE GOING,IT WILL WORK FINE TILL THEY LOCKUP THEN THE BELT WILL BURN OFF,BUT I WOULD CHECK THE WATER PUMP ALOT OF TIMES IT JUST THAT,LET ME KNOW -MIKE
Nov 03, 2008 | Frigidaire FTF530ES
Maytag Neptune MAH5500B Front Load Washer Logo
139 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
