Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
Port forwarding on dlink adsl2 router
I need to do port forward on Dling ADSL2 Router for DVR online View
  • Anonymous Mar 14, 2014
    port forwarding ?
    Scholar:
  • 58 Answers
Step 1. Before you open ports in your router, set the computer (or the device) which requires
ports to be opened for, with a static IP address. You can choose any IP address from the
range of addresses you are using on your local network, as soon as it is not used by any other
device. The default range is from 10.1.1.2 to 10.1.1.254. In our example we are using
10.1.1.99.
Windows XP: Control Panel > Network Connections > Local Area Connection > Properties >
Internet protocol TCP/IP > Properties
Windows Vista: Control Panel > Network and Internet > [Network and Sharing Centre] > View
Network Status and Tasks > View Status > Properties > Internet Protocol v4 > Properties
Select the “Use the following IP address” option:
IP address: 10.1.1.99
Subnet mask: 255.0.0.0
Default Gateway: 10.1.1.1 (your router’s address)
DNS: 10.1.1.1 and 61.88.88.88 (or whichever your provider is using)
Now open the necessary ports in your router and redirect the traffic to the 10.1.1.99 address.
Here are the steps:
How to open ports in your router Page 2 of 6
Step 2.
Open your web browser and enter the IP address of the router (http://10.1.1.1). Enter
user name and password (default username “admin” and password is “admin”).
Step 3. Click on Advanced at the top and then click on LAN Clients.
How to open ports in your router Page 3 of 6
Step 4
. You will need to add a LAN Client (the address of your computer or a device) into the
router before you can open any ports. Type in the IP address of the Computer/Device (the
one you assigned in Step 1). You can specify the name of this workstation under Host Name
(optional). Click Add and then Apply.
Step 5. Go to Advanced > Virtual Server (Port Forwarding). There is a list of pre-set ports in
the router which you can choose from.
How to open ports in your router Page 4 of 6
Step 5a.
If your specific application is not listed there, you can add the necessary ports
yourself. Select the “User” Category and click on Add button below.
Step 5b. Enter a name for this entry under Rule Name. Then select the necessary protocol. If
there is a range of ports to open, specify the starting port under Port Start and the ending port
under Port End. If you need to open just one port, specify this port number in all fields
including the Port Map. Click Apply.
How to open ports in your router Page 5 of 6
Step 6.
Go back to Advanced > Virtual Server. Under LAN IP select your LAN Client (which
you added in Step 4). Select the Category and the desired Rule or select “User” Category
and you should see the rule which you have created in Step 5b. Select it and then click on
Add > to move it into the Applied Rules section. Click Apply.
Step 7. To save the new settings into the router's memory go to Tools > System. Click on
Save and Reboot button. The router will save the settings and restart.
Posted on Jun 21, 2009
Port forwarding
WHEN YOU OPEN A PORT YOU NEED TO ASSIGN THE DEVICE THAT GOES ASSOCIATED WITH IT...LIKE PC1 IP 192.168.1.1
PC2 IP 192.168.1.2 THE PORT YOU WANT TO OPEN NEEDS TO BE ASSOCIATED TO EITHER PC1 0R PC2 WHICH EVER IS RUNNING YOUR APLICATION...TEKGODS.COM
I’m happy to assist further over the phone at https://www.6ya.com/expert/jaime_08785c7d726a554e
Feb 18, 2013 | D-Link DSL-2740R Wireless N ADSL2 4-Port...
Hi, ADSL2+Wireless Modem Router was set up, it was good, but without the yellow cable, it was not connect to net why? Thanks, looking forward of your reply.
Because you need to match the security setting on the wireless router to sign on to the wireless portion of the modem. If you flip it over, you should see a sticker with WEP on it- write that down, view available wireless networks, and enter in the key from the sticker when prompted- at that point you should be able to use the wireless portion of the modem
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
May 31, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
How do i enable ports 25 SMTP and 53 DNS on a Netgear ADSL2
It depends on your router. First you need to login your router.
Then you need to find the port forwarding field. There you tell which ports to forward. In your case its 25 with TCP transport and TCP and UDP for port 53.
For each port you need to tell the router where to send the packages to. So you need to know the IP of the computer you want to get the packages forwarded to.
Some more detailed instruction which depend on the Router version (ADSL2 is not a specific version!) can be found here: http://kbserver.netgear.com/kb_web_files/n101145.asp or http://kb.netgear.com/app/home
Mar 14, 2011 | Computers & Internet
Any one know how can I configure forwarding so my emule will work
Port forwarding is very easy task with Router Commander program. Install it and this program will forward ports automatically. Router Commander speeds up slow Internet via router and prevents router from dropping connections also.
Oct 05, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
No port forward even though its advertized adsl modem is the dsl-264ou
Download and install Router Commander (fully compatible with your router) and that's all. The software will forward ports automatically.
May 12, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Port forwarding GLB-502Trouter With utorrent
Here is a link to the specific steps you need to setup port forwarding on the GLB-502T
http://portforward.com/english/routers/port_forwarding/Dlink/GLB-502T/Lingo_VoIP.htm
Dec 29, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Port forwarding
http://portforward.com/guides.htm
http://portforward.com/english/routers/port_forwarding/Dlink/DI-624/Utorrent.htm
Dec 16, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Port Forwarding
Try here:
http://www.portforward.com
Aug 11, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
1,419 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
