Question about NetGear WG111 802.11g/b Wireless Adapter
Not connected showed on my laptop
I just bought NetGear WG111Wireless Adapter,I installed using The CD,but when is completed installing, the picture showed there are no connected with red cross sign on it, when I click to open network connections, it said there are no network range in my area, which I know it has , I'm not IT person, could plz someone guide me with a plain english how to solve the prob .thx
  • 2 more comments
  • jlumenta Jun 22, 2009
    I have the CD alright, I have installed, n it succeed, it just showed not connected on the screen and i couldn't get any network in range just blank, and there is a red cross sign on the network connections bar
    I use XP with service pack 3, or may be because of that the screen showed up so annoying.
    thx
  • jlumenta Jun 23, 2009
    yeah there is "?" mark with yellow collour under the name other devices (PCI modem), do idea what is that mean???what should I do next???is that normal with that sign on it??should I remove or fix something??
  • NinaE May 11, 2010
    What operating system (Windows XP, Vista, etc.) do you have ?
    President:
  • 3,278 Answers
Boot up (turn on) your PC with the adapter removed. After you get the desktop, then connect the adapter to a USB port. You should receive a "found" message and then let the adapter find the device driver (software it needs). If no "found" message, connect the adapter to a different USB port. If still no "found" message, the adapter may be faulty.
I'd also suggest to select Start- Control Panel - System - Hardware - Device Manager and look to see if there are any "?" or other symbols. That would indicate a hardware conflict and you should contact us again for further help. Again, if no symbols, the adapter is probably faulty. Good luck.
Posted on Jun 22, 2009
  • 1 more comment
  • NinaE Jun 23, 2009
    Normal
    0
    OK.
    In Device Manager ... Right-click on the PCI Modem and select
    "Disable". Reboot and try the NetGear Wireless Adapter again.
    Remove: "Normal O" from my post.
  • NinaE Jul 02, 2009
    Resolve your problem ?? Thanks.
  • 1,272 Answers
Download the latest adapter driver for this adapter from the link below:
http://kb.netgear.com/app/products/family/a_id/1268
Install the adapter using thesr drivers and check if that helps.
  • Anand Gupta
    Anand Gupta Jun 23, 2009
    This has nothing to do with the yellow sign on the PCI modem.
    Are you aware of the security encryption being used on the wirless network and the passphrase. if yes, then follow the steps below to configure the wireless connection:
    1. Right click on My Computer icon and go to Manage.
    2. Go to Services then go to Service and Applications.
    3. Double click on Wireless Zero Configuration.
    4. Change the Start Up Type to Automatic and click on Apply
    5. Click on Start and press OK to close the window.
    6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
    7. Right-click on the wireless Network Connection icon and select 'Properties'.
    8. Go to the 'Wireless Networks' tab .
    9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
    Now please perform the following instructions to connect to the wireless network:
    1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
    2. Right-click on the wireless Network Connection icon and select 'Properties'.
    3. Click on the 'wireless network' tab.
    4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
    5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
    6. Look for the SSID (aka Network Name) of the Wireless router or access point.
    4. Highlight the SSID from the list that you want to connect to.
    5. Type the security Key here and click on the 'Connect' button.
    6. You should have successfully established a wireless network connection.
Stuck At Detecting Adapter
Disconnect it, remove any software that was installed and restart the computer. Do not connect the device until you finish installing the device's software or the software installation prompts you to connect the device.
If that doesn't work, here's Microsoft's solution:
http://windows.microsoft.com/en-us/windows-vista/update-a-driver-for-hardware-that-isnt-working-properly
If that doesn't work, go to Netgear's website for support and/or post the problems in the forums.
I hope this helps.
Dec 19, 2012 | NetGear WNA1100 Wireless-N 150 USB Adapter...
Hey. :) My name is Peyton. And me and my Dad have just bought a "NetGear N150 Wireless USB Adapter", And we've looked at the intructions, and we looked it up. But we can't seem to figure out how...
Installing the Software and Adapter
To install the wireless-N USB adapter with custom setup:
1. Insert the Resource CD. If the CD main page does not display, browse the files on the CD
and double-click Autorun.exe.
2. Click Install the Software.
Select one of the following methods to configure and manage your wireless network:
Smart Wizard. Allows you to manage your wireless networks with the NETGEAR
WNA1000 software and to connect securely using Push 'N' Connect.
Figure 1-1
Figure 1-2
NETGEAR Wireless-N 150 USB Adapter WNA1000 User Manual
1-5
v1.0, August 2009
- Configure network manually. Specify the settings for your wireless-N USB adapter
in the Settings screen.
- Configure automatically. Allow the Smart Wizard to automatically configure the
settings for your wireless-N USB adapter.
Windows Utility. Connect to and manage your wireless networks using only the
Windows configuration utility. For more information about Windows utilities, see the
Windows documentation or the NETGEAR application note at:
http://documentation.netgear.com/reference/enu/winzerocfg/index.htm.
See page 1-3 of the manual:
ftp://downloads.netgear.com/files/WNA1000_UM_05AUG2009.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 19, 2010 | Computers & Internet
I just bought NetGear WG111Wireless Adapter,I installed using The CD,but when is completed installing, the picture showed there are no connected with red cross sign on it, when I click to open network...
When you search make sure it shows up "Searching for wireless networks in range" for a while.
If it doesnt and instantly says "no wireless found" is because you have another program using the wireless connections
To solve this simply click
  1. Start
  2. Control Panel
  3. Administrative Tools
  4. Services
  5. Scroll down to "Wireless configuration" or "Wireless zero configuration"
  6. Right-click and select "Start"
then you can search again
Hope it helps
Cheers
Jun 21, 2009 | NetGear WG111 802.11g/b Wireless Adapter
Unable to Get Connectivity
Wireless Adapter Installation
A. Install the software.
Note: Firewall and anti-spyware need to be disabled. They sometimes treat software installation as a behavior of a spyware and therefore will prevent installation.
Windows XP:
1. Please power on your computer. Allow the operating system to boot up completely and log in as needed.
2. Insert the NETGEAR adapter Resource CD into your CD-ROM drive. The CD main page shown at the right will then load.
3. Click the Install Driver & Utility.
4. Please make sure that you follow the Install Shield Wizard steps. Click Finish when done and turn off your computer.
Windows 2000/ME/Win98SE:
Note: Windows 2000 may require you to be logged on with administrator rights.
2. Insert the NETGEAR adapter resource CD into your CD-ROM drive. The setup page will then load.
3. Afterwards, click on the Install Driver & Utility link.
4. Make sure to follow the Install Shield Wizard steps, and click Finish when done to restart your computer.
B. Install the adapter.
Windows XP:
1. Please make sure that you shut down the PC first and then remove the power cord.
2. Please insert the NETGEAR adapter into the available expansion slot.
Note: If you have PCI adapter, connect the antenna to the adapter, making sure the antenna is in the upright position.
3. Reconnect the power cord and reboot the computer.
4. When the Found New Hardware Wizard displays, please click on Next and then follow the prompt. If you are prompted with a Windows XP Logo testing message, just click on Continue Anyway.
5. After the installation completes, click Finish to close the wizard.
2. Insert the NETGEAR adapter into the available expansion slot.
4. On the Found New Hardware Wizard, click on Next, then follow the prompt to proceed.
5. After the installation completes, click Finish to close the wizard. Please make sure that you can see the NETGEAR icon located at the lower right portion of your computer screen.
Note: If Windows displays Digital Signature Not Found warning, click Yes to continue.
C. Configure the NETGEAR adapter.
1. Please Double click on the NETGEAR icon on the right lower end portion of your computer.
Note: If you do not see the icon, click on Start and go to Programs. Locate the NETGEAR Utility and click on the NETGEAR Smart Configuration Utility.
2. Click on the Networks tab.
3. Click on the Scan button.
4. Select the Network Name or SSID of your wireless network.
5. Click on the Connect button.
6. You will be directed to the Settings tab.
7. Type a name for the Profile.
8. The Network Name (SSID) will be the same with your wireless network.
9. Make sure that the Network Type is set to Access Point (Infrastructure).
10. Select the Security that you are using on your wireless router.
11. Click on Save Profile.
12. Click on the Apply button.
Enabling Wireless Zero Configuration Utility
1. Please click on Start, Run and type in services.msc and click on OK.
2. Scroll down and look for Wireless Zero Configuration. Right click on it and click on Start.
3. Right click on Wireless Zero Configuration again and click on Properties.
4. Under the General tab, set the Start up Type to Automatic and Service Status to Started. Then, click on Apply and OK.
Mar 24, 2009 | NetGear RangeMax NEXT WN511B...
Netgear wg111T Wireless Adapter 2.0 connectivity issues
Windows XP:
Windows XP:
Jan 02, 2009 | NetGear WG111U 108 Mbps Wireless USB 2.0...
How can I install a wireless usb adapter WG1111....
First put in the cd that came with the wireless USB adapter. Close the auto setup page(we will use windows wireless network manager which works better with windows firewall . Plug in the wireless adapter and the laptop will automatically install the driver. If for some strange reason it asks you to install new found hardware, follow the promts and install manually and select cd and the directory the WG1111 drivers are located. Press ok and wait for install. Restart the computer.
After restart the computer will come up with a caption New Wireless Networks found. Double click on the wireless Icon in the bottom left hand corner. It will open a seperate screen with all wireless connections avaliable to you. Might be 1 or more networks, depending on whether your neighbours have wireless networks. Anyway find your specific wireless network could be for example NetGear, Dlink, or my home network. Click on connect your wireless connection. Another smaller screen will appear with Key in your password twice( WEP key or WPA key)
Key in your key or password twice and apply or ok. It will connect and close screen.
Restart computer!
After restart the computer will pick up your connection automatically and your ready to go on line. If you move your mouse down to the icon with wireless network in bottom left hand corner it will show your wireless connection in a caption stating the connection name and how strogn signal is. Connection complete.
NOTE: YOU MUST HAVE A WIRELESS MODEM OR WIRELESS HUB CONNECTED TO YOU MODEM TO USE THE WIRELESS WG1111. THANKS!
Aug 02, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Cannot connect to my laptop with a built in wireless.
Windows XP:
Windows XP:
Jul 13, 2008 | NetGear WG111T 108 Mbps 802.11g Wireless...
Hi there, I just bought a netgear Rangemax next wireless router WNR834B with RANGEMAX™ NEXT WIRELESS N USB 2.0 ADAPTER – WN121T with no installation CD and i have connected the router to my modem and its...
Get the driver for the WN121T from the NetGear webset and install it before pluging the adapter into the notebook. Use a wired connection on the notebook until you have the drive downloaded.
Jun 19, 2008 | Computers & Internet
Wireeless
Windows XP:
Windows XP:
Feb 12, 2008 | NetGear Wireless
NetGear WG111 802.11g/b Wireless Adapter Logo
223 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
