My washing machine leaves little orange spots on my clothes
  • 770 Answers
Sounds like iron content in your water supply. Are you on a well? Possible solution, in line filter on supply line from the wall to the washer. Is the problem on hot or cold or both?
Posted on Jun 21, 2009
Leaving detergent spots. the machine fills up with water washes drains leaves detergent spots on clothes
If you dissolve the detergent in a bucket of water before adding it to the clothes you wont get this problem.
Nov 14, 2011 | Crosley CAWC529JQ Top Load Washer
My washing machine leaves little spots/dots of rust on my clothes...help?
if this is a top loader, there is a seal that seals your agator shaft from water going down and oily grease from comming up. if you remove your agitater and have excessive play in your shaft you may need seals
Sep 21, 2011 | Washing Machines
My washer leaves oil spots on my clothes
The only place where oil can enter the wash would be if the bearing seals have failed. It's a major repair, and the entire machine has to be taken apart to replace the bearing and seal.
Jul 30, 2010 | Kenmore HE2 Plus Front Load Washer
Leaving brown stains on clothes, messing them up,
If it isn't rust, I suspect cotton can decompose if moist for a long time (in the laundry or machine), causing brown spots. In that case, the spots probably cannot be removed. Or can they?
May 09, 2010 | Washing Machines
Leaving black residue (spots) on clothing
Black spots usually come from the agitator shaft bearing seal which will, when worn, allow oil from the transmission to seep into the wash. Replace the seal, and maybe the upper bearing if the shaft itself will move visibly from side to side in various directions. If the machine is still under warranty, take advantage. Hope this helps!
Apr 12, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My zanussi washing machine is leaving little black spots and holes in my clothes why?
well my washing machines is make loud nosies ???? any ideas what wrong
Feb 14, 2010 | Zanussi Washing Machines
Clothes and our towels have an orange discoloration
The orange spots are caused by benzoyl peroxide that is used in some facial cleaners.
Jul 18, 2009 | Kenmore Washing Machines
Black spots floating on top of water
the top seal in the transmission is bad causing oil to get inside you will need to replace the trans but it will be cheaper to buy a new washer
Jul 12, 2009 | GE Profile 3.5 Cu. Ft. King-Size Capacity...
Greesey Spots.........
looks like the grease would be coming from the shaft at the middle of the tub. that would be the only source of grease in that area.you need to remove the whole drum to look at it.
Feb 19, 2008 | Washing Machines
Wasing machine leaves rust spots on clothes.
check the basket of the machine for rust spots on the basket if thats the case the basket should have a 10 year warranty depending on the age marks are either caused from that or the dryer. if its frigidaire the dryer then the front seals probably need to be changed make sure to find out exactly which machine its coming from
Mar 18, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
247 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
