err 836 means you have changed your recvr to a different dish or LNB's or your missing one or more satellites needed for your installation or programming needs. if this has been in the same location and connected tot he same dish and you dont have sats 105,or 121 listed in the install summary then you will need a technician to check your dish. It could be out of alignment or a faulty LNB.
my sony tv model KV-36XBR400 randomly turns off. When this happens, a red light next to the word...
(More)
my sony tv model KV-36XBR400 randomly turns off. When this happens, a red light next to the word STANDBY lights up. Whats wrong with it?
This dvr keeps showing either dui or du1. Help . I try to set the box to 1080 and it keeps...
(More)
This dvr keeps showing either dui or du1. Help . I try to set the box to 1080 and it keeps defaulting to 480 evry time I turn off and turn back on,
master tv makes a horrible noise for 2-3 mins and when going to and from commercials. 36" tube...
(More)
master tv makes a horrible noise for 2-3 mins and when going to and from commercials. 36" tube with the standard DVR receiver. Tech says it is an electrical problem. Have tried all troubleshooting suggestions.what do you think? also having some audio issued with the HD tv in living room. tech says that is also electrical
TV showed "Problem Detected" with a possible solution of unplugging my unit for 60 secs....
(More)
TV showed "Problem Detected" with a possible solution of unplugging my unit for 60 secs. and allowing it to reboot. I do this routinely (Once a mo), but did it again. This time it cleared ALL recorded items (including protected items) I had 43 hours available for recording. It also Cleared all scheduled timers, and now will not allow me to record if I try to use "Create A timer" or "Create a Scedule". Is my harddrive fried?? (I've had problems with it locking up for about the last 12 months) Dish Network DVR
