Question about GE WPRB9220D Top Load Washer
Shoestrings wrapped under agitator
After washer my running shoes, the shoestrings are caught ubder the agitator. How can retrieve the shoestring?
  • 146 Answers
Re: Shoestrings wrapped under agitator
You will have to remove the agitator. Remove the softener dispenser from the top of the agitator and when you look down the agitator, you will see a 10mm stainless steel bolt. You will need to remove this bolt to remove the agitator. If there is no bolt, try pulling the agitator up and out.
Posted on Nov 03, 2007
0 characters
3 Points
1+ year old GE wjre555ok2ww washer won't release the wash water during spinning. How can I fix that?
Small things get into the electric pump. I removed coins and shoestrings from the pump in the past. They are easy to take apart and clean up. Rarely do they fail.
I have a video and service manual for your Hydrowave Machine HERE
Mar 04, 2011 | GE WJRR4170BT
My washer wont drain
I was working on one of these machines one day with the same problem. I took the electric pump apart and found a shoestring in it.
I have a video which shows how to get into the machine and more HERE
Dec 27, 2010 | GE WBSR3140DW Top Load Washer
Easy fix. Remove the front panel. Get the shoestring or whatever it is out of the electric pump.
Sep 09, 2010 | GE Washing Machines
Won't drain water or spin
2 seperate problems but related. The drain problem could be something in the pump. Recently I removed some shoestrings from one. To get into the machine is easy. The top is bolted down. The front panel has to come off first. To do so place a thin knife between the top and front and press down to release the clips holding the front on. That is the pump on the bottom rightdbffad1.jpgLets talk about the no spin issue. The lid switch assembly could be at fault. After the front comes off you can easily remove the top, unplug the lid switch and check it for continuity.
Apr 28, 2010 | GE WBSR3140DW Top Load Washer
I need to know how to take the cover off. water
I removed a shoestring from one of them pumps not long ago. The electric pump comes apart easily for cleaning. Remove the 3 screws holding the bottom panel on, they are under the washer between the base and the washer. First try cleaning out this pump filter. With any luck you won't have to ring for service.4010f77.jpg
Mar 10, 2010 | GE Washing Machines
How do I pull the agitator out of my washer so that I can clean the drain
I fixed one of these with a drain problem not long ago. Their was a shoestring in the pump. To get to the pump you remove the front cover. The pump comes apart easily for cleaning. Have your mop ready. This old school manual gives directions for removing the front panel. The top does not pop off the front pops off on these washer.
Mar 06, 2010 | GE WBSR3140DW Top Load Washer
Washer working thenstopped - burning rubber smell
I happened to me once and it was a case of a shoestring getting sucked into the pump. I had to disassemble the pump to get it to work again.
Jul 21, 2009 | GE WBSR3140DW Top Load Washer
I need to remove GE topload washer agitator
Pull up hard on the agitator. It will come up.
Mar 21, 2009 | GE Washing Machines
Laundry is trapped under the base of the agitator.
Im not very familiar with that type of top loadign washer,,, but on most agitators there is a bolt that runs down the center of the agitator, connecting it to the transmission/gearbox. Usually there is a cap, or softner dispenser that can be pulled off, revealing this bolt.
Mar 13, 2009 | Washing Machines
GE WPRB9220D Top Load Washer Logo
604 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
