Question about Tomtom GO 910 GPS Receiver
I have just bought second hand tomtom one (4n00.001) it says 2 put sd card on, any 1 no how much these r? thanks
    President:
  • 778 Answers
You can find 2GB SD (Secure Digital) memory cards for $10.00 or less shipped to the U.S. on eBay. You'll find them at local electronics retailers, they may cost a little more.
Posted on Jun 21, 2009
TRIED TO UPDATE MY TOMTOM GO 710 BUT NOT ENOUGH MEMORY BOUGHT NEW CARD BUT TOM TOM WONT TAKE IT TRANSFERED DATA BACK ON TO OLD CARD BUT TOMTOM WONT TAKE THIS...SHOW TWO CROSSED HAND ON MEMORY CARD...
Just had the same problem..............
I discovered that you must only use an SD card and not an SDHD card.
I bought a bigger SD card (2Gig), installed it and copied the data I wanted without any probs. With the SDHD card I couldn't transfer anything and didn't get any help as to why...(there's a lot to be said for trial & error).
Hope this helps
Jun 09, 2011 | Tomtom GO 710 Car GPS Receiver
Tomtom one (4N00.012) will not load up.
Your particular unit runs it's software from SD-Card. you need to check if the card is not damaged: while unpowered push the SD card to come out insert it in a card reader on your computer and see if it reads it ok, if it ask's you to format it it means it's damaged and should be replaced ( the sd card of your tomtom should be replaced with another SD card which you should buy from tomtom for your particular device not a generic one). if it reads just fine reinsert it and start the device again..And about the reset the correct procedure is: Press and hold the On/Off button until your device restarts. This can take more than fifteen seconds.904537f.gif
You should also install Tomtom Home on your computer, connect the device and update it if al the above failed (with a verified and working SD card inserted) - link for Tomtom Home: Windows, Mac
May 30, 2010 | Tomtom ONE 125 GPS Receiver
Tomtom 1 v3 wont read new sd card help
Take special not of part 6
1. Remove the SD card
The card needs to be formatted properly first that's all,
2. formatting is better done in a card reader.
3. Right click on it and select format select FAT32 as the files system
4. Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
5. You now ned to select your tom tom which will also show as a drive.
6. In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
7. Then just copy ALL the files from the tom tom to your sd card
8. DO NOT USE CUT AND PASTE !
9. Once all the files are on switch off the tom tom and insert the sd card
It should now work
Sep 15, 2009 | Tomtom ONE XL GPS
Red cross on sd card on startup
You can not use a sd card from one TomTom and put it into another TomTom. The operating system on the card is coded for each individual TomTom device. First try doing a reset with the card installed on your dads TomTom. The reset hole is on the bottom of the TomTom marked reset Use a streightened paper clip, insert the paper clip into the hole until you feel a click then hold it in for 20 seconds. If that didn't work and you have a card reader insert your dads sd card into the reader and make a backup of the everything on the sd card. Just copy and paste everything on the card to a folder on the desktop you have created on your desktop. Next delete everything on the sd card EXCEPT the maps and ttgo.bif or ttgo.bak file. Now that you have made a backup and deleted everything on the sd card except for the maps and ttgo.bif or ttgo.bak open TomTom Home. TomTom Home should see your card and install the operating system back onto the sd card. If it doesn't you may have to insert the sd card back into your dads TomTom and connect it to the pc. It may take a few times of doing this to get the latest operating system back onto your dads TomTom. You can do the same for your TomTom, but you cannot use any thing bigger than a 2 gb sd card. Do not get sdhc cards they won't work. This will only put the operating system for your TomTom onto the sd card. When you have installed the operating system onto your device it will say "no maps found", you will have to buy the map from TomTom..
Jun 17, 2009 | Tomtom GO 300 GPS Receiver
Tomtom one will not start up
go to tomtom.com web site then uk then my tomtom login or create a account if you have not registered its free then email them they now have support in uk and offer excellent service and ask the question email is the best way.
you should get a reply within 1 to 2 days also look at their faqs
a couple of things to try
(1) hold reset 20 seconds.
(2)remove sd card then do 20 second reset put sd card back in, hold switch button on untill you get a display then release switch
Jun 10, 2008 | Tomtom ONE GPS Receiver
Tom tom one
Jun 09, 2008 | Tomtom ONE GPS Receiver
SD Card not showing in my Tomtom go 720 to play MP3
If you want to play mp3 songs from sd card then create mp3 folder and place all the songs in side that folder. Now when you go to Juke box menu it will scan all the songs and you will be able to play them the way you want..
Jan 09, 2008 | Tomtom ONE GPS Receiver
Tomtom GO 910 GPS Receiver Logo
224 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
