I need a circuit diagram for a Behringer PMX 2000 to repair a left hand power output problem
  • keith5555uk Jun 21, 2009
    Many thanks for a quick responce, the circuit is a great help ..........
  • Rommel Cana
    Rommel Cana May 11, 2010
    what seems to be your problem on the power output? is it the part number? or something else?
  • 35 Answers
Here you go..
I posted your schematic on my temporary web files site; so,
download and save within the next two weeks cause it might go away..
http://ca.geocities.com/artiedc/PMX2000.pdf
Ed
Posted on Jun 21, 2009
Behringer Vintiger GM110 guitar amplifier Output pcb board
You should be able to get a diagram from the company itself and the circuit board can either be purchased from the manufacturer itself or they can tell you who to call.
Here is the manufacturer's number
BEHRINGER USA beusa_t.jpgBEHRINGER USA Inc.
18912 North Creek Parkway, Suite 200
Bothell, WA 98011
Tel.: +1 425 672 0816
you can also try their online support at
http://www.behringer.com/05_support/webform_support.cfm?lang=ENG
but I would just call them, it would be much easier
Let me know if you need any further help or if they couldn't help you and I will let you know who else might have what you need.
good luck
May 23, 2008 | Behringer Audio Players & Recorders
How do i hook up my laptop and my tablet to a behringer Europower PMX 2000
Easy to do - just get a patch cord that has a stereo 1/8" plug on one end and two phono (RCA) plugs on the other end. Plug the phono plugs into the "Tape IN" jacks on the mixer and use the "Tape" volume to adjust the sound level. It's best to turn your laptop or tablet volume up to maximum, then adjust the volume on the mixer.
Jan 15, 2015 | Behringer Audio Players & Recorders
Will my Behringer amp purchased in the USA work in Australia
You will probably need a voltage converter. Unless you purchased the general export model with a switchable voltage power supply, your PMX2000 will have the power supply for the 120V 60 Hz electrical mains and a 10A H fuse. To confirm this, look on the back of the amp.
I wish that I had better news for you.
Jul 19, 2013 | Behringer Audio Players & Recorders
Behringer sx3242fx not working .i need circuit diagram .
Behringer will not release schematics unless you are an authorized service agent... however, sometimes you can make do with the few schematics floating around... What is the problem with the unit? They typically use a switching power supply and the schematics of those aree usually similar enough to repair them.
Sep 09, 2011 | Behringer Sx3242fx Eurodesk 32-channel...
No output from the mains on the europower pmx 2000. The lights flash indicating an input signal, and the monitor outputs still work.
When using the BRIDGE loudspeaker output, u should NEVER use any of the other two connectors (RIGHT/MONO MAIN and LEFT/MONITOR) at the same time. If u know this and have not done it, it is possible and very likely that u have burnt the power amp section. get it fixed if u have no idea. it should not be hard for any qualified tech. (monitor ouput does not go through the power amp)
Mar 13, 2010 | Audio Players & Recorders
Behringer pmx 2000 missing knob
If the shaft broke, then you will have to replace the whole encoder for it. You cannot glue a shaft and expect it to hold.
Mar 17, 2009 | Behringer POWERED MIXER, 20 CH, 400 WTS...
BEHRINGER EUROPOWER pmx 1000
The voice cancellor switch basically subtracts the left and right signal because the vocalist is usually centered... The noise would likely be in an op amp associated with this feature...
Compare your circuit to a PMH1000. On that unit first thing to check is the two electrolytic caps at the left and right noise cancellor outputs.
There are a wholle bunch of resistors and IC's 48,50,37 are all involved.
Troubleshoot this one with freeze mist (ccircuit cooler). The problem should show up easily by heating and cooling.
Oct 29, 2008 | Behringer POWERED MIXER, 20 CH, 400 WTS...
Behringer PMX 2000 Amplifier
Hi aliciacarol,
The best place to go to get parts for Behringer parts I have found is straight to Behringer themselves, or an agent nearest to you. They are generally inexpensive to buy, and delivery are better than most. Steer your way to your nearest agent to you from the map . If you have any troubles, feel free to get back to me here. Good luck, thanks for using FixYa
regards
Graeme
Feb 23, 2008 | Behringer EUROPOWER EP2500 Amplifier
669 people viewed this question
 Grubhead
Grubhead
