Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Same problem with mine...
Starts really slow -- grinding kind of sound. Will finally reach max power if I "bump" it a couple of times. That is, push the handle down raising the front wheels off the ground about 3-4 inches then lowering quickly (thud!). But even once it's reached max power, once I let go of the control handle thing, it winds down instead of instantly stopping like it should.
2 Suggested Answers
  • 313 Answers
SOURCE: Motor has low torque
common complains for electric & cordless mower is that they are not ment for cutting on wet or dump grasses or long tall grasses they will bog down. for this type of unit blade should be extremely sharp. also clean the under the deck so you can better air flow for the blade. if your switch & rectifier are new & in right connection then have you armature check for short circuit..
Posted on Jul 27, 2008
Slow Acceleration
sorry to tell you but I think the car is having a kind of fuel injection problems! Before bringing it to the repair shop can you tell me if when you push the accelerator the car has a kind of tripping,like it wants go and than it is holded from something?
May 29, 2013 | 1997 BMW 5 Series
1999 suzuki quadrunner does not run properly
Sounds like its floodling check the carb for dirt and clean well, check the float is still floating, check for wear on the float valve, seat and seal.replace if nessary.
Jan 27, 2012 | Motorcycles
Good Morning, I have a Lenovo T-60 laptop. The last couple of weeks, when it is cold, when I push the power up switch the hard drive goes on as well as the circle with the Z illuminates but nothing else...
It really depends on what kind of cold you're talking about. External temperature cool enough to produce condensation in the system can really mess your system up. Even to the point of destroying it. It's always good to keep your system above freezing and even above the dewpoint of where ever you're located.
If you're talking about cold being just starting the computer from any temperature from an "off" power mode to "on" then you could have a video issue. You can check your Event Viewer when it finally powers up to get more info on what caused the problem.
Sep 05, 2017 | Lenovo Thinkpad T60 Notebook
I have a '96 samsung 25" tube tv. model # TXE2546 - series # 3CAG700429. when i turn it on it has always made a click sound a couple of seconds afterwards. the "power & timer" led light flashes about...
This problems the FBT-the Flyback Transformer have cold solders.Must resolders the FBT.The right side wall of the FBT-the "H" horizontal transistor,must be also resolder too.
Oct 18, 2010 | Samsung TXJ2754 27" TV
Good day everyone. A couple times when I had tried to start my car I had heard this kind of grinding sound and the car shook a little bit. Trying to get to the bottom of this problem I started my car about...
you should be fine. the grinding could have been a bad spot on your flywheel ring gear causing the starter to not fully engage thus making the grinding sound.
Feb 11, 2010 | 1998 Toyota Camry
2001 Saturn Sl2 wont run after warmed up
SOUNDS LIKE YOUR CATALYTIC CONVERTER IS DYING
Dec 28, 2009 | 2001 Saturn SL
Stuck on Demo Mode
Mine did the same thing, I just took the face plate off and replaced it a couple times, and magically a couple days later it starts working. It does this to me at least once a month, its very irritating. Apparently its a common problem for this model, and as of yet I haven't found any other way to fix it except just waiting for it to start working again. I've decided to scrap mine and buy another player.
Sep 08, 2009 | Sony CDX-R3300 CD Player
Clunking noise in front end of harley
would guess that they are not bottoming out, they are topping out. doubt that you get them to full compression on bumps or braking would really be a bad experience, it's more likely that after compression on a bump, the forks spring back out as far as they will go and reach the end of their travel, it's because they aren't very sporty forks and lack enough rebound damping. I have a 2008 1200 sportster and it does it. cure would be maybe thicker oil in forks to slow up the rebound but would also slow the up stroke over bumps. you can get just about evey accessory for a Harley so there's probably a kit available to fix the damping.
Jul 08, 2009 | 2006 Harley Davidson FXDBI Street Bob
KTM MXC 400 dies and don't know what kind of oil to use
Sounds like a fuel problem. Try replacing the fuel filter.
Check all the lines and the tank vent.
Jun 11, 2009 | 2002 KTM MXC 400 Racing
Hi! I have an Indesit W84TX washing machine. Lately, it has stopped working every time it reaches the rinse cycle. It seems to rinse and drain just one time before the process stops and the settings dial...
Actually, while the settings dial spins, there is also a kind of grinding/clicking sound from down where the drain port is. I checked it and there is no filter there when I open it.
Apr 05, 2009 | Indesit WA 115 Front Load Washer
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
69 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
