Question about E-Machines eMachines Desktop PC
I have an emachines 2220 computer and it wont turn on there is a green light on the motherboard but no fan or harddrive movement do i need a new motherboard if so can you tell me where to get one thats quite cheap. Thanks
  • dm_wiles Jun 21, 2009
    It doesn't beep. there is only a green light on the motherboard it won't turn on.
  • 3 Answers
I used to have this problem all I did was plug the comp in somewhere else n it fixed it xD
Posted on May 11, 2011
  • 1,555 Answers
Need not to throw away that much money also. just remove the ram from its slot blow the mother board with a vaccum cleaner. put the rams back and tell me what error or how many beeps u can hear.
Posted on Jun 21, 2009
  • Aruna Singh
    Aruna Singh Jun 21, 2009
    You mean to say there is a green LED on *********** board which is not glowing or there is a green glowing light. Remove the power cord for some time from smps and then reconnect and try if then also nothing happens just check wether smps is working or not just unplug the power supply cord to the motherboard from smps and check the output it should be between 12-18 volts dc. If not getting any voltage or getting too low then your smps needs to be changed
My computer says it has no signal. How can I fix this? When I turn itinerary it says no signal then the green light under my monitor turns orange.
Open cpu cabinet then you can motherboard pull cmos cell from motherboard for 10 seconds then put it back reconnect RAM memory reconnect both connection to harddrive .Make sure motherboard is not ground with cabinet. Then check. Also when you power up the computer press F8 key 5 to 6 times then if you are able to see safe mode and other menu enter in "Enable vga mode" then go to display property and change screen resolution to 1024*768 then apply. Let me know if you need further assistance. Thanks for using FixYa.
Aug 29, 2010 | E-Machines eMachines W2686 PC Desktop
I have a T2893 model that is probably 10 years old. The hard drive just quit on me and I cannot boot back up. It appears completely dead. I changed power plugs to ensure that it was not the power supply. I...
1) Install the harddrive as a slave drive in a known working computer.
2) Install the harddrive into an economical external harddrive enclosure, and plug the USB cable of the enclosure into a known working computer.
[IMHO the better of the two options]
The eMachines T2893 uses an IDE harddrive, (IDE is also referred to as PATA)
This is an example of an IDE external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1337265&CatId=2779
As for the T2893 it could be a bad power supply, and worst case scenario, a bad motherboard also.
Granted the power supply may seem to be working, (Bestec 250 Watt), but it may have a weak voltage power rail.
Enough power to light lights, and maybe spin fans, but not enough for the Processor.
1) ALL the lights use less than 1 Watt of power
2) EACH fan uses 2 to 3 Watts
3) A typical Processor can use 51 to a 125 Watts.
The T2893 comes with an Intel Celeron D 330.
http://en.wikipedia.org/wiki/List_of_intel_celeron_microprocessors#.22Prescott-256.22_.2890_nm.29
The Celeron D 330 can use up to 84 Watts. (Under the heading TDP in the chart )
In essence the harddrive may not be bad.
When you press the Power On button, you are closing a circuit that feeds 5 Volts to the Power Supply. Soft Power On function.
[Brought in, to replace the old style of pressing the plastic Power On button, which in turn presses against a steel rod, which in turn presses against a Power On switch, attached directly to the Power Supply ]
Power goes to the motherboard. The first chipset to receive power, and to initialize is the BIOS chip.
[Chip and Chipset are slang terms to represent I.C. Integrated Circuit]
Bios looks to see what devices are installed, does a Ram Memory count, turns the Processor on, and hands the computer over to the Operating System.
[Windows XP is an example of an O/S]
The operating system is located on the harddrive.
You don't have enough power to turn the Processor on, so there is nothing to process information.
Nothing to find the operating system.
Two of the major faults reported for the T2893, are the Bestec 250 Watt PSU, (Power Supply Unit), and the motherboard.
The primary failure is the Power Supply. When the power supply fails, it has a nasty tendency to take the motherboard with it.
What actions to take, to possibly solve the problem with the T2893, provided the harddrive works?
Suggestions:
1) Test the Power Supply. See if the voltages are correct, and specifically the 12 Volt power.
There are three main voltages.
A) Yellow insulated wires are 12 Volts
B) Red wires are 5 volts
C) Orange wires are 3.3 Volts
ANY Black wire is a Ground wire.
Do you have a multimeter? An economical multimeter can be purchased for around $10 to $12.
(Many stores carry them. An auto parts store is one place)
There is also a power supply tester. Economical versions are around $20.
The 12 Volt power can be 11 to 13 Volts. Anything below 11 Volts, and it's time for a new power supply.
Power supply diagnoses to be good, check the motherboard. Visually look for bad Electrolytic Capacitors.
eMachines are known for using cheap quality Electrolytic Capacitors.
Saves the computer manufacturer money, which they use to sell budget priced computers. (All eMachines are budget computers)
http://www.capacitorlab.com/visible-failures/index.htm
If the motherboard is bad, I have seen replacements offered online.
One motherboard offered had the price of $90.
Now you could be looking at $30 to $50 for a decent replacement Power Supply, and another $90 for a motherboard.
Believe it would be best served to purchase another computer, IMHO.
Have any questions concerning this, please post in a Comment.
Apr 20, 2010 | E-Machines eMachines Desktop PC
Emachine T3958 wont turn on
make shure that the 4 wire plug to ther mother board from power supply is plugged in..other wise try a new power supply
Oct 09, 2009 | E-Machines eMachines Desktop PC
I have a EMachine T6534 which won't start. I shut
I agree...sounds like a power supply problem. Typically a bad power supply will not damage the motherboard. It should still be functional.
Sep 02, 2009 | Computers & Internet
Emachine....uhh...wont turn on.. green light on motherboard. help
well this would be more simple for me since i have more than one pc so first thing i would do is try another power supply if that wont turn it on then i would say mobo, the PSU's of the emachines are **** and dont last too long...
well i would try the PSU first since its cheaper.
good luck
Aug 24, 2009 | Microsoft Windows XP Professional SP2 Full...
No boot, New PS, Green light on MB lights, No Fans running
Bottom line: Either your power supply or (hopefully not) the mother board has gone bad.
Replace power supply (remove old one), take to local independent computer shop, ask them for new unit. Should be around $50.00. - no more. After reinstall, if still no fans, boot, etc. Replace motherboard or buy a new machine. MB's installed probably will run you around $250.00-ish.
Good luck.
gurutim
Mar 21, 2009 | E-Machines eMachines Desktop PC
My pc wont work
Is the power supply fan running? Is the CPU fan running? Do you get any beeps when you power it on? Is the Monitor light green or red/ orange? Please answers these questions first so I can help you. Please don't rate me untill I am through with the answering your questions. I will be more than happy to help but first I need you to answers these questions.
Jun 10, 2008 | E-Machines eMachines Desktop PC
E machine no power
Make sure the RAM is seated, the CPU, any video card and the Power supply is properly connected.
If you power it on, still get no POST (beep at startup from the PC speakers) its time to replace the motherboard.
Feb 01, 2008 | E-Machines eMachines Desktop PC
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
E-Machines eMachines Desktop PC Logo
258 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
