Question about Apple iPod nano
Ipod nano 2G charges but does produce sound through docking station speakers , i already pushed the reset on the speakers, and it didn't work..this docking stations works for other ipods..
SOURCE: IPod Nano will not shutdown
turn hold button on and off, then press the menu and centre key at the same time to reset it. T
Posted on Feb 24, 2007
SOURCE: iPod 8 GB silver will not turn on
I went to the Apple site and found these instructions. They worked for me.
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Posted on Dec 27, 2008
  • 11 Answers
SOURCE: does not charge
Hold down the play pause button for 30 seconds to reset the ipod.
Posted on Apr 28, 2009
mneilsen2084
  • 342 Answers
SOURCE: My ipod will only work while plugged into the docking station
If the part is stuck inside the iPod you can take the case apart quite easily and remove the broken part. If this is not the issue and I am way off please do let me know :)
Top Case Removal Begin by using a flat tool to separate the white plastic front case from the silver backcase. You will need to stick your flat tool into the crevice, work it down into the crevice,and then pry up so that the casing separates. Apply enough pressure so that your flat tooldoes not slip and scratch your iPod!Continue separating the casing by gently prying up all the way around the unit. It shouldbe much easier to pry the casing apart after you get the initial corner started.
Posted on May 19, 2009
natemc
  • 7 Answers
What you may have is a low-speed USB port, when the iPod is designed to run on a hi-speed USB port All Mac computers have this and most Windows years 2005 and up have it as well. Another thing that may have happened is when you plugged in the cord, or unplugged it, you may have accidentally broke off some of the metal inside the iPod that connects to the cord Try looking at that as well. Hope this helps!!!!
Posted on May 20, 2009
Will the apple ipod nano 5th gen. work with this system. Sony AIRSA20PK S-AIR iPod Dock and Digital Wireless speakers
  • Compatibility: iPod mini; iPod nano 1G, 2G, 3G, 4G; iPod classic 4G, 5G, 5.5G, 6G; iPod touch 1G, 2G; iPhone, iPhone 3G, iPhone 3Gs
  • Wireless audio system includes iPod Dock/Transmitter and two wireless speaker systems with LCD display and alarm clock function
  • AM/FM tuner provides alternative to iPod content; multi-zone function means iPod can play in one room while radio plays in another
  • Expandable system is easy to set up, and is compatible with up to ten speakers with the compatible audio receiver
  • Connect to your home AV system with composite audio and video cables for enjoying iPod content
  • May 07, 2010 | Apple iPod nano 5th Generation
    The altec lansing inmotion does not charge my new ipod nano.What I can do
    Maybe this could be the solution...
    Source: http://www.speakerstation.co.uk/ipod-speaker-docks-ct-87.html
    Important Note: iPods released since Sept 2008 (e.g. Touch 2nd Gen, 4th Gen iPod Nano and iPod Classic 120 Gigabyte, iPhone 3g and onwards) have an updated dock connector that means older revisions of speaker dock may not be able to charge these newer models of iPod/iPhone. Older docks should play music from these newer models with no problem.
    The problem with charging is due to Apple removing support for 12v (firewire) charging on these new models of iPod/iPhone. Only 5v (USB) charging is supported on these new models. ..."
    Oct 30, 2009 | Altec Lansing inMotion® iM500 Docking...
    Directions say it charges and syncs. When I
    Look at:
    Oct 09, 2009 | Altec Lansing inMotion® iM500 Docking...
    My iPod nano 8 gig will not charge on JBL On Time
    1695.12847.600x400.ifwahbk.jpg Get one of these to sole your problem. ipod change their charging circuit I found one at Walmart in the ipod accessories section. Its called the Passport home dock adapter.
    http://www.scosche.com/products/productID/1695
    - this accessory supports charging for the iPhone 3G, iPod touch (Gen 2) and iPod nano (Gen4) with most iPod docking stations
    - Snaps into any iPod universal dock and accepts universal dock adapters
    Jul 07, 2009 | JBL On Time Docking Station for Apple iPod...
    I cant get my ipod nano 2g`s speakers to work when docked?
    i tried it again and it didnt work so i went back to argos and got another one and it worked then it was my 1st ipod it was faulty lol
    Mar 25, 2009 | Altec Lansing Inmotion-IM600...
    IPod is not charging when docked.
    my 6 generation nano will not play on my i-f2 sonic impact portable docking station, can any one help?
    Jan 07, 2009 | Sonic Impact Technologies IF22 Docking...
    Docking station
    Hi!
    I would suggest that you by-pass any docking stations and connect it directly via usb charger as most ipods do. And also, try to update Itunes and your Ipod Nano software.
    Thanks and good luck! =)
    Jan 04, 2009 | Apple iPod nano
    Problem with ihome and ipod nano.
    yes, unfortunately the ihome iH9 is not compatible with previous models of the ipod nano.
    if you want a similar device, there are many other docking stations for the ipod that are ip0 that ARE compatible with the ipod nano 2G
    iH85B is another ihome dock which is compatible with all ipods after the ipod mini (including the ipod nano 2G)
    http://www.ihomeaudio.com/products.asp?product_id=10186
    Dec 25, 2008 | Apple iPod nano
    ILive docking station not working properly
    Omg i have the same exact one and the exact thing happens with mine---blue light no longer shows up and music will not play through the speakers---my ipod still charges and the clock still works but yeah---i also got mine 2 months ago!
    Oct 24, 2008 | Audio Players & Recorders
    Ipod nano not charging on docking system, it has low battery if none, can play with a little charge on ipod but has to be charged with plug first, the docking system is brand new aswell and is charging...
    for some **** reason the new ipod nano (4th generation) does not support FireWire and therefore will not charge on any docking station that is a FireWire power sorce - which seems to be most of them out there!
    have same problem so will end up charging from computer as docking station still plays the new nano, no point in buying new docking station just for sake of charging!
    Aug 01, 2008 | Audio Players & Recorders
    Apple iPod nano Logo
    50 people viewed this question
    Top Apple Audio Players & Recorders Experts
    Nagendra Baliga
    Parshiv Luthra
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
