Bmwx 5390 I have a 6.2 inch wide screen monitor bmwx-5390 nitro tv radio only thing show on the screen is the word car with a symbol on the side of it I cant turn the volume up or down its not letting me do nothing
You Need to reset it basically easy way to do that is just turn off the car open your engine cover and unattached the battery for a while and put back the battery connections and check should work.
? 1:36
https://www.youtube.com/watch?v=PHjoXd55mTo
Mar 11, 2013 - Uploaded by colorado4wheeling
Looking online i couldnt find anything about this unit , except for the stock ... Looking at the devic ...
From what I have read about this EQ it is just for subsonic frequencies. You really don't want to run your components through this EQ. Leave the components running off of the 4 channel amp and your sub box on the two channel with the EQ in series between your head unit and the sub amp.
The only way that would happen is if your pink wire is still somehow connected to the e-brake. You need to completely remove this wire from anything and only connect it to ground.
dude buy a new system for one never heard of a nitro and for two if you dont know **** about systems and your buying a beamer then you should have enough money to get a new better system installed
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD By dmorrow54 on Nov 13, 2007 Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me. Add a comment
c7carl
5 minutes ago
WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use. Comment:
