Question about Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka 4870: Brush roller turns even in hose setting.
The brush roller continues to turn whether the setting is for floors or hose.
You either have the wrong size belt, most likely too small, or you have installed a new belt incorrectly. When you open the cover on the bottom of your vac, you will see the pulley that moves as you flip the switch from floors to carpet. The belt does not go around this pulley. When activated(carpet) the pulley puts tension on the belt causing it to turn the roller. When switched back to hard floors, the belt looses tension allowing motor to cause suction but disabling roller. Also, the dial on top of vac is only to direct suction, not for disabling roller
Posted on Aug 25, 2009
Roller brush spins
The roller brush will turn as long as the sweeper motor is running no matter what brand you have. Turn it off as you return it to the upright position.
Dec 29, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka 4870 brush won't stop turning in upright position
there will be a linkage that as come loose and not operating the limit switch to turn it off, try looking at 23. Idler Clamp Assembly on the link below.
http://www.vacpartswarehouse.com/Eureka-4870-Ultra-Smart-Vac-s/1928.htm
Jan 27, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
I got a cord wrapped around the roller, and now neither the roller nor the suction work...only hot air coming out the top of the base.
To unrap the cord from this vacuum you will have to do the following:
First turn the vacuum upside down and place head on counter and handle on the floor. You will have remove the base plate. There are 3 screws that hold it in place. Since cord is wrapped around the brush roller you will not be able to take it all the way off, but it will give you access to the brush roller. If the belt is still on the brush roller, I suggest you cut it, so you can lift the brush roller out of the base and that will make untangeling the cord easy. If you need a new belt here is the info on that.
Style "R" Extended Life. Eureka Part #61110 - Free Shipping Style "R" Extended Life cost is $ 9.99 for one
Apr 29, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
Change the belt
Hi There,
Here's how you can replace the belt on your Eureka SmartVac 4870. I have taken pictures of the repair to help you better with this.
Here's what you'll need in order to complete this repair:
- Eureka Style R Extended Life Replacement Belt, Part 61110
- Eureka SmartVac Model 4870 Roller Brush Assembly, Part 61520 (Only if the brush no longer spins, or the brushes are worn out)
- Phillips head screw driver
Step 1. Turn the vacuum upside down so that the brush roller is facing upwards. Unscrew the three screws that I've highlighted in red.
Step 2. Remove the bottom plate after unscrew the three red highlighted screws. Once you remove the bottom plate, you'll have full access to the roller brush and belt area. Remove the roller brush by pulling straight up on the roller brush itself. Discard old belt, and test roller brush to ensure that it spins freely by holding the very end of each side, also called the bearing caps with just your finger tips. Try spinning the brush with your thumbs. The brush should spin several times around with each spin. If you notice the brush doesn't spin at all, or if you feel some resistance when you spin the brush, this means that your bearings are either gone, or will be soon. It may be time to consider a new roller brush at this time.
Step 3. Remove the new Eureka Style R belt from the packaging, and wrap one end around the the metal pin, on the opposite side of the roller brush. This pin is actually the motor shaft that spins the belt, which spins the brush.
Step 4. Wrap the other end of the belt through the side of the roller brush that has the pulley, and use the roller brush to stretch the brush roll back into the agitator housing. Make sure the end caps fit in the housing correctly by making sure there are no gaps between the roller brush housing and the end caps of the roller brush.
Step 5. After reinstalling the roller brush back into the housing with the belt attached, pull the belt forwards towards the brush. The brush should spin when you do this. Make sure that the belt is not pinched underneath of the roller brush or this will cause the belt to break immediately when you turn the vacuum back on.
Step 6. Reinstall the bottom plate, making sure that the little notches on the front end of the bottom plate tucked underneath of the reverse notches on the bottom housing of the vacuum cleaner. Tighten all 3 screws back into the bottom plate. Make sure the vacuum is set to carpet mode, and turn the vacuum on.
If you have any questions about this repair, or if you notice that the roller brush stops when the brushes hit the carpeting, please just use the clarification request form here on the Fixya repair page. I will then be happy to walk you through a little more advanced repair of replacing the clutch in the Eureka SmartVac that controls the rug/floor switch. Most of the time though the belt will be all the vacuum needs.
I hope that this was helpful information to you. If this helped you, please be so kind and rate the repair as helpful by clicking on the thumbs up icons in the top corner of this repair.
Thank you very much,
Chris J.
GoVacuum
Apr 04, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
4870 roller part number
I know the belt number
Eureka Part Number: 61110B (Replaces 61110, 61110A)
And the roller i think: Genuine Eureka Brush roller part number 61250-3 for Eureka The Boss/Smart vac/smartvac ultra 4800 series vacuums including models 4870 and 4880
Hope this helps you.
Jan 03, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
My Eureka The boss Smartvac Model #4870 roller brush won't turn even on the highest setting and the belt smells hot. we took the belt off. How can you tell if it needs replaced?
Just by what you explained I can tell that it needs to be replaced. The belt doesn't have to be broken to need replacing, if it is stretched and worn then it will slip on the motor shaft and not turn the brush roll and get hot. Here is a link to the belts you need and the manual which has instructions:
Bissell 4870 Belts
Owner's Guide (3,666K download)
Dec 11, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Brush roll continue to turn while the vacuume is in the upright.
Check to see the bare floor switch is fully engaged and the vac hose is in its socket as well
Sep 06, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
New brushroll for eureka smartvac 4870; bristles too long to turn
HI Don't forget that you have a height adjustment control so its better to put it in the highest position - if this is not allowing the roller brush to move properly on the carpet then switch the vacuum off, and lightly trim with scissors on the brush lines. Avoid cutting everything down though - a slight trim should improve things. Generally though when brushes appear too long its usually because the height adjustment dial hasn't been set upwards.
Mar 27, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
In Carpet setting, the vacuum brush does not spin
I put 3 turns of electrical tape around the area of the beater bar that meets the vacuum belt. This solved the problem short of replacing the beater bar.
Jan 18, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka Smartvac 4870 Bagged Upright Vacuum Logo
636 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
