Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Ichanged the rear drive belt on my 17 hp
I changed the rear drive belt on my 17 hp mastercraft and now it wont go forward or backward.
  • 2 more comments
  • dlsproat Jun 21, 2009
    I tried to take the one wheell off so I could insert the pin which connects the shifter but i could not get the wheel off when I removed the bolt.
    What brought it to my attention was I was cutting grass and it quit moving forward. I knew the belt was in rough shape so I tried to cut the rest of the section as I was not sure if I could get a belt. Played with the shifter putting it in reverse and than forward and it went for a while longer. Than it would not move aafter that.
    Mod 13AR678G515 1999
  • Dwain Pippen May 11, 2010
    The reason I asked was there is a keyway in the axle and in the rim with a square key that locks them together. Sometimes people take off a wheel and don't see the key fall out. The mower won't move without it. Was the mower moving before you replaced the belt? Also, what is the model # under the seat?
    Did you have one of your rear wheels off while working on it?
  • 376 Answers
Ok, I see it's and MTD product. Did you replace both belts? The front belt is #954-0280 and the rear belt is # 954-0370. What I would suggest is remove the cover plate between your legs. You'll have to remove the shift knob and two screws. Start the engine, put the gearshift in nuetral and let out on the clutch pedal and observe what's happening. Everything will be working the same as if you were in gear. You should be able to see if there is a problem with one of the belts or the vari-speed pulley. Put the speed selector in 7th (or 6th) gear and push the clutch down then back up, and watch what going on. That's the best I can do without seeing it myself. Hope this helps.
Posted on Jun 22, 2009
Cub cadet sltx1050 wont go forward or backwards? was w orking fine then we had to push it backwards to jump iot cause it wouldn't start and now it wont move forward or backward
There are two possible options one is the belt for the drive is shot, the other is that the transmission is shot we tend to go out.
Nov 08, 2017 | Cub Cadet Garden
I need to know the length of belt required for a mastercraft 15 hp 46 inch deck. the belt drives the blades
Take a string and palce it as you would the belt, then measure the string
May 11, 2014 | Garden
Trans bad?
Jack up the rear end using the frame. Put a person or cinder block on the seat, and put it in drive. Look for the shafts turning inside the wheels indicating broken keyways.
May 06, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mower run but wont drive forward or backwards?
check the drive belt also is the release lever pulled the one that allows you to push it
Apr 15, 2012 | Toro Garden
The tractor will not go forward or backward it starts right up but will not engage
1) The drive belt between the engine and transmission has broken or jumped off a pulley.
OR
2) Your hydrostatic transmission is dead.
DO NOT STICK YOUR FINGERS UP INSIDE A RUNNING MOWER TO SEE IF THE DRIVE BELT IS MOVING.
Jul 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
FORWARD AND REVERSE GEAR SELECTION BACKWARD
Recheck your belts, does your engine have a pto
Jul 28, 2009 | Garden
Cratsman lt2000 lawn tractor will start but will not move forward or backward. I tried changing the drive belt, but that didn't work.
Is the transaxle pulley turning? If so have you removed the rear wheel recently and possibly lost the square key that fits on the axle?check those two items first.If ok it probably has a broken gear or shift key in transaxle.
Jul 14, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
385 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
