Question about Nokia Consumer Headset
Signal i have problems with nokia 1600 signal
  • 906 Answers
Good day,
hope this link below will answer your query.
nokia
Posted on Jul 28, 2010
No signal nokia 1600
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Aug 13, 2012 | Nokia N Cell Phones
How to rapair nokia 1600 no signal
hi,
No signal on mobile phone has many causes.
1) probably, loose contact on its antenna.
2) Hardware related.
3) Software related.
For problem 1. Open your phone using t6 screw driver. Check the antenna connection if it is still contact with the board of free from any debris.
For problem 2. Need cellphone technician to do it.
For problem 3. Try resetting it to factory settings. If still no signal, have it repair by technician.
Note:
only open your phone when there is no more warranty on it.
Don't forget to rate me. Thanks.
regards,
john
Jan 09, 2011 | Nokia 1600 Cellular Phone
Stopped selecting the network sutomatically or
hi,
if the phone is stop selecting network automatically or manually ,maybe its software problem the furst reason or the hardware component called 2n2 capacitor..in the first case the phone is just experiencing signal problem that having no reason,no water damage or not drop...the solution to this is write PM or permanent memory...here is the procedure,tools and gadget you need..
1,jaf box gadget
2,1600 fbus
3,pm files of 1600
open jaf box ,select dct4 then check the phone is connected...if phone is connected ,thick write pm then service and select 1600 pm from the folder...if the writing is done ,it goes your phone with contact service but it can fix by simply thick unlock....
test the phone if it is now selecting signal ,if not yet go to the next solution ,changing 2n2 capacitor...
here is the location of 2n2 capacitor of 1600 ,you can get this component even in the old model nokia phone like 3210 ,8210 etc...
http://i935.photobucket.com/albums/ad200/Ongskie79/1600-2n2.jpg
after changing capacitor ,test the unit...goodluck and thanks for trusting fixya...
Jun 19, 2010 | Nokia 1600 Cellular Phone
NOKIA M.NO.1600 IS NOT GETTING LITING, HOW TO RECTIFY?
this may be due to failure of light ic plese go to
a mobile technician
May 04, 2010 | Nokia 1600 Cellular Phone
HOW TO REPAIR NOKIA 1600 BACK LIGHT PROBLEM
Nokia 1600 light problem solution ways. this image is how to repair light problem in nokia 1600. check the link from positive point of battery terminal to the resistor shown as in diagram make jumper as shown and it will work if the link was broken
Apr 21, 2010 | Nokia 1600 Cellular Phone
No network in 1600 nokia phone how to solve it
It depends on the signal strength(ie tower location)of your service provider.Contact your service provider and if still remains the same you need to change your service provider(ur sim)with good signal strength in your area.
Oct 03, 2009 | Nokia 1600 Cellular Phone
Can't get signal anywhere
To use your O2 simcard in Your mobile you need to unlock it. Unlocking using codes is the easiest way to unlock. You need codes to unlock your mobile. These codes are available at www.mobile-unlocker.com.
Apr 05, 2009 | Nokia 1600 Cellular Phone
Call Ending
i believe your cellphone is not originally there so the phone might be modified so that you can use it in your country i think the reason why the call stops is the poor network signal due to modifications made to your phone my advice for you is to consult the cellphone technician to check the network flex on your phone
Sep 22, 2008 | Nokia 1600 Cellular Phone
NOKIA 1600 IMEI ???????????????
yes sir' JAF can solve that prob.
by using RPL logs...
Jan 09, 2008 | Nokia 1600 Cellular Phone
Nokia Consumer Headset Logo
Top Nokia Radio Communications Experts
shaun taylor
woodzowl307
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
