Question about Intel CELERON 2.66Ghz CPU AND MOTHER BOARD (CPU4266CEL) Motherboard
Pc can shutdown anytime while i useing it
I have realy a big problem
whenever i start my pc.its start window is loading and its shut down
next time i satrt agien and its start by it self without pressing the power botton.
after so many time trying its start and when i doing work on it its shut down by it self.
i cheak all hardware and rejoin it in proper way but he happen all the time.
plz help without changing any hardware
Run "shutdown -a"
Posted on Jul 14, 2009
  • 90 Answers
Make sure it is not overheating and that your ram and processor have a good connection.
Posted on Jun 21, 2009
Toshiba satellite p300 shutdown
You also should change the thermal paste. If you want to play games, please choose normal PC. I think you are asking too much from your laptop.
Apr 15, 2013 | Toshiba Satellite Computers & Internet
Lenovo y450 not shutting down
go to download.com and download ccleaner, this will clean out all junk from the hard drive, next download smart defrag from the same location and defrag the hard drive. Both programs should improve performance, next check to see how many programs start up when windows start, if there are to many it greatly slows the shutdown time and some cases stalls, remove any programs not needed.
Mar 14, 2012 | Lenovo IdeaPad Y450 Notebook
Launch start up repair
Im not sure if you are wanting to get to start-up repair or trying to get rid of it
If you want to access it, Boot system and do a hard nshut down. Restart, you will have the option to Launch start up repair or to start windows normally
If you are getting the option screen unwanted, this is primarily due to improper shutdown.
Whenever you shut down always try to use shutdown, restart options in taskbar.
If in the event you are stuck and need to do a hard shutdown try pressing Ctrl/Alt/del simultaneously
to access task manager.
Here you can end processes hung up or do a proper shutdown
Jun 22, 2011 | Toshiba Satellite Pro L300 Notebook
My pc configuration is motherboard-Asus p5vd2-vm-se hard disk- WD 80 GB 5400rpm processor-dual coreE5300 2.60Ghz OS- windows xp professional problem is my pc is not shutting down its hang on...
use alternate method to shutdown your pc. OR use anti virus.
USING DOS.
  1. goto start' run
  2. type cmd. press enter.
  3. dos window will come.
    type C:\Windows\RUNDLL32.EXE
  4. your window will shutdown.
ALTERNATE METHOD..
  1. In that blank space type { shutdown -s -t 60}
  2. click next > finish
  3. new shortcut icon appear on your desktop.
    DOUBLE CLICK on it to shutdown your pc.
if you have any queries don't hesitate to ask.
if it help, pls rate it. ; )
Oct 12, 2010 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
I just bought a sony VIAIO today and dont knoiw hoiw to shut it down
1. Normal shutdown: select Start - Shut Down - Shut Down
2. System hangs: select Alt-Ctrl-Del and then Shutdown
3. If #2 doesn't work - hold the power button until the screen is dark
Hope this helps.
Aug 17, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Won't shut down completely
If shutting down XP takes what seems to be an inordinate amount of time, here are a couple of steps you can take to speed up the shutdown process:
  • Don't have XP clear your paging file at shutdown. For security reasons, you can have XP clear your paging file (pagefile.sys) of its contents whenever you shut down. Your paging file is used to store temporary files and data, but when your system shuts down, information stays in the file. Some people prefer to have the paging file cleared at shutdown because sensitive information such as unencrypted passwords sometimes ends up in the file. However, clearing the paging file can slow shutdown times significantly, so if extreme security isn't a high priority, you might not want to clear it. To shut down XP without clearing your paging file, run the Registry Editor (click Start > Run, then type regedit in the Run box) and go to:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management
  • Change the value of ClearPageFileAtShutdown to 0. Close the Registry, and restart your computer. Whenever you turn off XP from now on, the paging file won't be cleared, and you should be able to shut down more quickly.
    Note: Please be careful when editing the Registry; you can do a lot of damage here. Don't change or delete anything unless you know exactly what it is.
Apr 13, 2009 | Computers & Internet
My XPS 1530 will not shutdown, it only restarts
Try running chkdsk /r and then restart the computer. to do that, click on START, RUN, in the open field, type 'cmd' and press <enter>. A dos window will open. At the blinking cursor, type 'chkdsk /r' and press <enter>. You will get a message that the drive can't be locked and do you want to run it the next time Windows starts. Type 'y' and press <enter>. Now shutdown the computerand restart it. Chkdsk will run and it may take some time. Depending on your installation, you will see a blue screen that will show the progress. Sometimes the screen will stay black and the hard drive light will flash. That's ok. Let it run until Windows loads. Wait until it is completely loaded and then try shutting it down normally.
Good luck and let me know how it works out.
Feb 07, 2009 | Dell XPS M1530 laptop. TUXEDO BLACK. 15.4"...
Dell model DHM DESKTOP which is stuck while plug in .
Try this out:
1. Hold down the Start (Windows Flag Key) button on your keyboard and press R
2. Type this Command : shutdown.exe -s -f -t 00
This will shutdown all running programs and shutdown windows Instantly.
Optionally you can create a desktop shortcut to do this automatically. Here is how:
1. Right click on any blank space of windows desktop -> New -> Shortcut. A “Create Shortcut” window will open.
2. In the blank, type in:
It means, shutdown and wait for Zero second. Click “Next” button for next step.
3. Type in whatever name you like in the blank. I use “Turn Off PC”. Then, click “Finish” button.
4. You are finished . A new shutdown shortcut has been created on your windows desktop!
Just click on it to shutdown.
Dec 07, 2008 | Dell Dimension 2400 PC Desktop
Laptop won't shut down normally!
You should go to the BIOS and load the default settings. Also, check your device manager to check if all hardware is installed and functioning properly (no conflicts, etc).
Oct 31, 2008 | Acer Aspire 5630 Notebook
Shut down icon
That is a strange problem.
I will help you to create a shortcut on your desktop for that icon, whenever you need to shutdown your computer, just click that shortcut on the icon.
Right click on the Desktop.
Left click on New > Shortcut.
In the Type the location of the item: textbox enter
%windir%\System32\shutdown.exe -s
The -s parameter is used to shut down the computer.
The following two parameters can be used with -s:
-f Forces running applications to close without warning.
-t xx Set timeout for shutdown to xx seconds.
The following command would shut down instantly.
%windir%\System32\shutdown.exe -s -f -t 00
Click the Next > button.
In the Type a name for this shortcut: textbox enter
Shutdown My Computer (or some other name of your choice)
Click the Finish button.
Whenever you want to shutdown your computer, click the shortcut on your desktop that says ShutDown My Computer, and your comptuer will shut down the usual way, the way it used to shutdown.
Actaviosan
Nov 17, 2007 | Compaq Presario 5000 PC Desktop
Intel CELERON 2.66Ghz CPU AND MOTHER BOARD (CPU4266CEL) Motherboard Logo
162 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
