Question about LG LRSC-26922 Side by Side Refrigerator
Ice cubes that accumulate in the basket are all fused together. I have to use an ice pick to break them up. My old refrigerator didn,t do this. This one is a Samsung with the freezor on the bottom and electronic controls on the door.
  • 614 Answers
Try truning your freezer colder. Had same problem with my Hotpoint. But empty ice at least twice a year if you dont you it often because they will stick together from opening and closing the door. Rus
Posted on Jun 21, 2009
What causes ice maker malfunction?
you could try cleaning the ice bin first of all the accumulated ice cubes that are all sticking together at the discharge side of the bin. thanks.
Mar 04, 2016 | Kenmore Refrigerators
What causes my ice maker to drip water?
HI,
This could be either the ice maker is old and the finish inside has depleted, the water valve is going bad or you had a jammed ice cube and now it overfilled. Many different reason this could happen. Does the ice cubes stick together with a bridge? Is the drip coming from the ice maker head unit? How is the ice in the pan its stored in, stuck together? In the pan, has the ice glaciered together? Need more information please. Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 09, 2014 | Kenmore Top Freezer Refrigerator
Why would my ice maker start freezing all my ice cubes together?
ice maker made cubes, but you shouldn't put in freezer any warm staff, its melt ice for while after freezing them together
Jul 29, 2014 | Jenn-Air Jenn Air Refrigerator Replacement...
Water is leaking into the ice tray freezing all the ice cubes together
That maybe it or it may be your preception, If the heater in defrost is over heating during the defrost cycle you can get the same results
Dec 17, 2017 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker is not working properly. I noticed that it dumped water into the ice catcher and fused all the ice cubes together. Now it fills but is not producing any ice. We have the freezer temperature...
Feel under Ice maker to see if it is warm. This is a heater that comes on to loosen the ice cubes just long enough to allow the cubes to slide out of their ice slots. The only remedy is to replace the Ice maker model=> D7824706Q Ice Maker Assembly
Please let me kow if this is helpful or if something different may be happing, Thanks, Sea Breeze
Feb 27, 2011 | Maytag PBF1951KEW (19.0 cu. ft.) Bottom...
Ice maker - Ice cubes are connected together instead of one at a time. Can this be easily fixed?
Good day,
By design, the cubes are fused together when they form. The water enters only the rear of the ice maker when it is filling, and flows forward one cavity at a time, thus leaving a small section connecting the cubes together.
In theory, the force of ejecting the cubes, and falling into the bucket causes them to break apart.
It's not perfect, but usually works most of the time.
If the machine or ice maker is not level, it is possible some of the wells get more water than others, which could cause the cubes in one part to be too large and create the problem.
The other possibility, is the water valve in the bottom back of the machine to not close promptly during the fill cycle causing the well to fill too high causing your issue.
A very remote possibility usually associated with homes that use well water, is the water pressure is too high, adding too much water per cycle.
Unlike a cloths washer, the ice maker uses a simple timed fill method which is normally 7 seconds.
An outside possibility exists that it could be an internal problem with the ice maker itself, but I've never seen that as an issue.
Sep 27, 2010 | Maytag Refrigerators
RS267 Ice is not dispensing
The freezer temp is not cold enough, the ice cubes melted and giot welded together and now the motor will not turn, you have to unplug it, wait until it melt a little take the drawer out and get rid of the old ice, clean the tray, and make sure it is completely dried before putting it back in, use paper towel to dry it.
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Jan 14, 2018 | Samsung RS265LABP Side by Side...
GE Monogram refrigerator icemaker problem
This is normal if you have previously used the crushed ice mode. The refrigerator will continue to dispense crushed ice for some time until the reserves are depleted. If this continues for a longer period then shut down the refrigerator and remove the dispenser compartment, clean any remaining ice and reinstall it. Start the power supply and wait 5 hours for the ice to form. Use the cube mode and you will surely obtain ice cubes.
Aug 27, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Ice maker dripping water fusing ice cubes
The dual water valve (solenoid) that open and let the water from the line when the ice maker calls for it, is leaking and needs to be replaced.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice accumulating in freezer
There should be a tube that brings water to your icemaker from the back of the fridge into the icemaker. This tube is frozen with water, or the inlet where this tube feed the icemaker tray is frozen. The result is that water cannot go to the ice maker, and instead, goes over the top of the inlet area.
Verify that this is indeed what is going on.
The fix is to remove the blockage/buildup of ice at the inlet. You may have to detach the icemaker to get to it. Be carefull with electricity! Also be carefull as plastic can break under stress!
The tube may be frozen to the inlet, channel locks can be used to gently twist the tube to break it free.
Good Luck!
Jan 01, 2008 | Samsung RS2630SH Side by Side Refrigerator
LG LRSC-26922 Side by Side Refrigerator Logo
213 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
