Question about Samsung SPP-2020 Thermal Photo Printer
The rollers in my samsung spp-2020 are sticking
When i'm trying to print pics the rollers dont seem to be catching the paper, but it is the correct photo paper i'm using, please help!!!
  • 721 Answers
On most printers there's a "thing" near the rollers that grabs the paper. It's usually a flat piece of plastic with some kind of stuff on it that grips the paper. It's actually on the out bound side of the printer. You can re-glue the pad by super glue if the part isn't available.
Posted on Jun 21, 2009
Rollers unable to pick up the new paper I received recently. Had a few sheets of old paper left and working fine with these. I saw there was a similar question posted by someone else with same problem.
clean your paper receiver roller,
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
Nov 23, 2009 | Samsung SPP-2020 Thermal Photo Printer
How do i use the blutooth on my samsung spp-2020 printer??
Enable the bluetooth function on the printer and then, on the bluetooth device (Like a cellphone for example) choose "Print via Bluetooth".
Nov 03, 2009 | Samsung SPP-2020 Thermal Photo Printer
Print cartridge
There is a green 'latch' just above the cartridge when it is installed. If you move this, the cartridge will release.
Best Wishes,
Karlos
Apr 12, 2009 | Samsung SPP-2020 Thermal Photo Printer
Samsung 2020 photo printer
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Samsung SPP-2020 Thermal Photo Printer
Spp 2020
check your windows settings
and   even if thos are correct maty be the connecting cable is not workinfg
Sep 06, 2008 | Samsung SPP-2020 Thermal Photo Printer
Samsung SPP-2020
You need to get the exact photo paper for this model.
The ones that comes with the flaps on each ends.
Without the flaps, the printer won't print.
Aug 05, 2008 | Samsung SPP-2020 Thermal Photo Printer
Paper not feeding in the machine and get a paper jam error Printer rollers do not grab the paper to load into the printer. The rollers turn, put the paper is not loaded.
After so much paper goes thru the rollers they pick up dust and dont stick. Some models you can unplug and then use a q tip soaked in alcohol to clean the roller. Others require you to take them apart to clean. If you have to take it in to get fixed then check out the new ones from a computer store. Sometimes its cheaper to get a new printer than go get yours repaired or cleaned. If you do decide to have it done look really close when they get done and ensure the rollers were cleaned with alcohol. Otherwise they mihgt still have a oil coating on then and that causes them to slip also, especially on photo paper. They will argue in some places that the alcohol will dry out the rubber and it will age and crack. Altho this is true I have yet to see a dry, aged or cracked pickup roller, even 15 years in the business. I think thats because it takes longer to age and crack a rubber roller than it does to just wear out the machine. Jonathon
Jun 18, 2008 | Samsung SPP-2020 Thermal Photo Printer
Paper won't feed on my Samsung SPP-2020
i had the same problem and replaced the ink cartridge and hey presto ! it worked
Mar 10, 2008 | Samsung SPP-2020 Thermal Photo Printer
Samsung SPP-2020 Thermal Photo Printer Logo
556 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
