Question about Refrigerators
I also have a constant clicking and the fridge does not cool prop
The service engineer said the part was not available even though the fridge is in perfect condition otherwise. It seems a waste to scrap it for a trivial fault
  • 1,543 Answers
That is not a trivial fault.
You do not say what brand, model number, or part name or number you were looking for, or even the age of the product. It is possible that even discontinued parts may be available from some sources. Some parts resellers may still have some in their inventories, or you may be able to find the part on ebay or similar sites. If not, contacting the manufacturer's consumer relations department may help. Remember to always be polite and positive. Tell them how well you like there product but are dissapointed to not be able to locate a repair part. If they cannot help locate a part, perhaps they might offer a "good will certificate" which would give you an extra discount toward purchasing a replacement unit from them to keep you as a satisfied long term customer. Most have toll free numbers, so your time is all that would cost to ask, and if they can't or will not help, you are no worse off than you are now.
Posted on Jun 21, 2009
My kenmore 253 upright freezer/fridge is not cooling the fridge part correctly. It's cool but not cool enough to keep the food fresh. The freezer works well sometimes. And sometimes it seems that it's not...
Try this test. Set a window fan behind the fridge to constantly blow air across the lower coils at the floor. If the fridge works well after a while of this, then the lower fan on the fridge needs replaced. Sometimes though, after a while, the fan will finally start working again because the cycle has finally corrected itself with the test. Leave the window fan run on low for a few days before removing it. The hum you hear is the compressor moving the coolant and is supposed to do the hum sound. That's good. Now once the fridge is working, and you still have a good freezer section and not cool enough below in the fridge for you, there is a knob that sets the cool lower by opening flaps under the freezer to let more cold down to the fridge area. Set this knob to colder and the flaps will open more.
Nov 11, 2014 | Refrigerators
KitchenAid Superba Fridge beeping and clicking on and off
next to the compressor is a relay called a klickson
You can get engineer to replace for about $120 or buy one for about $20
Apr 08, 2014 | KitchenAid Refrigerators
Cannot remove a constant speed prop from a lycoming engine
What sort of Prop do you have and what engine model is it fitted to?
Jan 25, 2014 | Sport & Outdoor - Others
The top section of my refridgerator is not cooling at all and the alarm goes off constantly even though the door is cloased what can be the problem
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 03, 2011 | AEG Santo 3888 KG8 Bottom Freezer...
Hi, My fridge ( 420 ltrs) Top Freezer making constant humming noise ( like a dieasl car engine)like the engine keeps running and try to cool the fridge. 1 year old. When I open the freezer or the...
The noise is the fan hitting ice build up on the coils... it is no defrosting properly...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 14, 2010 | Samsung Refrigerators
Constant clicking sound coming from power box amana fridge
When you heard the click and the compresor stops ,check if it's very hot , if yes the compresor is of on overload and this could happend because 1 the condenser coil is dirty ,2 the relay is bad or 3 the compresor has a problem .Also check if behind the kick plate there's a timer (some units have it there or next to the cold control ) that could cause a problem too.
Aug 23, 2009 | Refrigerators
CONSTANT CLICKING SOUND COMING FROM POWER BOX
if the fan blade is contacting anthing under there and stops it will shut down the compressor and wont work
Refrigerator not cooling properly.
upper part feeses and bottom not verry cold at all
Aug 16, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Freezer works, fridge does not,runs constant though
Try turning it off and defrost it for 48hrs with both doors open. Then turn it back on if it's still not colling the fridge then you need to check to see if the fan in the freezer goes at all. If it cools for a few days then goes warm again you may need a new D'frost element, D'stat or something else cheers
May 15, 2009 | Electrolux Refrigerators
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
