Question about DeLonghi Microwave Ovens
Where can I buy a turntable motor for a Delonghi AC925EQK microwave. The motor is a Hengxing TYJ50-8A7 220-240v 4W 4RPM
  • 379 Answers
Don't know if you got your motor or not, but I've just ordered an identical part number from ebay - search for "microwave turnable motor".
It is advertised as a Panasonic part but has the exact part number you want.
Posted on Aug 11, 2009
    President:
  • 1,952 Answers
Www.repairclinic.com/0047_6.asp -
www.partselect.com/Microwave-Parts.htm
forum.appliancepartspros.com/microwave.../2544-buying-right-microwave-turntable-motor.html -
Posted on Jun 21, 2009
My microwave oven works, but the turntable stopped turning. How can I repair this?
turntables are turned by a rubber belt from a small motor
have an appliance service center check it out and get a quote
Dec 24, 2015 | LG Microwave Ovens
Change Motor but turn table does not turning?
test the following steps and fix it. God bless you
Turntable Motor
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Touchpad and Control Panel
If the microwave turntable doesn't turn the touchpad and control panel might be defective. This is not common. Test the turntable motor first.
Touchpad
If the microwave turntable doesn't turn and the touchpad has a button to turn the turntable on and off the touchpad might be defective. Check the turntable motor first, that is more likely.
User Control and Display Board
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace. If the motor is good, the user control and display board may be defective.
Main Control Board
If the microwave turntable doesn't turn the turntable motor is usually the problem. If the motor is good the main control board might be defective
Jun 16, 2013 | Microwave Ovens
Turntable has ceased to function when oven is on. Is it dangerous to use like this?
Not dangerous, but your food will not be efficiently or evenly heated. To change the motor do the following:-
There is a panel under the microwave, held on by one or more screws. Remove it and you will see the synchronous motor inside. There should be a plug to disconnect the wires. Remove the motor and fit a new one. Ensure that the microwave is disconnected from the wall outlet before attempting any work on it.
Feb 16, 2011 | DeLonghi Microwave Ovens
Delonghi EM821AAN-800watt The turn table has stopped spinning
Make sure the turntable guide is lined up properly and there is no debris caught in it. Examine the turn table bushing the tray sits on and make sure it is not worn or broken. Make sure the turntable is sitting down in the groove correctly. Lastly it may be the drive motor itself is bad. This is the small motor that turns the carousel. This motor is very difficult to replace and unless you are qualified you should not attempt this repair and leave it to a professional. This motor will cost from $40 to $75 plus the cost of having it replaced. You may want to consider buying a new microwave if this unit is over 5 years old. You could end up spending more to repair this one than a new one costs. Of course you can use it without the carousel.
Dec 02, 2009 | DeLonghi MW 605 Convection/Microwave Oven
The glass plate will not rotate when trying to heat up your food...
Sounds like either the turntable motor has seized or that the shaft of the turntable motor has broken off inside the roller ring. You may need to chek with your local De'Longhi repairer.
Nov 29, 2009 | DeLonghi Microwave Ovens
My turntable stopped running
If you didn't buy the turntable motor then I assume you purchased the coupler ( white plastic/nylon piece that fits into the turntable motor collar and rotates the platen? Is that what you purchased?
Sep 13, 2008 | GE JES1384SF Microwave Oven
Intruction manual needed
Since the company seems to not even offer microwave ovens currently which, to me, is an indication that they are buying and having rebranded some Asian (Chinese or Korean) make and may not even have service information or support.
I checked a site you may not have found that often has info available, Retrevo.
You might want to visit and bookmark it in case they acquire what you need in the future;
http://www.retrevo.com
Jul 06, 2008 | DeLonghi Microwave Ovens
The turntable in the microwave does not rotate.
First you need to see if it is the motor that is bad. Usually you find the relay or switch that powers the motor and see if you have voltage.
Microwaves are better left to professionals. A novice could hurt themselves working on a microwave. I would suggest getting a repair man to fix it or buy a new microwave (whichever works out cheaper for you)
May 20, 2008 | Panasonic NN-T774SF Microwave Oven
Microwave turntable does not turn
I have the exact microwave you do (ems8000w), the motor failed and I found this one worked perfectly as a replacement.
The original is impossible to find.
https://microwaveglasstrays.com
1 x 120v Microwave Turntable Motor 6RPM 4W # F63265G60AP (F63265G60AP) = $14.99
Good luck.
May 02, 2008 | Microwave Ovens
Microwave Ovens Logo
1,342 people viewed this question
Top DeLonghi Microwave Ovens Experts
William Miller
William Miller
Steve Mason
Are you a DeLonghi Microwave Oven Expert? Answer questions, earn points and help others
