Cars & Trucks Logo
faith sindisiwe Posted on Apr 29, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just want to know when can i register occupational health and safety management and how much is it ,diploma
Alfredo Kraus
Level 2:
  • Expert 62 Answers
  • Posted on Apr 29, 2014
Alfredo Kraus
Expert
Level 2:
Answers
62
Questions
Helped
21572
Points
151
The simplest way to do is - open the account in Linkedin.com website. World Largest Professional Network LinkedIn
1helpful
Im missing my cousin allan williams and his wife that moved to morwell victoria and appear to be missing .any hears from then pass this on please
contact the Morwell police and report a missing person/s
give them details as to make of vehicle , occupation, place of work health details , all you know and ask them for help
Where is passenger side air bag relay 2007 MKZ
There is no relay for the passenger side air bag . What seams to be the trouble ? There is possibly a code set in the air bag control module .
Air Bag and Safety Belt Pretensioner Supplemental Restraint System (SRS) The air bag supplemental restraint system (SRS) is designed to provide increased collision protection for front seat and second row outboard occupants, in addition to that provided by the 3-point safety belt system. Safety belt use is necessary to obtain the best occupant protection and to receive the full advantage of the SRS.
This vehicle line contains dual stage deployment (advanced restraint system) driver and front passenger air bag modules. These vehicles are also equipped with driver and front passenger safety belt retractor pretensioners. These vehicles can also be equipped with optional side air curtains that deploy from the A-pillar to the C-pillar upon a side impact. Vehicles with optional side air curtains are also equipped with seat side air bag modules in the front seats.
Side air curtains deploy from the headliner, protecting the first and second row outboard occupants during a side impact. Seat side air bag modules deploy from the outboard front seat backrest upon a side impact. In addition, a front impact severity sensor is mounted to the lower radiator support, a seat position sensor is mounted to the driver seat and a usage detection switch is added to the front driver and passenger outboard buckles. If equipped with optional side air curtain modules and seat side air bag modules, there are an additional 4 side impact sensors.
Vehicles are also equipped with an occupant classification sensor (OCS) system as part of the front passenger seat. The OCS system includes 2 OCS rails and an OCS module.
Passenger Air Bag Deactivation (PAD) Indicator
The passenger air bag deactivation (PAD) indicator is a visual indicator used to inform the front seat occupants of the passenger air bag deactivation state. The PAD indicator is a stand-alone lamp installed into the vehicle instrument panel in a position visible to each front seat occupant.
The restraints control module (RCM) controls the state of the PAD indicator through a direct hardwire connection, based on information provided by the occupant classification sensor (OCS) system. The PAD indicator is lit to indicate the passenger air bag module is disabled. An exemption to this is when the front passenger seat is determined to be empty and passenger safety belt buckle unbuckled, and therefore indication of a deactivated passenger air bag module is not necessary. In all other cases, the PAD indicator is unlit when the passenger air bag module is enabled.
When the ignition switch is in the ON position, the PAD indicator prove-out period is initiated by the RCM. The RCM briefly activates the PAD indicator to prove-out the indicator function and verify to the front occupants correct functional operation of the PAD indicator.
The PAD indicator will be lit/unlit within 1.0 to 1.5 seconds of a change of state from the OCS system.
When an OCS system fault is present, the RCM defaults the passenger air bag module to the last valid state received from the OCS system until the ignition switch is turned OFF. If the OCS system fault is still present when the ignition switch is turned ON, the RCM defaults the passenger air bag module to enabled regardless of the size of occupant in the front passenger seat. The PAD indicator will be unlit. For information on the OCS system, refer to Occupant Classification Sensor System in this section.
The following table indicates the passenger air bag status and the PAD indicator status based the size of the front outboard passenger occupant.
I HAVE APPLID FOR A DIPLOMA IN SAFETY MANANGEMENT THEY SAID THAT I DID NOT MEET THE REQUIREMENT SO WHAT CAN I DO
That depends on the requirements set forth by the institution offering the diploma. Please contact them for their requirements.
Work done and not being paid
I understand you are located in South Africa. Click here for a link to that country's Labor Laws.
Below is a list of contacts taken from the Contact Us Page. Good luck!!
General advice
[email protected]
Conferences and training related enquiries.
(012) 661 3208 Fax: (012) 661 1411 / 086 546 2561 / 086 528 3464
Magda [email protected] or Peraldo [email protected]
Manager - Susan Brits [email protected]
Health and Safety Enquiries
(012) 666 8284 Fax (012) 666 8264
Deidre [email protected]
Health and Safety Manager - Tinus Boshoff [email protected]
Postnet Suite 114
P. Bag X 1007
Lyttleton
0140
How do we fix front passenger side seat belt retractor on 1999 Ford Taurus? It will not pull out....
you may have to remove the bolt that holds the buckle to the floor. Try to push the belt into the retractor and see if it frees up.
I assume you are saying it is in the locked mode. It has an automatic lock mode for holding a child seat. When the belt is pulled all the way out, it goes into locking mode. You will hear it ratchet when the belt starts going back in.
Section 01-20A: Restraints, Active 1999 Taurus, Sable Workshop Manual
DESCRIPTION AND OPERATION Safety Belt, Lap/Shoulder The dual locking mode retractor on the shoulder belt portion of the combination lap/shoulder safety belt for the front seat passenger and rear seat outboard passengers operates in two ways:
  1. In the vehicle sensitive (emergency locking) mode, the shoulder belt retractor will allow the occupant freedom of movement, locking tight only on hard braking, hard cornering or impacts of approximately 8 km/h (5 mph) or more. The front and rear outboard seat belt retractors can also be made to lock by pulling/jerking on the belt.
  1. In the automatic locking mode, the shoulder belt retractor will be automatically locked and remain locked when the combination lap/shoulder safety belt is buckled and does not allow the occupant freedom of movement. This mode provides tight lap/shoulder belt fit on the occupant and on a child safety seat or infant carrier installation restraint.
  1. When the combination lap/shoulder belt is unbuckled and allowed to retract completely, the retractor will switch to the vehicle sensitive (emergency) locking mode.
sxh~us~en~file=ani_caut.gif~gen~ref.gif WARNING: REAR-FACING INFANT SEATS SHOULD NEVER BE PLACED IN THE FRONT SEATS.
The automatic locking mode must be used when installing a child safety seat on the front passenger seat and rear outboard seats where dual locking retractors are provided
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
