Question about Canon CanoScan 8000F Flatbed Scanner
Try to clean the scanner's glasss. it's may get dirty
  • 10 Answers
Posted on Jun 22, 2009
When using the auto feed, copies come out with black streaks down center of page
If you only get streaks when using the automatic document feeder, then in most cases it is dirt on the scanner glass. You do not state model but if you can also scan flat objects, trying copying a piece of paper that way. If that copy comes out fine, then you definitely have dirty glasss, if that copy has streaks you either have dirt on the scanner itself or a faulty scanner unit.
May 08, 2015 | Office Equipment & Supplies
How to check exposure lamp on ricoh sc101?
Clean the true white on the slit glass housing. Check for a dirty scanner mirror or that the scanner mirror is out of position. Also, check if the scanner is blocked or if the dirty white plate underneath the glass is obstructed. Try cleaning the glass with water. To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
Jul 15, 2014 | Ricoh Aficio 1013 All-In-One Laser Printer
Sharp IR 2016 platine glass dirty
The cover plate is above the glass white surface of the scanner. If this is the same dirty stains will come out on copies.
The glass must be clean.
By feeding the original documents through the ADF, the scanner lamp is no longer the path to scan, the ADF is responsible for passing the original document over the scanner, while it remains still placed on the side under a thin glass is to a large glass side. This also must be clean, otherwise you will be black lines on each point or spot on the glass.
Good luck ...
Feb 28, 2012 | Office Equipment & Supplies
My dr-x10c scanner gives an P007 error code i have tried cleaning the rollers but the error stills keeps coming back. do you think that it's time ireplace mty exchange roller kit???
Solution: I had the same error P007 on a Canon Scanner. Switched off the scanner, Opened the scanner. Located all of the sensors. Sprayed Platenclene spray and used a soft cloth and cotton buds to clean the sensors. Switched back on the scanner and the error was gone and its scanning perfectly. The error P007 is a result of dirty sensors!
Nov 19, 2010 | Canon Office Equipment & Supplies
Is printing with a large black stripe down the side of the page, getting worse and worse as we copy
Please try cleaning the glasss surface where you place paper for copying
Oct 13, 2010 | Gestetner Copier
Sharp al-1631 error L1
Your copy lamp is faulty or scanner drive is not moving. Check the lamp and replace if not lighting.
If its the scanner, unlock the scanner lock above the paper exit tray.
Nov 25, 2009 | Sharp AL 1631 Copier
Black pages
Try to copy a document. If the copy comes out black then the the scanner is dirty. Clean the scanner glass (products on the market that clean by sending through the scanner) and try to copy again. If after cleaning the scanner, the copy is still black you have a scanner issue and the laser/scanner unit will need replacement. Best of luck and please post back with any questions or just to rate the solution.
Greg
Aug 10, 2009 | Brother IntelliFAX 4100 Laser Fax
Ricoh Aficio 1232 c SC-101 and SC-142 codes what do they mean?
It is a scanner problem....could be lamp, lens defect, or as simple as the lamp, and lirrors undeer the glass being very dirty, because the code refers to the 'white level"....a calibration that the machine does when switched on. It could be as simple as, the white plate which is underneath the left scale (beside the main contact glass) is dirty (or missing). Try cleaning this (2 screws), and while you're at it, try removing the main contact glass (3 more screws)and cleaning it as well as the scanner bulb, and mirrors (slide scanner to the right with the machine unplugged).
Good Luck
Mar 02, 2009 | Ricoh Aficio 2015 Copier
WE HAVE A PANASONIC FAX MACHINE MODEL UF-4100 AND WHEN I AM TRYING TO COPY A DOCUMANT ON IT THE DOCUMENT PRINT COMPLETLEY BLACK?
ok no prblem check your scanner if it is dirty just clean scanner.dirty scanner may cause black copy .or scanner is dead replace it with a new one.by mian jee
Dec 11, 2008 | Office Equipment & Supplies
Coppier Problem
The trouble is that the scanner assembly can't find its "home" station. Here is the most common solution. There is a reflective white stipe under the scanner glass that the scanner looks for. If the stripe is dirty, or if the scanner mirrors are dirty, the scanner won't sense its location, and cause a "scanner error". A qualified technician should be able to clean the assembly. The other option is to replace the scanner assembly. I hope this helps.
Feb 27, 2007 | HP LaserJet 3330MFP All-In-One Printer
Canon CanoScan 8000F Flatbed Scanner Logo
109 people viewed this question
old marine
old marine
