Question about HP Deskjet 840 InkJet Printer
When it is finish printing the result is that the text is not straight and after the the left upper part of the paper is like folded
  • 258 Answers
Thats because the paper feed or rollers are not sitting where they should be
Posted on Jun 21, 2009
Respected sir i have a printer lbp2900.canon.......the problem is when i command a print, when the print is finish a line appear after the print on the left side of the paper. sir unfortunately one day i...
Do a hard reset of printer to see if that clears up the electronics memory and restores operation. If that procedure and reinstallation of software does not remedy situation then something is wrong with the printer.
Aug 24, 2017 | Canon LASER SHOT LBP-2900 Printer
My Konica Minolta bizhub C250 seems prints about every 10th page crinkled and crooked. I can hear it going through the machine and crushing a crease in the paper as it prints. The printed also seems to...
The paper may not be feeding straight out of the paper tray due to poor stacking of the paper in the paper cassette. try another paper tray or check the paper in the paper tray for folded over papers usually near the bottom. Also try feeding paper from the hand feed tray on the left side. This uses a different paper path.
Dec 07, 2010 | Konica Minolta bizhub C250 All-In-One...
1320 Printer prints with corner fold
This tells me something is getting caught usually I would recheck the Paper Tray. If possible you could run the paper through the Bypass or Tray One as HP would call it. See if it is happening there if so then you can eliminate the Cassette Trayi
Also Did you run any lables through this Printer ??
Sep 12, 2009 | HP LaserJet 1320 Printer
Cannot print a manal with the finished size as 5.5x8.5 folded and stapled. IT SHOUD PICK UP THE 8.5X11 PAPER AND FOLD AND STAPE IT BUT IT DOESN'T. Please HELP.
for the 8.5x11 paper to staple the paper has to loaded in the machine with the short edge of the paper fed first so if the paper is turned the wrong way in the paper tray the machine will reject the fold command it should say on the paper type setting 8.5x11R
Jul 21, 2009 | Konica Minolta Office Equipment & Supplies
Need to print a half-fold card envelope with HP Photosmart C4480
I'm printing wedding invitation envelopes (or A6) and had to set both my C4480 and psc1315 to a regular size 8.5x11 letter size but changed my margins to reflect the smaller size for my envelope with the left side of the screen being the more narrow margin. After adjusting the top margin accordingly, I fed the envelopes, flap side down and straight into the printer and voila...envelope addresses are printed. Good luck. Blu
Feb 15, 2009 | HP Photosmart C4480 All-In-One InkJet...
Not printing
You probably have paper debris stuck to the underside of the print head.
While you are printing, pull the lead from the back of the printer leaving the head free floating and unlocked so you can slide it back & fore. Get a piece of kitchen roll and fold it until it's the size of the track beneath the print head slide the head to the left, place the folded kitchen roll flat down in the print track, slide the head over the folded kitchen roll until it appears on both sides of the head. Grab both ends of the roll and lift it toward the head. Slide the roll sideways left and right to physically clean the bottom of the print head. Try not to tear it as it will trap under the head. let go of one end and slide the head away until you can pull the roll out. It should have a lot of ink and gunk on it. Plug the printer in and the head will reset itself.
Now because printing has been non existant, you'll need to "Prime" the heads. Use the maintenance software and click head cleaning, when finished do not allow the nozzle check pattern to print. Carry out 3 more head cleans cancelling the nozzle check after each one by clicking [Finish] until 4 cleans have been completed. Then allow the nozzle check pattern to print and it should be back to normal. If not perfect, carry out another "Prime" as above.
Hope this helped.
Nigel
The INK Store
http://www.the-inkstore.co.uk
Dec 14, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Toner prints onto adjoining paper in the mail.
maybe it is excess toner, or the paper type my be the wrong type to use, try some other type
Nov 17, 2008 | Canon imageCLASS D880 All-In-One Laser...
INSIDE MESSAGE ON GREETING CARD
Your card will fold to make an inside and outside once folded, but is seen in a page layout app differently.
Take a sheet of paper and fold it in half to represent the card you will be making.
Now open it up and lay it down on a table, with the inside of the card face down.
The outside back of the card should now be on your left, and the front of the card is on the right. Use a pencil or pen to mark it as such, if you need to.
Now when you do your card layout, the cover art and text should be on the right side of the page you create in the application.
If you flip the card over, so that the inside is now facing you, you are looking at the inside of the card.
Usually, the text and signature areas would be on the right side of this page, as well.
Now, use that same guidance when you work on 'page 2' of your document. Add the text to the right side of your page, so it will be on the right inside panel after you print and fold the card.
The final step is to print it out so that the inside and outside are in the correct orientation to each other.
Be sure to feed the paper such that the top of the card is facing the same side of the paper tray when you prnt both sides. (I sometimes make a light mark in pencil which can be erasd, to be sure it goes in the right direction, since this step is easily messed up.)
Good luck.
DigiChick
Jun 09, 2008 | Cosmi Print Perfect Platinum
Misalignment messing up paper edge and printing
I would says check the fuser assembly for the folding the paper problem and the text tilting is a scanner/laser issue.
carefully check the paper path for anything blocking the way.
print a test page and open the lid when the paper is inside to stop it, inspect the paper to see if it's folded and also see the image on the paper to see if it's ok before reaching the fuser
hope this helps
Jan 04, 2008 | HP LaserJet 4p Printer
HP Deskjet 840 InkJet Printer Logo
27 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
