Pls help me... i can print but the image are not aligned
I had a graphic/image that is aligned very well in my file but when i print it. It's not aligned. For i can explain what i see in my print out - it slides down. I even draw a line (a vector line) to check if its just the image that has a deffect. but it still didn't work out straight. And i can't do anything about it though i check the set up of the printer and the properties as well. Can somebody please help me? advise me if theres any solution for this. Thank you!
The printed output is fuzzy, blurry, or grainy, or the edges of objects in the images are jagged.
Solution
Follow these steps until the issue is resolved.
Step one: Check your paper
Many papers have printing and non-printing sides. Load the paper with the printing side down.
Use
the correct paper type for the project. For everyday documents, plain
paper works well. For documents with dense printing, such as
high-contrast graphics or photographs, use HP Advanced paper for the
best results.
If
these steps do not help, try a different paper. Ink might not bleed as
easily on heavier paper. Paper that does not accept ink well is also
prone to bleeding and smearing. HP designs its inks and papers to work
together.
Step two: Check the settings
In the program being used for printing, click File
, and then click Print
The Print
window opens.
Make sure the appropriate product is selected, and then click Preferences
or Properties
The Preferences/Properties
window opens.
Click the Printing Shortcuts
tab.
Consider modifying some or all of the options in the Printing Shortcuts
menu to increase print quality.
Print quality
: If the quality of the printouts is not acceptable, try increasing the
print quality. To print more quickly, try decreasing the print quality.
Paper type
: If one of the options matches the paper type exactly, select it instead of Automatic
Paper size
: Make sure that this option matches the paper loaded in the product.
To see additional options, click the Advanced
tab, and then click Advanced Features
The Advanced Features
window opens. Consider changing the following option:
Ink volume
: Adjust the amount of ink that prints on a page. For lighter images
(less ink), drag the slider to the left. For darker images (more ink),
drag the slider to the right. The lighter the ink volume, the more
quickly the printout dries.
Step three: Check image resolution
Make
sure that the image file has enough resolution for the size of the
printed picture. Although many photo applications can enlarge an image
or part of an image to any size, eventually the individual pixels become
visible and the whole image looks blurry.
Here are some general guidelines for image file resolutions:
94 pixels per cm (240 pixels per inch) for images to print on smaller format photo paper, such as 10 x 15 cm (4 x 6 inch)
117 pixels per cm (300 pixels per inch) or higher for larger format photo papers
Lower resolutions might produce acceptable images when printed on rough-textured paper
Step four: Align the cartridges
If
the previous steps have not improved the appearance of the printout,
align the cartridges. See the user guide for alignment instructions.
Solution
Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
In the program being used for printing, click File , and then click Print .
The Print window opens.
Make sure the appropriate product is selected, and then click Preferences or Properties .
The Preferences/Properties window opens.
Click the Printing Shortcuts tab.
Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
Paper size : Make sure that this option matches the paper loaded in the product.
To see additional options, click the Advanced tab, and then click Advanced Features .
The Advanced Features window opens. Consider changing the following option:
Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry.
If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions.
PSC 1600 User guide:
http://h10032.www1.hp.com/ctg/Manual/c00276605.pdfClick on this link or copy and paste the complete link into your browser. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
I had the exact same problem and couldnt figure out what was going on...but I had a freak fix. I don't know how, but when I installed disc 4 (Picture It! 2000 Setup and Picture Disc) and disc 5 (Additional Art), I was able to access the program again. Hope this helps!
I've printed images over 500kb. Can you print a small image? If not, perhaps the driver is the problem.
If you're trying to send a text file of IPL commands to the printer, set up a Generic Text printer driver, to to send the file as ascii characters instead of as a graphic image. You can set this up in addition to your Intermec driver.
Go to Printers and Faxes, Add Printer, Next, Select the Port, Select "Generic" Manufacturer, "Generic / Text Only" Printer, and give it a name like "Text". Cycle the printer power to clear previous attempts, then print the file to this printer name.
