Question about Miele DA 249-4 Kitchen Hood
Distance from lowest point
Hi, my electrician has jsut installed my range hood & it appears too low. Could you please tell me the height distance from the LOWEST point (being the sides at the front) & the middle height ( from the front mid section) I have tried to desypher the measurement guide to no luck. I don't want to be duped cos the electrician can't be bothered to change it.
Thanks in advance
  • jules2623 Nov 05, 2007
    Thanks for your help!!
It is 600mm for electric hobs to 650mm min for gas hobs.The point of measure is from the top of the cooktop to the filter on the rangehood.You can have it higher if you want but it starts to not work as efficiently especially if you have cross winds such as open windows.
Posted on Jan 24, 2009
    Scholar:
  • 146 Answers
Normally the rangehood should be at least 700mm from the top of the cooktop.
Posted on Nov 04, 2007
Seats height
Hi, here is how to determine your seat height.
Measure your inseam length by standing barefoot against a wall, use a book to press up as high as possible between your legs, and measure the distance from the top of the book to the floor.
Take that length and multiply that with 0.65 to give you the distance from the top of your saddle down to the center of you BB axle, where your crank goes through. The distance indicated by A on this pic.
Hope that helps!
Sep 11, 2013 | Giant MTX 125
What is brace height?
Brace height is the distance, when the bow is at rest, from the string to the deepest point of the grip. Today's bows generally range from 5-1/2" to 8-1/2"
Jul 09, 2012 | Archery
How do you adjust a 1994 Jeep grand cherokee laradeo headlights?
There are two adjustment screws at the top of each headlight. They are visible when the hood is up. Use an Allen wrench (hex) of the proper size to turn one screw to adjust the height and the other for lateral adjustment.
It is best to position the vehicle on a level surface a facing a wall or garage door. The vehicle can be about 8 feet from the wall during adjustment.
Adjust the light left/right and up/down with those adjustment screws. The head lights should point somewhat straight ahead at the same height as the headlight itself and the same distance apart.
After adjustment, park the car on the street at night, turn light son and stand about 50 feet form the vehicle to see if either light (low beams) seem too high. It would appear brighter if it is too high, dimmer if it is too low.
Nov 16, 2010 | 1994 Jeep Grand Cherokee
From a point on the ground, a person notices a 110-foot antenna on the top of a hill subtends an angle of 1.5 deg. If the angle of elevation on the bottom of the antenna is 25 deg, find the height of the...
Draw one right-angle triangle:
D
C
A===B
A = your location
B = bottom of the hill
C = bottom of the antenna
D = top of the antenna
The A-B distance is constant.
The B-C distance is unknown.
The B-C-D distance is unknown.
The C-D distance is given.
The C-A-B angle is given as 25 degrees.
The D-A-C angle is given as 1.5 degrees.
Use SINE and COSINE functions to determine the B-C distance.
Tell your teacher that you found the answer to your homework on the Internet.
Sep 24, 2010 | Computers & Internet
I just installed the right head light on a 2000 f250. I'm trying to find the specifications on distance and height of the light beams, L &R when adjusting the lights.
Headlamp Adjustment —Screen Method Aiming NOTE: Horizontal aim is not necessary for this vehicle and is not adjustable.
NOTE: Consult your state's vehicle inspection manual for recommended tolerance ranges for visual aiming.
  1. NOTE: The sight shield may need to be positioned or removed for access to the adjusters.
    Before starting headlamp assembly adjustment:
    • Check the tire inflation.
    • Check that no other load is in the vehicle other than a half tank of gas.
    • Check that the headlamps are clean.
    • Check for correct headlamp operation.
    • Check that the vehicle is on level ground.
    • If the vehicle is equipped with air suspension, make sure the switch is on.
    • NOTE: The vertical wall or screen must be a minimum of 2.4 meters (8 feet) wide.
  2. Park the vehicle on a level surface approximately 7.6 meters (25 feet) from the vertical wall or screen directly in front of it.
    NOTE: The center of the lamp is marked by a 3 mm (0.12 in) circle on the headlamp lens.
    Mark a horizontal reference line on the vertical wall or screen.
    1. Measure the center of the headlamp height to ground and record.
    1. Make a 2.4 meters (8 feet) horizontal mark (masking tape) on the vertical wall or screen at the same distance from the ground as previously recorded.
  1. NOTE: This procedure should be done in a dark environment to effectively see the headlamp beam pattern.
    Turn on the low beam headlamps to illuminate the wall or screen and open the hood.
  1. NOTE: The appearance of the beam pattern may vary between vehicles.
    On the wall or screen, locate the high intensity area of the beam pattern.
7ced4e6.gif NOTE: The appearance of the beam pattern may vary between vehicles.
Identify at the top edge of this high intensity area a distinct horizontal cutoff in the beam pattern. If the top edge of this cutoff is not even with the horizontal reference line, the headlamp beam will need to be adjusted.
Apr 06, 2010 | 2000 Ford F250 Super Duty Crew Cabs
What should be the maximum distance between hob and hood and still maintain efficiency
There is an optimum height specified by your hood manufacturer. usually the distance between the wall and base cabinet is 600mm. the hood could be at 600mm or slightly higher say not more than 750mm.
Thanks.
Jun 25, 2009 | Kitchen Ranges
How to use the reticle in my Fujinon Mariner Binoculars?
How to use the reticle:
The vertical scale (reticle) visible through the left half of the binocular, above the compass display, allows you to calculate distance to an object if you know its height, or to calculate the height of an object if you know its distance from you.
Each mark on the vertical scale has a value of 5 MIL (1Mil is equivalent to an angel that can determined an object one meter in height at a distance of 1000 meters). Therefore, if a navigation chart gives the height of an object, by sighting on it and counting the number of MILS, you can determine how far away it is.
To Measuer distance when height is known:
Object Height(m)/Scale Reading x 1000m=Distance in Meters
To Measure height when distance is known:
Distance(m)xScale Reading/1000=Object height in meters
Jan 26, 2009 | Fujinon Mariner WPC-XL Binocular
Distance betweeen range top and microwave 60654
This is always covered in the owner's manual or installation manual. If you don't have yours, you can find one here.
In some cases, you can get it free if you see a "Manage My Home " link on the right side of the page after entering your model number.
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
We're happy to help and we appreciate your thoughtful rating of our answer.
May 28, 2008 | Kenmore 60654 Microwave Oven
Miele DA 249-4 Kitchen Hood Logo
364 people viewed this question
Top Miele Kitchen Ranges Experts
Jim Thurston
Steve
Are you a Miele Kitchen Range Expert? Answer questions, earn points and help others
