SOURCE: TOSHIBA TP4688 Rear Proj. TV
Look for F850,F851 black soldered in micro fuses near board edge...usually, convergence circuit is the issue......
Be sure to solder wire jumpers 008,010,017,048,600....any bad
connect can cause fuse to blow again.........T.
SOURCE: Mitsubishi Medallion does this
may be there will be some loose connections inside you need to find and should solter it ............if warranty is there go for it...................because repairing by own will void warranty
SOURCE: Someone please help
Good Day;
Two things normally happens after a L storm:1.) One must unplug TV for 5 minutes, then plug back in. 2.) Main glass fuse out, will be near a/c cord. 3.( Power regulator IC may be out. Try these first.
Good Luck!
SOURCE: my big screen tv
Those are the two 5amp pico fuses that go out when the convergenec Ics go out on a mitsubishi. You can get the ICs and pico fuses at the following link. If youre not sure which ICs you need leave them a email with your model nuber.Heres the link
http://servicemanuals.vstore.ca/
SOURCE: Mitsubishi Medallion HD 1080 model ws-48413
my mitsubishi medallion tv wont power on.
all I get is a blinking light. How can this be fixed
