Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Stops after a few mins of use
After I vaccuum for a bit the machine will just stop.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 83 Answers
You are experiencing a thermal cut-off - caused by a blockage. The machine turns itself off before it overheats. You will be able to turn it on again after 30 mins to an hour after it has cooled down. Call the Dyson helpline to do a full troubleshoot to find the blockage.
Posted on Jul 30, 2009
Bikegit
Replace the switch! It shut down when battery get depleted. and then when you start it again the cycle is shorter because the batery regenerate but not as previous cycle.
Jul 16, 2014 | Karcher WV50 Window Vacuum
Tip
How to Prolong the life of your Vacuum leaner
There are several types of vacuum cleaners these days. Most people now seem to use the upright bagless vacuums since you do not have to buy the filter bags. Those vacuums are fine, if you take the proper care of them. Ithink it is a bit messy. In order for you to really prolong the life of any vaccuum, you must make sure the machine has plenty of circulation. In order for the vaccuum do the great job you expect, you have to do a little maintenance on it.
  • Each time you run the vaccuum,
  • Take out all filters (foam & the plastic inserts)
  • Wash the filters out with warm water.
on Jan 06, 2010 | Vacuums
Vaccum afuera 550 start few minutes and stop few secondes, after 10 min its stop 30 sec and start 3 sec, after 20 min start ok
Your vacuum may be clogged, overheating and shutting off. Check for obstructions in the hose by laying it as straight as possible and shining a flashlight in one end while looking thru the other end. If you have a curved hose end, try holding the suction hose from another vacuum while checking for airflow in the opposite end.
Nov 06, 2013 | Electrolux Central Vacuum
My vaccuum stopped working after it was working. I cleaned two rooms and it stopped. Any ideas.
Did the machine just turn off or what? What model is the vacuum?
Check for any clogs, first, and clear them if needed.
Also, check to see if the bag is full.
Aug 23, 2010 | Oreck Vacuums
My fusion just stopped. i was vaccuuming and it
One item to check is this: This unit has a temperature overheat device.
Unplug the unit for 20 minutes, then plug in and turn on the switch. If there was a blockage in the hose/cup/filters, this could cause the overheating.
If this does not resolve the problem, it will need disassembled and checked with a continuity meter to determine the component that failed (motor, switch, cord, or TCO)
Oct 25, 2009 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Smells like the motor is burning. observing sparks. It the motor cooked and is it just time for a replacement?
If you're observing sparks, then yes, just get a new one. With the low prices of good vaccuums its not worth starting a fire with your vaccuum. If it just smells like the motor is burning, check the belt and make sure its rotating freely and if you have an attachment, make sure the brush on the vaccuum is not being stopped while using the attachment. However, if you are seeing sparks,,,, definately time to junk it
Aug 20, 2009 | Sharp Twin Energy EC-TU2603 Bagged Upright...
No Suction
Your Power head is blocked with hair or dirt,,or the hose which connects the Upright with the power head is blocked.
Try taking a steel coat hanger apart (straighten it out) and then push it into the pickup hose to remove blockage.
Jan 29, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Vaccuum stopped running
Belt jumped off beater bar and jammed it! Disconnect belt, does imotor run. If yes, reconnect belt turning beater bar by hand to see if it is smooth. Carefully, reassemble and run it!
May 28, 2007 | Eureka 4386AT Upright Vacuum
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
118 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
