Question about Husqvarna Rose
Same problem with Rose
Was serviced 2 times and just got worse after the service.
how do you open the top part?
    Novelist:
  • Husqvarna Expert
  • 371 Answers
Not sure what you are asking but I would find another service technician - a certified Husqvarna Viking service technician. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Posted on Feb 13, 2010
  • BLMoonlight
    BLMoonlight Apr 26, 2011
    Some of us Rose owners can tear apart, repair, time and maintain a commercial single-head, but cannot figure out how to remove the top case of the Rose machine without fear of cracking it. When one pays $2K for something they should receive a REPAIR manual at least for the purpose of cleaning out the lint. It cost me $100 to have a certified technician remove a few strands of thread that accidentally got caught up inside. This is so very very wrong. And for this reason, it will be the last Husqvarna I will ever buy.
Need a service manual for a singer xl 400
Service manuals are generally not available since they were intended only for technicians. You may be able to locate one by searching:
Make Model manual
or
Make Model service manual
Feb 28, 2018 | Singer Sewing Machines
On my husqvarna rose when i press on the foot pedal it just beeps and indicates the foot isn,t down. it is. No matter if its up or down it will not start sewing. please help.
The Rose has a spring that activates a sensor that detects when the foot is up or down and yours has apparently broken. You will probably need to find an authorized service center to replace it. Not too many shops will know what to do or which part it is.
Best Wishes
Aug 10, 2010 | Husqvarna Rose
Bobbin is not threading correctly
It could be hook and needle timing. Suggest it be serviced by an authorized Husqvarna Viking service technician. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Jan 24, 2010 | Husqvarna Rose
Embroidery not working
If still an issue, suggest you visit an authorized Husqvarna Viking dealer for assistance. They are usually eager to help. It sounds like it may be time for the machine to be serviced. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Dec 14, 2009 | Husqvarna Rose
My embroidery unit on the Rose squeaks loudly when in use. Can I oil it? Does it need servicing?
Typically does not need oiling but if you do, use Tri-Flow oil available from most bicycle shops. But it would highly recommend you take it for service at an authorized Husqvarna Viking service technician. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Nov 18, 2009 | Husqvarna Rose
After a few stitches my machine quits
The problem you are having is with the sensor on the top tension unit. There is a sensor that registers the movement of the spring which lets the machine know that it's sewing. When the spring either sticks or the sensor moves out of position because of vibration, the machine "thinks" that the top thread is broken. The machine needs to be taken apart and the top tension spring checked to see if it still has enough pressure to return to it's starting position, or to see if the sensor is in it's correct position. A trip to your service tech is required
Jul 04, 2009 | Husqvarna Rose
Will not sew more than a few stitches.
remove throat plate and check under and around the bobbin case for stray thread.
Feb 19, 2009 | Husqvarna Rose
Husqvarna Rose embroidery unit stopping mid picture.
Could be the design you're trying to stitch out is eroded. Try rewriting the design to the card and see if that helps. If not, take your machine along with the embroidery unit, peddle, hoops, etc. to your tech for a once over. It may just need an adjustment.
Jan 02, 2009 | Husqvarna Rose
My machine Bernina 830 does not run.
Hi Rose Mary,
I'm assuming you are talking about the original Bernina 830 (their newest machine is also an 830!)
If you've not had your machine professionally serviced in awhile, it could be as simple as a good, thorough cleaning and adjusting. Your machine should be professionally serviced about every 1-2 years....not a bargain service that blows out the dust and puts oil on the hook, but a service that checks all the gears for wear, adjustments, hook timing, feed timing, grease for the gears (if required), removes lint build-up deep in the machine - very thorough.
There are various gears in the 830 that control these functions. It sounds as if one of the gears may be either broken or jammed. Unfortunately, unless you are trained in machine repair, this isn't something you should attempt. When gears are replaced or adjusted, generally the timing of the machine must be reset as well.
We would recommend that you take your Bernina to your nearest authorized Bernina dealer (they'll be trained on your specific machine and have easy access to any parts that may be needed).
If you do not know a dealer in your area, you can search on the Bernina website.
The original Bernina 830 was one of the greatest models Bernina has made and is well worth putting the money into keeping it running. Great machine!
Hope this helps narrow down what may be happening.
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Nov 29, 2008 | Sewing Machines
Mc 5700 problem
Check for loose threads or fluff in upper tension unit and bobbin case tension gauged to 14g resistence. Otherwise, service time I'm afraid. Have it serviced by an authorized Husqvarna Viking Service Technician. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Feb 07, 2008 | Husqvarna Rose
Sewing Machines Logo
77 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
