VCRs
Problem for VCRs
Generic problem for all VCRs
Magnavox msd804 vcr/dvd combo
By bob515 on Nov 03, 2007
vcr tried to eat several tapes it would either eject properly or leave tape routed through all rollers but, after taking cover off and watching cylindrical head was turning and engaging etc... ;. Tape spindles would rotate about 10 degrees and then would get eject message on screen; but tape would not come out unless power turned off. After carefully watching tapes in and out and messing with tape entry mechanisms; noticed that the rubber coated roller mechanism which engages on the side where the conical pin fits in the tape had more resistance than what i thought was normal. Why did this happen; after several, well many cycles of unpluuging and plugging up and many different tapes the problem resolved itself for now. whewww! at least it did not eat tapes up completely like old machines, just wrinkled section around rollers.
What is the most likely cause of this problem and how can i be sure to avoid creating the same situation again.
Thanks! RT Smyrna, GA
Best Solution
posted on Nov 05, 2007
Helpful)
dodgecharger
Rank: Wiz
Rating: 83%, 328 votes
I think what you are referring to is the pinch roller. This roller sits at the right side of the mechanism, and in play mode, presses the tape up against the capstan shaft. These pull the tape through the machine at a precise regulated speed. If the roller isn't being engaged or the capstan isn't turning, then these conditions need to be corrected. Does the capstan turn freely? How about the noted roller? Perhaps lubricant has dried/hardened/gotten sticky...
There is electronic circuitry for the capstan motor (a direct drive type motor integrated on the underneath side. Something could be awry with this circuitry.
There is a drive clutch mechanism which could also be defective. This drive clutch assembly sits in between & swivels between the supply and takeup spindle, depending on whether VCR is in Play/FFWD or REW. In the Play/FFWD, it is engaging the right spindle (takeup) and in REW the left spindle (supply). If this is what you are describing, perhaps this clutch unit needs replacement or the grease at its pivot is hardened/sticky.
Most VCRs of the last 10+ years don't use a rubber tired drive (very common on late '80s VCRs), rather a gear toothed drive.
Beyond a simple mechanical problem, repair might not be economical feasible. Most VCRs of the last 10+ years are poor quality, disposable, unlike the machines of the '80s and early '90s, which were built like tanks comparitively speaking.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for VCRs
Questions and Unsolved Problems for VCRs
Answer
after the retuneing the tv the recorder does not show the clock as it did before the retune
Answer
The head on the mini dvr is not working can I replace the entire mini drive
Answer
The timer will not shut off and did not record the show as it was set up.
Answer
need the codes for use on a univeral remote control for vhs dvd combo jvc hrxv1
Answer
Humax PVR-9150T update message on screen
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top VCRs Experts
Top Audio & Video Equipment Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
