Question about Samsung HC-P4363W 43 in. TV/DVD Combo
Seperated colors Hi, thank you for looking at this. After our move, our TV?s colors specially blue and Red are not lining up properly. what should i do? I looked for different settings to get them aligned, but could not get them lined up? Can you help? Thanks in advance for your time :) Regards,Blur mine is doing the same way. yellow: centered, blue: top right of yellow, red: bottom left of yellow. screen has curve at top and bottom. if any one knows what to do please let me know
  • 143 Answers
Re: seperated colors
This is a common problem you have bad solder connections on the convergenc ics solder them back if this does not fix the problem then replace them k
Posted on Nov 03, 2007
0 characters
3 Points
All lines of convergence is wrong who I can restart adjusments?
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
You can see some more examples and find a fix using this link on Fixya
Apr 04, 2011 | Samsung HC-P4363W 43 in. TV/DVD Combo
Color on the screen
Convergence is dead.Know how to solders?Replaced 2 convergence ICS and some or all it resistors.Tries websites Tv repair, to repair it ur self.The shop will cost U $300 for parts and labors.
Feb 02, 2010 | RCA D52W135D 52 in. TV/DVD Combo
After moving tiv up some stairs the picture became double in one corner and three color strips overlapped each other. Anything on that side of the screen shows double with three strips of color, green, red...
Ur tv convergence is dead.Must know how to solders?Buy a convergence kit at Tv Repair, to replaced the convergence ICS and all it resistors.The shop will cost u $300 parts and labors.
Nov 30, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
SONY TV MODEL # KP-65WV700 SER.# 9002706
Blue Gun is right side of TV if you look in TV from back side. Part number is as follows..
8-733-663-25 {CRT 07MVC62(B)-L} [KP-65WV700 ONLY]
Mar 13, 2009 | Sony Combination Televisions
Picture has mark please helpfind the source
Anything from video processing to screen drive could cause a problem like this...accordianman
Feb 27, 2008 | Samsung HC-P4363W 43 in. TV/DVD Combo
Resetting TV Color Settings.
Generally 50 is the middle setting. try setting the color bars all to 50 and see what happens.
Jan 21, 2008 | RCA T19408 19 in. TV/VCR Combo
Colour distortion
Your screen mask may have become magnetized. This will require that you have the CRT degaussed. This is done with the use of a degaussing coil. you have to stand about 10 feet from the TV with the coil held vertically and moving it in a circular pattern as you walk towards the tv. Once you are about 1-2 inches from the TV stop and continue the circular pattern for about a three count then backup from the tv still using the circular motion once you are about 10 feet from the tv turn the coil to a horizontal plane and move it away quickly and turn it off. This should degauss the TV and remove the color distortion.
You will need a degaussing coil to perform this task.
Thank you,
Nov 27, 2007 | Combination Televisions
Loss of color - all green
yes! the problem is in the CRT board the RGB colors! you have lost of blue and red! thats why your unit is green! and only green is worked the blue and red is not work! maybe you have lost contact of them! resolder all CRT board to comeback the normal picture!
Sep 28, 2007 | Panasonic PV-C2061 20 in. TV/VCR Combo
No red color on screen
sounds like you cracked the printed cuircut board on the crt drive board or in the video cuircut.. If you know how to solder look very carfully with thw set unpluged for crack on the crt pcb or the main board then scratch off the paint on the little pc traces on both sides of the crack and solder a wire across the trace
Apr 02, 2006 | Hitachi SSF420TR 20 in. TV/VCR/DVD Combo
Samsung HC-P4363W 43 in. TV/DVD Combo Logo
256 people viewed this question
Top Samsung Combination Televisions Experts
sonic boom...
sonic boom...
Steven Wander
Steven Wander
Are you a Samsung Combination Television Expert? Answer questions, earn points and help others
