Question about Garmin Nuvi 760 Car GPS Receiver
Charging Garmin Nuvi battery for first time
Should a Garmin Nuvi 855 be turned on or off to charge the battery for the first time? How long might it take?
  • merryblue Jun 21, 2009
    Thank you. Should the Garmin be in the OFF or ON position during charging?
    Much appreciated!
  • 2,200 Answers
The Garmin Nuvi 855 uses a Lithium-ion battery. It is a very clean system and does not need priming as nickel-based batteries do. The 1st charge is no different to the 5th or the 50th charge.
In other words there is no memory effect with these batteries and it should be safe to charge it for as long as you like on the first charge. I would estimate 4 hours will give you a full charge if you wish to do this from the outset.
Posted on Jun 21, 2009
  • Radio Code Pro
    Radio Code Pro Jun 21, 2009
    No problem. You may find the unit turns itself on automatically when you connect it. It may or may not do this on the first charge. It really is a matter of personal preference but I would be inclined to turn/leave it off for the first charge.
My garmin in nuvi 1350 will not charge it keeps saying the battery is low
Nuvi 1350 charges in 4 to 8 hours. If your Nuvi is not accepting a charge, you may have a loose or bad USB cable. Note that the Nuvi can be charged with a phone charger. Charging it with a connection to a computer moves charging time toward 8 hours and more towards infinity if you don't have the driver installed on the computer. Turn the Garmin off. If the driver ins installed in the coputer, plug the Garmin into the computer and then hold down the power button on the Garmin for 30 seconds.
Sep 10, 2017 | Garmin GPS
Garmin 255w i replaced the battery, symptons of charging
Hello
There sill be a battery symbol in the forner of the screen which sill indicate advancing the charging signal [very like battery signal of a cellphone] in green color. You can see it on its manu page. To increase the accuracy of the battery guage, gully discharge the battery and then fully charge it. Do not unplug the Nuvi, until it is totally charged. Connect the vehicle power cable to the mini USB connector on your Nuvi and to a power outlet in your vehicle. The vehicle key may need to be turned ON/ACC for Nuvi to charge.
Connect an AC adapter [optional accessory] to the nuvi and a wall outlet.
Connect your Nuvi to a computer using a USB cable. The computer must be ON for the nuvi to charge. OK.
Jan 12, 2012 | Garmin nuvi 255W GPS Receiver
Garmin nuvi 40 goes into usb mass storage mode when pluged to charge
I updated my Nuvi 40 with the latest software and it will not reboot into GPS mode with the usb cable connected. It used to work. I have figured out how to get it to charge with a standard USB cable:
1) Power it on.2) Press the battery icon for 8 seconds - it will enter TEST mode.3) Plug in your USB cable from the PC to the Nuvi - the screen will change to say charging.4) Press the power button 3 times rapidly - it will say Charging across the screen and it will go dim and then dark.5) To wake it up and use GPS mode while charging simply press the power button 3 times rapidly, again.
Works Great!
Nov 15, 2011 | GPS
My Garmin Nuvi doesnt charge
I've received many units for repair where the customer thougth that the battery was bad because the unit would not turn on or stay on long.
The problem was really caused by broken connections on the mini-USB jack. Please see this link for more info, specifically look at the section dealing with the mini-USB connector.
http://www.sharc.net/gps_charger_repair.htm
- Jim
Oct 22, 2009 | Garmin nuvi 205 GPS Receiver
Nuvi 200 when charging never says charging complete .
HI, I have the same NUVI. Mine does the same. I haven't had any issues with it. It still charges fully when I unplug it.
Jul 25, 2009 | Garmin nuvi 200W GPS Receiver
How do know when my Garmin 855 is done charging?
Turn it on without being connected to the charger and check out the battery indicator - that will give you a bearing on battery condition.
Sep 20, 2017 | Garmin Nuvi 660 GPS Receiver
Need Garmin nuvi 855 manual
Your manual for your Garmin Nuvi 855 can be found at this following manufacturer link:
http://www8.garmin.com/support/userManual.jsp?market=4&subcategory=41&product=010-00577-31
Please be sure to vote if this was helpful to you.
Regards,
Joe
May 07, 2009 | ICOM Informatique GPS
Is m Garmin nuvi 200 GPS charging
Merritt, Your Garmin Nuvi does not have a charging indicator similar to say your Cell ph. Simply a battery charge indicator scale. Normal full charge time is approximately 3 to 4 hr. If you looking to ensure your unit is in fact charging Plug in & then remove the connection, Your unit will pop-up a screen to request if you wish to remain on battery power. I hope this helps you.
Mar 09, 2009 | Garmin nuvi 200W GPS
Without plugged in my garmin nuvi 200 will not work
That means that you have to replace the battery.
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Jan 21, 2009 | Garmin nuvi 200W GPS Receiver
First time use / battery charge
The Nuvi units are short on battery life and therefore Garmin has given you a connector other then USB to power your unit while in a car. You need to carry that. It's just a design flaw. If you try to rely on the battery of your Garmin Nuvi, you have less than 2 hours even on a full charge. And carrying the USB adapter which plugs into the cigarette lighter socket won't allow your unit to run while charging. so you need to take the adapter charger bracket that comes with the unit if you need it for longer trips.
Jul 10, 2008 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 760  Car GPS Receiver Logo
3,016 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
