Question about Electric Autometer Z Series 2 inch Oil Pressure Gauge, 100psi,
How do I open an Autometer Sport Comp gauge? - Electric Autometer Z Series 2 inch Oil Pressure Gauge, 100psi,
I need a wiring diagram for instrument cluster for 04 Ford sport trac so i can hook into fuel gauge input wire to hook up a autometer fuel gauge
there's an online store www.reliable-store.com where you can get info on all vehicles, heavy equipment, engines right from service instructions, repair instructions, parts info, wiring diagram, torque specs, electrical, fuse diagrams, error/fault codes everything
Jun 05, 2018 | Ford Cars & Trucks
How can i get my 97 model jeep cherokee to run with the guages working as well. fuel imobilizer problem.Have 2 computers,First one the car starts and runs fine but no gauges work and the original comp
Is the first one - the functioning one - also from a '97 Cherokee Sport 4.0? I think it may have its own problems, or it might be from a different vehicle - different year or model - and incompatible with your gauge head.
Aug 03, 2014 | Vehicle Parts & Accessories
Need to tear apart autogage plastic tachometer to fix the needle
Remove the gauge pod from the dash, get a heat gun and slowly warm the edged of the plastic face to relax the adhesive that holds the face to the pod. Carefully remove the face and place it face down on a clean surface. Carefully put the needle back on and do the reverse of the face removal to get the adhesive so it will reattach.
Sep 18, 2013 | Auto Meter - 2343 - Autogage Mechanical...
Speedometer/tach combo i bought from autometer cant get the speedometer or odometer to work the back of the autometer has 12 places for wires but my factory gauge only has 10.autometer has not been an
your spedometer should be hooked up via cable off the front wheel. not through wiring but use your volt meter to ensure the wire coloring didnt change in the makes of bikes
Apr 21, 2013 | Harley Davidson FLSTC Heritage Softail...
Tach reads double of old one
look to the connection of the tach wire, see if its on the green wire of the coil, if it is, then clean the connection and see if that helps, if it still doesnt work properly you may have a faulty gauge
Jul 03, 2010 | Autometer Auto Meter TachometerSpeedometer...
I would like to know if I can wire my autometer guages (electrical) into my instrument cluster with out causing damage. I own a 81 GMC C2500 pickup. Thanks steve sstratford@cogeco.ca
If you are looking to install these gauges into your factory cluster it is possible as it is not a computer cluster. I would look into buying a professional cluster made for hotrods that is already done as there is alot of work to do to make the Autometer gauges fit nice and clean. There is a plastic cover over your factory gauge set and it will be dificult to get it cut out and set rite for the new gauge set. maybe if you built your own cluster unit you could use one of these Billet pieces as a template. Thats just a thought I have done this and It looks nice with a rose wood underlayment routered out to fit the gauges.
http://www.trucknvans.com/Billet-Center-Dash-s/673.htm
I hope this helps.
Roy
Nov 17, 2009 | GMC C2500 Cars & Trucks
Autometer tachometer installation
I have a 09 cobalt, and i cant figure out which wires and where do i hook them up to so i can use my after market tach
Oct 02, 2009 | RTO Autometer Auto Meter 6121 Cobalt...
I have a 2003 mustang cobra, I have a auto meter shift light and sending unit. what to I hook the sending unit to ??
To the tachometer. The sending unit should have the instructions for the hook-up
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 31, 2009 | Electric Autometer Z Series 2 inch Oil...
Electric Autometer Z Series 2 inch Oil Pressure Gauge, 100psi, Logo
61 people viewed this question
Top Electric Measuring Tools & Sensors Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Electric Measuring Tool and Sensor Expert? Answer questions, earn points and help others
