Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Slow Mow I have a MTD YardMachine, I recently replaced the drive belt on, I noticed the belt was a little sloppy around the pullys.I started to mow my lawn, but the mower would drive slow even with the speed setting set at its highest setting ( 7), it was just too slow. Also before all this,I noticed there was a little spot of oil or grease under the drive gear or transmission. Maybe the trans needs oil, and how do i put it in?, theres doesn't seem to be any where to add it to. Any help please Thank You, Joe
    Scholar:
  • 81 Answers
Try fixing this problem by making sure the belt is installed properly.. Whenever you install a drive belt it needs to be "seated". Make sure the belt is on correctly and the first time you try it out to see if the mower will move, start out in the highest gear. Hang on as it may ****, but this is the proper way to replace and seat a drive belt.
Posted on Jun 22, 2009
My 160 has started having trouble mowing at its normal speed in my yard. I have not changed the height I mow at, or the frequency at which I mow... What's happening?
i am assuming you are talking about a john deere. if it has a lot of hours or is very old the drive belt may need replaced if you are talking about speed. if you are talking about missing some grass the deck belt may need replaced.
Aug 20, 2017 | Garden
2008 craftsman lt1000
you need a govenor adjustment take it in or or your waiting to long to mow grass slow down when you mow or mow more often
Sep 02, 2014 | Garden
What do i do i put gas in oil tank self propelled snapper?
If you did not try to mow the lawn, but shet the motor off before there was a loud KA BOOM.
If not, it is time to consider a new motor.
Otherwise just drain the crankcase like you would to change the oil.
If you have a friend that could help tilt the mower so almost all the gas is drained.
Now, put oil in the motor, 40 wt because there will still be a little gas left in the motor and when you mix gas and oil the gas is absorbed by the oil and the oil will thin out.
DO NOT! start it up and rev up the motor. You want to let any remaining gas to be taken up by the oil. Run around your lawn a few times at a moderate speed WITHOUT the blades engaged.
After this you can mow the lawn, at a moderate throttle setting, then drain the oil and fill it with the oil your owner's manual says to use.
Or just put around your yard for 30 - 40 minutes, then change the oil.
The above will only apply if you didn't mow until you had flames coming out of the exhaust and banging, knock ing noises were coming from the motor.
Jun 04, 2014 | Mtd Yard - Man 160cc, 21" Self - Propelled...
No engine power when deck engaged
dirty air filter on carb or spark plug might me loose lowering compression which will in turn rob your power
May 17, 2013 | Mtd Garden
Mtd 42" riding mower rear drive belt keeps popping off pulley
Hi, check the idler pulley arm and return spring on that belt. Its most likely not pivoting freely allowing the belt to loosen when you operate the clutch, regards Phil.
Jun 10, 2012 | Mtd Garden
Adjust the drive belts,
if you have the belt installed correctly, the idler pully is the only adjustment and thats automatic. i trust you have installed the correct belt.
Apr 29, 2010 | Garden
Need a repair manual for a huskee 21hp. 46" cut model#13at688h731 George`s e-mail hvg.prop@cox.net
My MTD Huskee 21 HP 46" Lawn Tractor keeps breaking the transmission belt. We have replaced it several times and it breaks again after 4 or 5 mowings.
Apr 19, 2010 | Mtd Garden
Hi there i have an 18hp 42'cut power kraft deck probleme
Hi ! I have the same mower. It is an older machine and possibly the belt that drives the mower is worn. The belt drive is spring loaded and when you engage the mower by lowering the lever, aspring pulls the deck backwards against the blade. If the belt hasn't been replaced in a while, I would start with that first.
Apr 08, 2010 | Mtd LAWN MOWER PART # 791-180705 Assembly,...
Riding mower goes slow in forward speed
There is a variable speed pulley that is a double pulley....one belt from engine to pulley and one from pulley to transaxle....remove both belts...pushing in the clutch will help with removal....remove o ring on top of pulley and pull up......the middle piece of metal is stuck....this piece is meant to slide up and down.....put the middle piece of metal on your pulley in your vice...wd40 the hell out of the shaft on pulley .....grasp the top with one hand and the bottom with your other hand...work the stuck pulley free.....put lithium grease on shaft...reinstall....done
Mar 09, 2009 | Mtd Garden
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
503 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
