Computers & Internet Logo
Winston Nyasha Chiromo Posted on Apr 29, 2014
ACER TRAVELMATE 5730 DISPLAY
FIX ACER TRAVELMATE 5730 DISPLAY PROBLE-NO BACKLIGHT,SCREEN IS DIM
amit saxena
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 24 Answers
  • Posted on Apr 29, 2014
amit saxena
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
24
Questions
0
Helped
2817
Points
47
Get recharge the LCD from service center.
Acer travelmate 5730 webcam not working
upgrade correct up to date driver first -
http://support.acer.com/product/default.aspx?modelId=238
2helpful
Acer travelmate 5730 factory settings restore
Acer Travelmate laptop by pressing ALT+F10 during the bootup to get to the eRecovery and restored the computer to factory default.
How to center my display in acer travelmate 5720
If your display is not centered try adjusting your screen resolution. Click Start/Control Panel and look for Display or Appearance and Personalization. Open them to open the display properties and click the settings tab for screen resolution. Set your resolution up higher. The higher the resolution, the smaller the icons, thus the more fits on the screen. Normal resolution is about 1024x768.
I have an Acer Travelmate 2700 but the problem is the backlight not coming on but if you put light on the screen its displaying but its dim. If i connect on an external monitor its displaying.
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
1helpful
I am having a ACER TravelMate 5730 laptop. For the past three or four months whenever I boot my laptop it gives a blank white screen. If I reboot one or two times it will be ok and works fine. Sometimes...
2 Solutions Possible.
The connection between the LCD Screen to the motherboard is not connected well and is causing the issues you are having.
OR.
The screen itself needs to be replaced because it defective.
Screen flicker Problem (Acer travlemate 5730)
the wiring for the display goes through one of the hinges in the back .. if the wiring is pinched or damaged then that could cause your trouble .. there is usually a cover over the hinges that comes off .. you may be able to see the damage ..
My acer aspire 4320 have no light in the display
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
ACER 4100 TRAVELMATE
If this happened suddenly, the backlight power supply (inverter)  has probably failed. It could be the backlight itself but they normally will dim or flicker before they die.
Try shining a light at an angle on the display with the computer turned on and look at it from an angle too. You may be able to see video very faintly; if you do, then it is as described above; a backlight problem, not the LCD display itself.
Acer Travelmate 201T most times no display
If the backlight is coming on its not the inverter, check the ribbon cable for the screen itself, If its been opened and closed alot maybe be time to replace the screen. Check connections first, go from there.
Grand Canyon Tech
Grand Canyon Tech
