Question about Whirlpool 18.2 cu. ft. Top Freezer Refrigerator ET18PKXG
Water pools under the crisper drawers and looks as if it is draining from the upper freezer down the side of the refrig door, looks like the little hole under the crisper is clogged with rust?? It is a old whirlpool top freezer/ frig
    Scholar:
  • 48 Answers
Mine clogs with a soft fungus mat but rust actually sounds better. I run a stiff wire like an unwound hanger into the hole and open it up so the water will drain onto the tray made to collect this water underneath the fridge. Last time I left the wire in place with a long handle and I haven't had water to mess with for many months now. My hole is between the two crisper drawers and when I get into either of them the wire gets a jiggle and I guess that's all it takes to keep the hole clear so the water can drain like it's supposed to.
Otherwise the fungus builds and builds until it sluffs off as a wad and plugs up the works on a regular basis. Too funky for sure.
Posted on Jun 21, 2009
Water in crisper drawer of Whirlpool model number ET18TK
the water in the bottom of the fridge will be from condensate running down the back wall and not collecting in the drain ridge to flow outside to the dish on top of the compressor. It comes from overloading the fridge by opening the door too often and excess food trying to cool down. check and unplug any blockages in the drain and pull any containers away from the back wall as water will flow off the wall onto them and miss the drain all together. The drain ridge will be under 1/2 way down the back
Dec 25, 2013 | Cars & Trucks
Water comes off somewhere in the bottom of my fridge. what could have caused it?
When your refrig goes into defrost , the water runs down the back of the refrig ( inside ) and out to the drip pan thru a drain hole under the crispers . If water is under the crispers , remove the crispers and you should see a " cap " covering the drain hole . Sometimes crud will cover the slots where the water is supposed to drain , causing water to pool under the crispers . Just remove this cap , clean , and reinstall .
Mar 20, 2011 | Magic Chef Refrigerators
Water accumulating in bottom of refrig under crisper drawers but not in drain pan under unit.cannot locate drain line
Here is a tip that I wrote about how to fix your freezer so that the drain hole does not keep freezing up.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 23, 2010 | Kenmore Refrigerators
Water pooling inside of refrigorator
sounds like the drain line for the defrost cycle is plugged. the water is supposedto end up in a pan under the refrig. the drain probably needs to be defrosted and cleaned.located behind the back panel in the freezer compartment
Jan 21, 2010 | Frigidaire Refrigerators
On the top back of the fridge is a unit that seems to be connected to the freezer. It leaks intermittently into the refrigerator and pools under the crisper baskets as well as wetting food that is on the...
Looks like you have a clogged drip tray channel. Unplug the refrige ,leave freezer and food compartment doors open for at least 12 hours. After that look under behind the refrige for a plastic-rubber tubing ending in the drain pan under the refrige.That is clogged, get a 2 feet hose 1/2 inch diameter. Attach end to the drain tubing then blow through this will clear the way.. and your done.
Dec 31, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Whirlpool refrigerator has water pooling under crisper
  1. take all things out from freezer
  2. open back wall of freezer
  3. clean the drain hole in the bottom middle
  4. put all back
  5. good job you fix it
Dec 29, 2009 | Refrigerators
Water drips from freezer into refrigerator
The drain is clogged..you need to see if it has a rubber drain trap going into the back side of refrigerator. if so, twist and turn as you pull it out and clean it..replace and then check that drain is open..if no drain trap on back side of refrig..remove freezer wall and open drain from inside freezer..you need to clean out drain trough using hot water..a little messy,but effective
Jul 12, 2009 | Refrigerators
Water collecting under crisper drawers.
When the refrigerator goes into defrost mode there is a drain tube that allows water melted off the evaporator coil to go into the drain pan that you found empty. That drain tube is clogged.
May 02, 2017 | Whirlpool ET1MHKXM Top Freezer...
Water collects on shelves in refrig.
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 26, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerator
check behind the drawers is there a water tank for water in thew door that would be my first guess
Feb 10, 2008 | Kenmore 63074 Top Freezer Refrigerator
Refrigerators Logo
476 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
