Minolta Ep2030 Error C06
Hello There, i have a Minolta EP2030When i turn my machine on i get an Error C06 with a red Wrench and i'm stuck there. can you be of assistance
  • 92 Answers
Open and close the front cover while machine is in error stage
Posted on Jun 26, 2009
C06 50 error code minolta dialta copier
The scanner which is the bright lite under the big glass has a home sensor to let the copier know that scanner is back home and ready to scan again. will the code is saying the senor is bad, could be dirty get some can air. Remove big glass will be though to get at small and black under the scanner bay side.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 02, 2013 | Minolta DiALTA Di183 Copier
Minolta dialta di183 copier error code c06 50
C 0650 - Faulty scanner home position sensor.
Remove the glass and clean the home sensor.If the scanner moves smoothly remove foreign matter and other obstacles,clean the scanner rails,clean or change the scanner bushing.Place WD 40 oil on scanner bushings.
My dialta minolta di183 is showing C06 50 code and i dont know how to go about it
Clean the home scanner sensor scanner is what moves as it scans the document. then go back to home position there is sensor that tell the copier it is back home clean dirt or might need to be replaced.
EP2030 Minolta error code C0660
Under the big glass to your right under that black cover is a lens assy., and mirror assy., something is jammed in there or bad motor. open front door upper left access cover remove cover touch trouble reset to reset machine.
May 08, 2012 | Konica Minolta EP2030 Fuser Thermofuse
The copier is displaying error code C06 (or C0b) 60. If I unplug the sorting tray (where the copies exit) the machine will make copies, otherwise it is frozen with the above error code and a red wrench? ...
I can tell from the code this must be a Minolta copier or made by Minolta. The CoB60 code is a sorter failure code. This code must be reset by opening, then closing the sorter. By that I mean if you have a 10 bin sorter that hangs from the left side of the machine then you need to release the sorter away from the machine then close it back. Same thing with the 20 bin which sits on the floor. Pulling the sorter away then re-attaching is the only way to clear this code. Now if the code comes right back then there is a mechanical problem which must be repaired. The 60 code deals more with the stapler in the sorter. You can try reloading the staples but that rarely works. It is either a jammed staple or a problem with the stapler itself.
If you need further info just reply back with your specific model and issues.
Thank You for using Fixya.
WheatlandServices
Nov 18, 2010 | Office Equipment & Supplies
I HAVE A MINOLTA COPIER EP2030/ WHEN I TURN ON COPIER IT SHUTS OFF IMMEDIATELY. CAN'T FIND A RESET BUTTON,DOES IT HAVE ONE? ANY SUGGESRIONS?
In my 27 years working on Minolta copiers I have seen this problem twice. Both times it was because the top half of the machine that opens up as when removing paper jams is not fully closed down. Also called the "clamshell". I may be wrong but check to be sure the top 1/2 of the machine is fully closed and latched to the bottom half.
Good Luck and Thank You for using Fixya.
Sep 10, 2010 | Minolta Office Equipment & Supplies
On our Ep3170 we get a C5 error code and the wrench symbol
Hello sir;You must remove the left side panel to access the service switch(s1) on PWB A you press this switch to chose the "C" then enter 0 press "#" ,then press "CLEAR" to terminated.
Jan 17, 2010 | Minolta Office Equipment & Supplies
Minolta EP2030 shuts off immedietly when I power it on
Do you see a error code? Like a C5? Try holding the power botton on and look for a code that shows up on the display. You may have a blown heater lamp or scanning lamp. You are losing your AC power some where.
Jan 22, 2009 | Minolta EP1083 CS/PRO Copier
Minolta EP2030 exposure lamp timing wrong
"Exposure lamp timing wrong" simply means that the lamp is coming on at a time when it should not be coming on. It is not a problem with the lamp itself. It is most likely a power supply problem. There is probably no simple fix.
Just because Konica Minolta no longer will sell you an agreement does not mean that you cannot get the copier serviced. There are plenty of independent repair agencies that would love to service your copier, unless you are in a really remote location.
The EP2030 was one of the last Minolta analog copiers, and parts are still readily available.
Nov 13, 2008 | Minolta EP1030/1030F CS/PRO Copier
Error message
???????????? you did not specify model or make??
the only one I could find is a minolta w/c610 error
Lens motor drive
when you turn on the machine is the lens suppose to move to find home in vert and hor mode? Then, check motor to see if it moves lens
Jan 16, 2008 | Office Equipment & Supplies
119 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
