Peavey keyboard amp--Hum takes over all operation
I have an ancient Peavey KB100 (a solid-state, 75watt w/1-15" + piezo amp) which I've used for years (typical Peavey). Lately, after playing for a while, the amp starts to emit a loud hum. The instrument signal can be heard faintly in the background. Disconnecting everything and turning all the pots to 0 doesn't alleviate the problem. The hum remains, even with nothing in or on.
Any ideas on what the prob is, or a possible fix?
Thanks much.
  • craig b nz Nov 14, 2007
    I've got an ART DPS preamp which I've had for a few years.
    It's developed a humming/buzzing sound which is getting in to my recording
    signal, as well as being audible from the unit when switched on. It seems to be
    worse on channel one. I've already taken it to a technician and he said he couldn't
    find anything wrong and thought it must be an earth loop problem. He then told
    me how to confirm if it’s an earthing issue by plugging the unit into a plug
    adapter with no earth pin and seeing if the sound disappears. I've tried this
    but it hasn't changed anything, I even unplugged every electronic device in my
    whole house but it's still humming. I’ve also taken it to my work office in case
    the power in my house is at fault, but it makes no difference. I'm convinced
    there is a problem with the unit, it never used to be like this, it's supposed
    to make my recordings sound better, not worse. Any ideas?
I realise this is a very old thread, but somebody may still be looking for a solution for this amp. There is a very common problem with the original 3-channel, 3 phone-jack version of this amp. ( and indeed, with a lot of amps that hold the main circuit board in place by using the front jacks and controls). over time, the connections to the input jacks fracture as the unit is moved around and subjected to different temperatures. You need to remove the head from the amp, disconnect the speaker wires and the reverb send-return cable, remove the main circuit board by unfastening all the front-panel jacks and controls and removing the 2 screws that hold the left side of the main board in place and the 2 screws that fasten the long aluminum heat-sink to the bottom of the chassis. Then you can pull the board free of the chassis ( if you are careful, you can do this without removing any more wires) ,and re-solder all the jack and pot connections along the front edge of the circuit board. This will last for a while, but does not permanently fix the problem. To fix it permanently, you should replace the 3 board-mounted input jacks with jacks that mount to the front chassis plate instead. They will have to be connected to the main board using shielded wire to keep noise out.
Posted on Apr 18, 2013
  • 31 Answers
Hi There,
Hum can come from all sorts of places in an audio amp system......
The shielding on the input cables may be broken.
An earth somewhere can be broken....which then allows "ground loops" to form and unbalances the earthing...causing HUM....
Your note about reducing the controls to zero and the hum is still there leads me to believe that the power filter capacitors or some other filter capacitor in the DC supplies have dried out.
Capacitors can also go "open" which can cause low level sound and HUM.
The motto is "Capacitors get "old" and cause hums"....
It looks like its time for a full service....the amp has done you very well over the years and its like anything else needs a service now and then to maintian the quality of sound expected...If there is one capacitor showing you its getting "HUMMY" then there will be others in there as well needing replacement....
High heat can kill an amplifier so while its getting a check over there will be checks for other problems in there as well..Hot running resistors which can dry out adjacent Capacitors...
Cheers for now YUBEUT
Posted on Nov 03, 2007
Peavey KB100 EQ pots what value?
should say on the back of the pot
Mar 02, 2015 | Peavey Music
Peavey PR15D amplifier board. What is the part number of U5. The IC is damaged and can only read the beginning of the part #. Starts with HC.....
You can contact Peavey and they will send you the schematics. If you can tell me a few characters of what is on the chip I might be able to give you a clue. For power amps they often use the LM3886, an eleven lead power amp clamps to a heat sink. For typical small 8 lead op amps the often use 4560's.
Mar 22, 2011 | Peavey Electronics Peavey PR15D 15" 200...
Kb100 peavey amp guide settings fot this instrument
try this:
If that link does not work,here is a general link to that area where you can download the PDF docs for manuals.
Sep 20, 2009 | Peavey Music
The volume knob has broken off at the base on chan 1 of my peavey KB100 keyboard amplifier. part needs replacing in NW London?
Was it the know or the pot? The pot is the metal(sometimes plastic) shaft with a nut securing it to the enclosure.
Here is your nearest registered Peavey service center.
This could also be repaired by someone with electronics knowledge. Just would need to know the pot taper and resistance. This would be on the front of the pot on the same side as the shaft. The enclosure would need to be taken apart.
Jun 21, 2009 | Peavey VTB1 1-Channel Amplifier
A peavey special 130 guitar amp with excessive hum
I used to have one of these years ago!
What do you mean when you say 'switch to the off position'? Do you mean it hums when switched off?
Because the sound does not fully follow volume, it is likely a bad connection or power filter capacitor is not working.
Either way, it means a trip to a repair shop. There is nothing in there you can fix unless you are a repairman. Your local music shop should be able to coordinate a repair.
If this amplifier is like the 1983 version I had, its built like a tank and the fix should be easy.
Hope this helps!
Mar 19, 2009 | Audio Players & Recorders
Picture warping
Yes this is a typical convergence problem, and there are two convergence Amp Ic's that are in need of replacing. If you have any solid state repair experience, you may be able to replace these IC's yourself, but if you do not have any solid state printed circuit board experience, play it safe and call in a tech to assist you in this repair.
Jul 14, 2007 | Mitsubishi WS-65807 65" Rear Projection...
1,258 people viewed this question
