Question about Pioneer DVR-110D DVD RW Dual Layer Burner
Burner saying its enabled and ok but not able to read any disks
Hi everyone, i have a problem where the burner does not see the disk when its in the drive but it says that it works and is ok. i want to back up everything so i can format my drive due to viruses. i tried updating the drivers, i've uninstalled and reinstalled the burner and still no change. if anyone can help it would be much appreciated.
Re: burner saying its enabled and ok but not able to read...
I've solved the problem by... flashing DVR-110 firmware instead of DVR-110D. Strange, but it works...!
Posted on Apr 06, 2008
  • 208 Answers
Have you setup the boot order to cdrom first?.. also is the cd 100% bootable? i use to burn a bootable cd ISO file inside the zip file i extracted.
i had to use a tool once called filtercheck i got it from in the forums by searching for filtercheck.. theres 2 versions one says check other says removal. the removal will say found some filters. i removed all and its all ok .. had to reinstall burning application though.
Posted on Nov 03, 2007
0 characters
3 Points
My Dvd Writer Can't Read Dvd Disks But Can Read Cd Disks
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
hope this helps you
Aug 25, 2011 | Samsung TruDirect SpeedPlus DVD-RAM...
Try using a Iris eye cleaning disk. Mosxt times when constant reading occurs or it says no disk it is the iris inside that has become occluded with dirt. Checkl that there are no finger marks on the disk and it is clean too
Once you have run the cleaning disk use a non scratched clean disk to check its load and read ability before trying in the disks that you had trouble with.
If they still give trouble then the problem will be with those disks and not the laser in the unit.
Please rate my help++++Thanks for using FIXYA
May 09, 2010 | Samsung SH-S202J 20x DVD?±RW DL IDE Drive ...
My cd/dvd burner stop working it won't read
Try cleaning the laser lens with alcohol and a Q-tip. If this does not work then the burner is tired.
Aug 11, 2009 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
DvD is not reading content off disks
So if I understand this correctly the software says it burns ok but still dose not read.?
Can you burn withour verify and test the read in another machine.
If it the software says it burns ok than you should be able to read it any where else that is compatable
Jul 29, 2009 | Sony DRU 500A DVD±RW Burner
Does not read disk
2x dvd will work since it records at 2x speed
Aug 12, 2008 | JVC Everio Share Station DVD Burner Burner
Message: "No Disk in Drive"
hi tip53
it seem you had problem with optical cd/dvd drive, open your Samsung sw 240b, under the optic there's potentio try to adjust it by twist to left slowly.
may help
goot luck.....
Jul 23, 2008 | Samsung SW 240B CD-RW Burner
open the cabinet  try changing the cables connected to it   and restart  the system this will do
if not then reinstalll l the os after makin essential backups
Jan 01, 2008 | LG GMA-4020B Super-Multi...
Pioneer DVR-110D DVD RW Dual Layer Burner Logo
175 people viewed this question
Top Pioneer CD & DVD Burners Experts
Brian Sullivan
Brian Sullivan
Richard Roberts
Gareth Cockram
Gareth Cockram
Are you a Pioneer CD and DVD Burner Expert? Answer questions, earn points and help others
