Question about Radio Communications
How to use all the functions on Motorola ATS 2500 Handie Talkie.
  • Radio Commun... Master
  • 1,654 Answers
Here is a link to a user guide for the US version of the radio: http://www.connectingyou.com/media/HT1250.pdf
Posted on Jun 21, 2009
I have 2 VISAR HANDIE-TALKIE FM RADIOS MODEL: HD5RDD9AA4AN + DON'T KNOW HOW TO PROGRAM THEM TO THE SAME CHANNELS
This is a discontinued radio from Motorola. programming requires a cable to connect to a computer, there is no direct programming available.
While this is not really an answer, the programming software is specific to Motorola and you need to buy both the software and the cables from Motorola.
you would be better served, to determine what frequencies you want and then pay a certified Motorola dealer who has the software to do the work for you.
Dec 05, 2016 | Radio Communications
Do you know the frequency range of the Motorola Handie Talkie Tanapa PMUD1673C?
As a general rule handheld radios will talk up to 2 miles line-of-sight. Anything you place between the two radios will reduce range. Talking from inside a building to outside, you can expect 1/4 to 1/2 mile. This being said, a radio can talk as far as it can see, so if you were on a mountain top, you could conceivably talk many miles into a valley below. Height and placement of your antenna determines range. Holding your antenna upright perpendicular to the earth will give you the best range.
Nov 30, 2016 | Motorola Radio Communications
I am looking for an owners manual for motorola gp68 handie talkie radio
You may download the manual from here: http://www.repeater-builder.com/motorola/gp68/pdfs/gp68-um.pdf
Jan 19, 2015 | Motorola Radio Communications
How to get it to scan handie talkie ltma model
One of your buttons would need to be programmed to Scan. This is done using Motorola proprietary software, a cable, and a radio interface box (RIB). Your local dealer should be able to assist you with programming.
More info at http://n1su.com/900.html
Best regards.
Aug 30, 2014 | Radio Communications
Hi, Was given a Motorola Handie-Talkie Tanpapa: PMUD1481A Model: AAH25KDH9AA6ANFD In good working order, BUT I need an owners manuel to reset and operate. HELP! Thanx, Bob
The radio you are describing is a HT1250 VHF 5 watt with display and full keypad. This radio cannot be reset by the user. It is a dealer programmable radio requiring a RIB (radio interface box), cable, and Motorola proprietary software. Your local Motorola dealer should have a subscription to this software and be able to program the radio to your frequencies.
Here is a link to the manual: http://www.connectingyou.com/media/HT1250.pdf
Best regards.
May 21, 2010 | Motorola T6510 XLR Talkabout Two-Way...
Need to dis-assemble a Motorola Visar handie talkie fm radio. Radio has intermittent volume, lose connection
The radio is easy to disassemble and has no hidden surprises, but I doubt you're going to like what you see once you get it apart. The large screws that are very visible on the outside hold both halves of the outside to the thick radio chasey and mother board.
Your volume problem is typical for older T6400s, and is caused by the speaker binding internally. Motorola does not sell the speaker separately and it is built into the case so you can't really just un-hook it and install a new one in it's place.
That's a shame, they are great radios.
Mar 30, 2010 | Motorola Talkabout T6400 (22 Channels)...
T5900 Walkie Talkie Issue
Hello Bo Duke,
If one radio won't walk to the other my guess if that you have the Privacy Code function set up incorrectly.
The privacy code function mutes the radio unless it receives a signal from another radio transmitting the same privacy code. If Privacy Codes are turned on for Radio A but not turned on for Radio B then you will be able to transmit from Radio A to Radio B but not from Radio B to Radio A. If Privacy Codes are turned on for both radios but each unit is set to a different code then neither radio will be able to talk to the other.
Make sure that the radios are both set to the same privacy code or that the privacy code function is turned off on both radios. You can find more information on how this function is set in the radio's Owner's Manual.
Hope this helps!
Ken
"Go Ahead. Use Us."
Jul 02, 2008 | Motorola Walkie Talkie 2-Way Radio
Operation of handie talkie GP338
Mostly of this features need to be able by the programing software, this mean that if you dont find it with your menu botton, mean that the radio has disable this features, also depends on the system that provide the service to have this features working, on your profile as customer, ETC Check this link can help you http://www.motorola.com/governmentandenterprise/id_2011i/en-sg/public/functions/browseproduct/productdetailpage.aspx?navigationpath=id_801i/id_1388i/id_1152i/id_188i/id_1363i
Aug 25, 2007 | Motorola Walkie Talkie 2-Way Radio
PROGRAMMING
here is a link to the manual for your radio (english http://myweb.accessus.net/~090/bearcatting.html#motoman They do not give out the information of how to program it, only authorised technicians are permitted to do so. Here is the link to motorola customer support in Puerto Rico https://www.motorola.com/pr/feedback.jsp They should be able to tell you where you can get your radio programmed, and what programming is permitted in PR. Hope this helps :)
Mar 21, 2007 | Motorola For MT1000 MTX800 MTX90010v...
Radio Communications Logo
2,080 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
