Question about GE (PSS26MSRSS) Side by Side Refrigerator
Snow build up inside the dispenser
Have a GE side by side refrigerator, model #gsh25kgmdbb, purchased in 2002.
Frost is building up inside the door of the ice dispenser,
What is going wrong and how can it be fixed?
Thanks.
  • geozombek Jun 21, 2009
    Door is not opened very much. Believe that air is getting in, because the flap does not close properly, between the door and the freezer, where the ice comes through the door.
  • k-dawwg May 11, 2010
    frost will only build up in a freezer if the door is left open too long or if there is air getting into it constantly
  • 614 Answers
There is only so much you can do. But the problem is the gasket inside that seals around the opening where your ice is dispenses is bad. You need a service tech to replace gasket. If you want to try get the model and serial number and take it to an Appliance parts house and tell them you want dispenser seal gasket. You just tell them what its doing and most of them know exactly what you want. Rus
Posted on Jun 21, 2009
Refrigerator side not cooling. The freezer works fine. Its age is over ten years old. Model GE TFX22R.
Is there any frost build up on the freezer panel? If not, this could be a damper door issue. Check to see if air is coming from the damper, this is the vent inside the back left-corner of the fresh food side, assuming the evap fan is running. If you feel nothing, it more than likely is your damper door.
If you have frost build up, we're talking about a defrost issue then. Let me know!
Mar 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
FROST BUILD UP ON ICE STORAGE BIN AND INSIDE OF
Most times this is caused by the dispenser door not shutting all the way. This causes moist air to be drawn in through the opening and the moisture will freeze in that area and also cause the dispenser door to have even more problems closing. Check the door and get me your model number so I can list the parts that are most likely causing this, Thanks Sea Breeze
Oct 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
Oct 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice dispenser frost build up - Amana refrigirator
This sounds like your ice may be melting and freezing around the chute. You may need to replace that rubber gasket on the chute. Otherwise, if you use a lot of crushed ice, that will build up badly on the chute and you can manually clean that off. I hope this helps you!
Aug 14, 2009 | Amana 25.8 cu. ft. Side-by-Side...
GE profile Artica side by side. I am getting a frost build up
Sounds like the dispensor flap is not closing completely , pulling outside air in . Using a flashlight on the outside of the flap , look inside to see if any light is visible . If so , then the ice flap plunger and solenoid will have to be replaced . Also , excessive crushed ice can also cause frosting .
Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
The ice dispenser door does not close all the way, and frost building up inside.
You are sure about the model number listed above your post? There are many versions of that model so I just need to confirm. Has the fresh food compartment begun to warm up slightly? Is frost building up on back freezer wall indicating a defrost problem. That model has control boards that make your refrigerator more efficient. If you need more help I will give you my email address so we can communicate directly, Thanks, Sea Breeze
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Excessive frost build up inside the freezer
Your problem is not a recall it is the fan and how many items you have in your freezer. Is it stuffed pretty full?
Jun 01, 2009 | GE PFS22SISSS Stainless Steel French Door...
Frost building up inside freezer.
Hi: Make sure your vents are not blocked by too much product in the freezer. When you changed the heater did you take a hair dryer to the back to make sure the initial blockage of frost and ice was removed as that will still block the air flow to the referigator, and cause frost to build? Also if the frost isn't in the back of the freezer but on the food it means there is a bad door seal. Usually the frost will look like snow flakes. The timers are on a circuit board now. And expensive. Ge makes an excellent refrigerator, but the parts are high in price. I hoped this helped. Jeff
May 31, 2009 | GE GSS23QSSS
GE (PSS26MSRSS) Side by Side Refrigerator Logo
201 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
