Question about Sony STR-DG500 System
Hi there I don'tseem to be getting any component video output. I am inputting virgin via optical input video 1, I get the sound and the box even displays virgin but no visual output?
    President:
  • Sony Master
  • 1,114 Answers
Optical is for "audio only" you need to send Video from whatever source you are hooking up, ie. TV,DVD,DSS,etc. Use what the source has, if it's got Component Video out, use that, Don't use HDMI! still too many firmware issues! Make sure when you hook it up to the receiver that you hook it up to the same input as your audio, just on the video side. It will say DVD or DSS or CBL next to the green,blue,and red inputs. Hope this helps
Posted on Jun 21, 2009
Conrad johnson converter connection
Hi sherring, have you cheked that your cable isnt damaged? the connecton at either end might be loose.
Dec 31, 2007 | Technics SA-AX530 Receiver
Ok so the issue is that after i have ran a hdmi cable from reciever to monitor, and 2 hdmi inputs (dvd and video2) into the reciever where im running a ps3 into the video2 port and foxtel/satellite tuner...
Try this, although recivers have video pass through, it is not the best option for video to your monitor. Depending on what you have for input/output on your TV/monitor, and, if you can, you should run all your video components directly to TV via(best)HDMI(video and sound) or, component and digital optical(best) or RCA, Then run digital optical out from you TV out to receiver in. You can use your monitors menu to chosse what you view and only have the onr input to you reciever. ASll you have to do then is go through you recievers menu to get the audio. Less connections less hassle. In other words, you would run your sat tuner to tv inputsat or cable, then dvd to dvd, PS3 to video 1 etc., on TV/monitor, then the single audio output to reciever.
Dave
Jul 03, 2011 | Audio Players & Recorders
Hi. I write from spain. I have the blu-ray LG
Have you tried the another optical cable? They don't tolerate dirty connections or small-radius bends in their routing. THAT (and the expense of optical cables) is why I always choose coaxial connections when possible.
Mar 02, 2011 | Yamaha RX-V363 Receiver
I have a Denon AVR2307 to which is connected,via optical audio and component video a DVD player/recorder and this works well but in order to take some of the work off the player part I've bought another...
HDMI signal from DVD can not be down converted to analog component signal.
Connect your new DVD to a component input 1..4. Make sure that component input assigned to desired input (dvd/vcr/sat/) (setup - input setup - input - component assign - component x etc). Connect coax output of DVD to coax x input of the receiver and assign it (setup- input setup - "input" - digital assign ..). Probably you need to setup DVD output resolution to 720i or 720p in dvd setup menu.
Sep 09, 2010 | Denon AVR-2307 Receiver
Hi there, is there a way to get my goodmans ghc58 surround sound system to play through my virgin + box? I cant seem to find an optical input/output from the surround sound but i do have a goodmans dvd...
There is an optical output from your Virgin + box but there is no optical input in the Goomans, there is only 5.1 input. The only way to do it is to connect the re and white phono audio output from you virgin box to the red and white tv inputs on the goodmans, this will sound good but it will not give you dolby digital sound.
Dan
Nov 28, 2009 | Audio Players & Recorders
How do i use it so my tv programming is in surround sound?
if the Comcast cable box has an HDMI output, it should connect directly to one of the TV HDMI inputs. Then connect the LG DVD unit HDMI output to the second HDMI input of the TV. Use two HDMI cables. Do not buy the expensive Monster HDMI cables. If you have already done so, I recommend you take it back for a refund, then buy the low cost HDMI cables which will work just as good and then you can bank the savings toward a new Porsche Boxter!! Now we have the video connected from both the cable box and the LG system.
Now--what do you do if the cable box does not have an HDMI output--just use its component output and your component cable (red, blue and green) to connect to the TV component input. This will still get the video to the TV and good HD pictures. Hum--do you have an HD cable box? You did not say and I just assumed that you did since you got the HDTV. If not, let me know with a follow up question and I will assist in that area further.
Now for the audio connections--The DVD player will not need any connections since it in the LG unit. The sound will come out the speakers when you start playing the DVD. The cable box is where we get the TV audio to feed the LG unit. If the cable box has an optical output, use an optical cable (again the low cost one)and connect to the optical input on the LG.
This will get the TV audio to the surround system. If no optical output, use the red and white (left/right) audio connections and connect to one of the two the LG audio inputs. To hear TV audio on the LG speakers, just switch to that input or the input associated with the optical input.
To watch DVDs, switch the TV to the HDMI input to which you connected the LG unit. For TV, go to the other HDMI input (or component input).
Switch the LG to the audio input to which you connected the cable box to get TV sound.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Sep 11, 2009 | Audio Players & Recorders
Which optical inputs should I use for (1) audio output from hi-def cable box (connected to HDTV with component cables) and (2) audio output from DVD (connected to 3805 with component cables?
Hi, the Optical and Coaxial inputs are assignable to whichever input you need them on. Plug the Optical cables from your DVD and HD cable box into any of the OPTICAL INPUTS (1 and 2 is fine, but write down your connections on paper)
You will then need to go into the setup of the AVR on the screen and assign the OPTICAL connections to the correct inputs (Probably TV/CAB and DVD.
Use the SYSTEM SETUP button on the factory remote, and you should see the on-screen menu appear on your TV. Go to INPUT ASSIGNMENT and choose the input for the DVD and assign OPTICAL 1 or 2...
Reply here if you need more help.
Jul 06, 2009 | Denon AVR-3805 Receiver
No picture from monitor out on Onkyo TX-DS898
I realize you may have already doubled checked but make sure you follow this from the manual:
If the satellite tuner / cable box is equipped with an S video output
terminal, connect it to the S VIDEO 3 (or 4) IN terminal with an S
video cable. If it does not have an S video output terminal, connect
its video output terminal to the VIDEO 3 (or 4) IN terminal using an
RCA-type video connection cable. You do not need to connect to
both the S VIDEO 3 (or 4) IN and VIDEO 3 (or 4) IN terminals. If
the satellite tuner or television has component video outputs,
connect them to one of the COMPONENT VIDEO INPUT jacks.
With the initial settings of the TX-DS898, the VIDEO 3 and
VIDEO 4 input sources are set for the COMPONENT VIDEO
INPUT 2 jack.
If the video connection is made at COMPONENT VIDEO INPUT
1, this must be changed at the Setup menu: Input Setup → Video
Setup → Component Video (see page 35).
Using an RCA-type audio connection cable, connect the audio
output terminal on the satellite tuner or television to the same
VIDEO 3 (or 4) IN audio jacks on the TX-DS898. Make sure that
you properly connect the left channel to the L jack and the right
channel to the R jack.
If the device has a digital output jack as well, be sure to also connect
it to either a DIGITAL INPUT (COAXIAL) or DIGITAL INPUT
(OPTICAL) jack on the TX-DS898 depending on the device.
With the initial settings of the TX-DS898, the VIDEO 3 input source
is set for digital input at the OPTICAL 3 jack, and the VIDEO 4
input source is set for digital input at the OPTICAL 4 jack.
If the digital connection is made at a different jack, this must be changed
at the Setup menu: Input Setup → Digital Setup (see page 33).
Apr 15, 2009 | Onkyo TX-DS898 Receiver
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
Sony STR-DG500 System Logo
91 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
