Question about Epson Stylus Photo 1290 InkJet Printer
Hi my epson r285 with ciss is leaving ink blotches all over my print outs, predominantly black, but less frequent with the other colours. This is only a new printer. Head cleaning, noxzzle cleaning and head alignment do not fix this problem. Why is this happening and how vcan it be fixed? Is it because of the ciss? Think ink used in the ciss, the ciss cartridges, or a faulty print head?
  • Anonymous Mar 13, 2014
    using ciss system and lines wont ****
  • Anonymous Mar 27, 2014
    helppp
  • Epson Master
  • 511 Answers
It might be caused by waste ink at bottom plate around head sprayer. For some CISS (bottle) design, ink will flow to head, and then flow to pad, when printer off. So, you must close respiratory hole at bottle when printer is not used. For cleaning, turn off printer (unplug power) when head is not in parking position. Move head to center. Put wet tissue (with cleaner or hot water) at top of pad (at head cleaning mechanics). Move head to parking position. So bottom plate contact with tissue. Wait for 10 minutes, repeat 3 times. Check nozzle.
Posted on Jun 21, 2009
  • 258 Answers
It is fault print heads, replace the black ink cartridge, if you have refilled it, the bottom of the cartridge has been damaged
First time visitor. Entered Epson Stylus Photo R285 into search box. As I scrolled down what I presume is the result of my search, there were answers for everything BUT my R285. I use a CISS kit on my...
Welcome to FixYa.
This occurs when the ink pad counter times out and is supposed to be a dealer service to drain the waste reservoir and replace the pad.
The only thing that you can do is try to reset the printer. Please do the following:
  • Turn off the printer by pressing the power button. Check to make sure that the print head is in the default position, to the far right of the device and locked in place.
  • Hold down the paper feed button. Turn on the printer by pressing the power button.
  • Release the paper feed button as the paper feed light starts to flash. Immediately hold down the ink-drops button for 15 seconds.
  • Wait for the printer to complete its test run. Turn off the printer and then turn it back on once more.
Thank you for using Fixya, keep me posted.
Jas247
Aug 23, 2011 | Epson Stylus Photo InkJet Printer
Epson R285 need service utility
It sounds a lot like you have managed to reset the printer using the R290 adjustment utility and it now thinks that your printer is an R290 printer.
As a result it's rejecting the yellow cartridge (presumably the first to read empty since you reset the printer) and expects you to provide R290 consumables.
The only fix that I've heard suggested (and I'm still waiting to hear if it worked) if to get someone with a valid R285 to use the same adjustment utility to make a backup of the EEPROM data (nothing else), save this file, send it to you, and then for you to restore that same data to your own printer EEPROM.
As I said, I haven't heard if it works and I could be wrong about the cause but as I provide waste kits myself and have already had quite a few people report a similar issue I suspect I'm about right.
Hope that helps.
Martin
Jul 06, 2009 | Epson Stylus Multifunction Inkjet Printer/...
RIP OFF EPSON, NEVER BUYING A PRINTER OR ANY SORT OF DEVICE FROM THEM AGAIN. WON'T LET ME PRINT WITH BLACK INK ONLY, BECAUSE YOU NEED YELLOW TO PRINT BLACK, YEAH? STUPID COMPANY!
It's up to you. Epson have best head design using micropiezo. we just to replace ink tank to continue printing. Or if using CISS, no maitanance. Just fill the bottle. All ink tank must be inserted, when printing, even we just print black, to preserve ink dried at head. Actually, if we just want black ink print out, we can insert empty yellow tank, but level indicator (program) not ink out.
Jun 28, 2009 | Epson Stylus Photo R200 InkJet Printer
Printing problem with Epson CX9400
I have a CX9400Fax and occassionally print is mixed/missing lines. You must do a Cleaning cycle usually at least 4-6 times or until it prints a clear pattern. It will use LOTS of ink during the cleaning cycle. The printer normally uses a lot of ink, my solution was to purchase a CISS system along with a Waste Ink Container. IMO the best CISS is sold by the company below. I did have to call for tech support once and they returned my call in 30 minutes, problem solved and never came back. I purchase refill ink and it seems that I do a lot less cleaning cycles.
http://www.inkproducts.com/ink-store/
Jun 20, 2009 | Epson Stylus CX9400 Photo Printer
Why does everyone go quiet when I mention Epson r285 , 2 red flashing lights and service needed. Does no-one of you highly intelligent boffins know how to reset a simple printer. Ive asked and asked on...
Bit late in replying but this guide for dealing with the R285 has been up for a while now.
It tackles everything from installing a waste ink tank to resetting the waste ink counter.
Wrote the thing myself following quite a bit of interest... Hope it helps.
Apr 06, 2009 | Epson Stylus 2200 InkJet Photo Printer
How to fix CISS Unit to Epson RX 610 printer?
replaced all ink colours and now a colour print is almost all black and white with a tinge of magenta? how can i fix this
Mar 29, 2009 | Epson 6 Color Inkjet 5760x1440dpi Photo...
Ciss for the epson r285
hi parksey,
Try to do clean test,
pick up the in cartridge and clean connection tips and rrfit it.
hope this helpfull,
thanks
Hamedo
Nov 08, 2008 | Office Equipment & Supplies
My epson r285 wont recognise compatable inks
My Epson R285 will not recognise compatible cartridges,mainly the black.I ran out of black ink and installed a compatible cartridge but it did not recognise it.To get the printer running I had to buy a genuine one which worked.I then ran out of all the other colours soon after and installed compatible ones which were accepted.I have now ran out of the black again but the printer will not accept the compatible cartridge.How can I solve this problem as the printer has accepted black compatibles before.
Thanks Padgy
Oct 09, 2008 | Office Equipment & Supplies
Using colour ink without black ink in Epson CX5500
this cannot be resolved, Epson software is useless it will force you to buy an INK
Jun 07, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Epson Stylus Photo 1290 InkJet Printer Logo
799 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
