Question about Samsung DVD-V5500 DVD Player/VCR
Remote control doesn't work
The unit itself is fine but the remote suddenly stopped working. Obvious things like batteries were checked. While universal remotes I own will operate many playback functions of dvd and vcr, there doesn't seem to be any way to set any of its menu items, like timer recording for vcr or function choices for dvd playback. Any ideas before I replace the remote would be appreciated.
    President:
  • 846 Answers
The only thing that comes to mind is somehow the remote became unprogrammed. This happens with some factory remotes, if you reset the code for the remote it may start working again.
There are other times (both of these Ive had experience with) when the remote will just stop working due to a defect.
Post back for any further help, thank you for stopping by Fixya!
Posted on Jun 21, 2009
I have a liftmaster formula 1 1280R opener that works fine from the wall mount but all of a sudden both remotes and the built-in remote in my car stopped working. It is not the batteries in the remotes. ...
The motor/control unit may have gotten reset. It needs to relearn the codes transmitted by the remotes.
MIne has a "learn" button on the control unit. Press and hold, then press the button on the remote. Lights will flash indicating it has received and stored the code. Release button.
Check to see if the remote works now. If so, all three should be working. If not, dig up your manuals.
Feb 28, 2013 | Sears Craftsman LiftMaster Chamberlain...
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
My KLH 5100 System worked fine for nearly a year. Very suddenly the remote control seems to have no effect on the unit. It doesn't switch it on, or off, or change the volume...nothing. I changed the...
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Sep 08, 2011 | KLH R5100 Receiver
Pansonic NV-HS960 will not accept signal from Remote control
Obvious things first check the battery, check nothing is blocking the signal area. If still no look try another remote, you might have to buy a cheap universal one. If that doesn't work then the remote sensor in the VCR has a fault in it.
May 26, 2011 | Panasonic Televison & Video
Suddenly stopped working, green light on remote works, but no response from car. No locks, trunk, or start.
Could be many things, loose ground or power wire on the 561, there is an inline power fuse on the red wire leading to the control unit that may be blown. It may just need to have the remotes reprogrammed to the control unit, sometimes the control unit just stops recognizing the remotes. If you have recently had the cars battery replaced, or jump started the car, check the fuse at the control unit first.
Aug 17, 2009 | Directed Dei Valet 561r Remote...
Fujitsu air con unit. Remote wont work. has new batteries
Check the micro processor control whether it is in manual mode or not. If not check the sensor whether it is functioning or not. If everything is fine then remote control has to be changed.
Aug 15, 2009 | Heating & Cooling
Volume does not work
check for loose solder and the system ic
Jul 17, 2009 | JVC HD-52G787 52" Projection Television
LE26R74BDX TV Not responding to Remote
there is a easier way to check your remote.
Open your radio on AM frequencies, you don't need to be tuned just noise is perfect, then bring your remote near the antenna and press some button. You will ear the frequency in your radio. If it works this way but not on the TV make sure to press the TV button before using it (if the remote is universal).
Jul 01, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Remote control does not work
Sounds like a bad IR sensor in either the remote or the unit.
Dec 29, 2008 | Audio Players & Recorders
Dino Buddy not responding to r/c
I Replaced the batteries in the dinosaur, because mine did that after only a few hours. when the batteries start to die, only the demo switch works...
I hope this helps!
Nov 29, 2008 | Lillian Vernon Remote Control Dinosaur...
Samsung DVD-V5500 DVD Player/VCR Logo
201 people viewed this question
Jerry Greenberg
Jerry Greenberg
