Question about TallyGenicom 8008 Laser Printer
SVC EL ERROR appears on the display - TallyGenicom 8008 Laser Printer
    Novelist:
  • 169 Answers
The SVC EL error on the 8008 indicates an 'ERASE LAMP' error.
The erase lamp in the 8008 is situated below the OPC belt in the printer, as a step to fixing the problem I would suggest removing the OPC belt from the printer, and taking suitable precautions to protect it from light and damage.
Then clean the area under the OPC belt in the printer to remove any stray toner.
Then test the printer, if the problem persists I would recommend having a suitably qualified engineer look at the printer. To check the Erase LED array is connected correctly and is functioning correctly.
Posted on Jun 22, 2009
Ink ribbon el
It uses the IR-87T ink rollers.
Nov 20, 2013 | Texas Instruments TI-5045 SVC Calculator
COMO QUITAR PROTECT ESTEREO KENWOOD KDC-MP642U
En estos modelos quedan grabados los errores de DC en el eeprom y se tiene que limpiar y estos son los pasos para este modelo:
Mientras que el display muestre PROTECT presiona el y sosten el 3 y 6 y luego presiona el RESET mantelos presionados por unos dos o tres segundos y luego suelta el RESET y despues de uno o dos segundos suelta los otros switches.
El display debe mostrar:
DC ERR
Presiona el 1 y el display mostrara
DC1 ERR
Presiona el 1 y sostenlo por par de segundos y el display mostrara
DC1 OK
Presiona el 2 y el display mostrara
DC2 4
Presiona el 2 y sostenlo por un par de segundos y el display mostrara
DC2 0
A este punto el eeprom ya esta limpio y nada mas presiona el RESET y el disply debe mostrar STANDBY
Espero que esta informacion te sea util y avisa si te funiona
Suerte y saludos
Jan 27, 2013 | Kenwood KDC-MP642U
Error code Re EL
i have the same proble with my royal 435dx i thought the error mesage was e1 but ut could be el....did you get a solution? i looked up the manuel online no help and i called their tech support which is outsource and barely understandable....no help
Feb 07, 2012 | Royal 435dx Electronic Cash Register
What is (SVC E9 Error)
Hi there
The error indicated on the 8008, ‘SVC E9’ indicates the printer is not detecting the OPC belt as rotating in the printer. The printer ‘looks’ for two black squires on the left side of the OPC Belt (as viewed from the front of the printer) if the printer does not ‘see’ black squires the printer indicates the SVC E9 error.
If the printer is displaying the SVC E9 error the most likely cause is something to do with the OPC Belt, normally removing the OPC belt from the printer then re-seating the belt would resolve the problem in most cases, as the OPC belt may not be locating correctly in the printer.
Unfortunately you have already removed the OPC Belt from the printer without resolving the problem, it may however be worth removing the OPC belt again and to look at the green reflective surface to see if there any damage or if the green surface is fairly central and is no skewed or bent in any way.
Depending on which position the OPC belt stops in you may see the black squares down the left side of the belt, if you can see these and they don’t look damaged or scratched the printer should detect the OPC belt ok, so the problem may lie with the sensor on the printer its self.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 18, 2010 | TallyGenicom 8008 Laser Printer
My scanner is locked on hypersearch. How do I get
Answer: Hypersearch can only be turned on and off through a limit or direct search. To turn it off, you should do the following: Through Limit Search:
  1. Press PROG, then LIMIT (SRC). Lo and 29.000 MHz appear. 29.000 MHz is the low end of the scanner's range.
  2. Enter the frequency that is the lower limit of the range you want to search (including the decimal point), then press E (SVC).
  3. Press LIMIT (SRC). Hi and 1300.00 MHz appear. 1300.000 MHz is the upper limit of the scanner's range.
  4. Enter the frequency that is the upper limit of the range you want to search (including the decimal point), then press E (SVC) again.
  5. Press \/ to search from the upper to the lower limit or /\ to search from the lower to the upper limit.
  6. While the scanner is searching or is on a transmission, press H/S.
  7. HYPER should disappear from the display.
Through Direct Search:
  1. Press MAN.
  2. Enter the frequency you want to start from using the number keys. (Press . to enter a decimal point). NOTE: To start the search from a frequency already stored in one of your scanner's channels, press MAN or PROG. Then use the number keys to enter the channel number and then press MAN or PROG again. If you enter an invalid frequency, the scanner displays Error. Press MON/CLR (.).
  3. Press \/ to search downward or /\ to search upward from the selected frequency. -d-, SEARCH, and either \/ or /\ appear.
  4. While the scanner is searching or is on a transmission, press H/S.
  5. HYPER should disappear from the display.
May 15, 2009 | Radio Shack Pro-94 Scanner
Kenwood BM200 : error message EL
From the owners english manual:
"E-L or E-S appears in display and machine cannot be turned on: Bread maker is malfunctioning. See “Service and Customer care” section."
Technical: Firstly check that the thermistor securing nut is not loose, and, if there is no evidence of thermal compound, then apply a little to the back of the component. Most times this cures the problem. If the appliance is still intermittent, it will be necessary to replace the thermistor assembly.
May 13, 2009 | Kitchen Appliances - Others
I own a Tally Genicom 8008 Laser printer. From the last print and after it appears the message: SVC E9 ERROR
The error indicated on the 8008, ‘SVC E9’ indicates the printer is not detecting the OPC Belt as rotating in the printer. The printer ‘looks’ for two black squires on the left side of the OPC Belt (as viewed from the front of the printer) if the printer does not ‘see’ black squires the printer indicates the SVC E9 error.
Jan 17, 2009 | TallyGenicom 8008 Laser Printer
Lexmark C500 printer SVC LL ERROR, SVC L1 ERROR
As i'm sure you already know the error means - Laser power is lower than the output limit.
It's probably due to a bad contact on the engine board. If you would like the service manual it can be downloaded from the following link free of charge http://www.eserviceinfo.com/equipment_mfg/Lexmark_22.html any problems come back to me.
Aug 11, 2008 | Lexmark C510n Laser Printer
JBL Error 1
Error one is unique to the disc being inserted into the player.
According to the service manual, this is the exact statement:
Err 1 appears on the display:
This indicates that the disc is dirty, scratched, damaged, incorrect (as in a "burnt" disc), or has been inserted upside down. Clean the disc or insert it correctly.
Toyota CD players are very sesnitive, and the svc manual specifically mentions not to use anything other than "store-bought" CDs.
Jun 03, 2008 | 2001 Toyota Sequoia
Minolta dialta di250
The C0048 error code not exist.Malfunction resetting procedure:
Turn OFF,then ON the power switch or open and close the side cover for all malfunctions except C05XX codes.
Use Trouble reset of the Initial screen to reset all malfunctions.
To right side the touch panel(screen display)near display contrast button exist a little hole (reset switch).Insert a hairpin to touch the switch.
Enter "3" from the 10-key pad when " * " appears at the center on the left side of the screen while the start up screen being displayed.Touch TROUBLE RESET,and EXIT to go back to the basic screen.
May 07, 2008 | Minolta DiALTA Di520 Laser Printer
TallyGenicom 8008 Laser Printer Logo
149 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
none
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
